Question about Infinity TSS-750 System
My subwoofer is making a regular thumping noise every 3 or 4 seconds. I had it unplugged for along time and just hooked it back up. It makes the sound regardless of where its plugged in and even if it's not connected to the receiver.
    Novelist:
  • 181 Answers
If you can replace the subwoofer, do it! Unless, your whole sound system is based on it. problem inside of subwoofer's internal amp. It's an active subwoofer, must be replaced with same kind. otherwise, take unit to local repair shop for diagnostics and repair. it might be some capacitors gone bad, may be IC chip is at fault. anyway, not do it yourself, unless you're an electronics expert.
good luck,
Alex's Tv Service,
215-806-5980.
Posted on Feb 03, 2010
  • Michael Edwards
    Michael Edwards Oct 23, 2011
    The amp is bad - putting dc to the woofer - don't plug it in unless you want more damage - I have add here and also on ebay - which model amp you have ? (SUB AMP)
Psw110 polk subwoofer, making a thumping noise, even if you unplug it from the subwoofer not the power source
Have you tried resetting the unit to factory settings?
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 06, 2017 | The Audio Players & Recorders
I have subwoofers hooked up and when i hit my brakes it thumps and when i hit the window button it will thump when i hit a bump it will thump what could this be
Interference in the electrical section,try putting a noise filter on your system that should help!!! also make sure all your equipment is grounded properly.
Sep 21, 2009 | Car Audio & Video
Jbl 12 subwoofer loud noise
Hiya, could be the power supply or possibly the amp circuit that has gone. If there are electronic guys in your area, they should be able to sort it out relatively easily. Get a quote first, make sure it is in economical repair as well, but it can be repaired
Jul 09, 2009 | JBL PB12 Subwoofer
Loud thumping noise
ok u hava pero in solb u us mlifayr
vich wat ok and 2 chanl 4 chanl 8 chanl 16 chnal us platal mi
Mar 06, 2009 | AudioBahn AK402 Car Speaker
Thump at the time of shutoff
The amplifier in the sub as with any other amplifier has a capacitor in it. Essentially a battery that holds a charge. When you trun things off such as subs or amps with a powerstrip instead of the intended on off button, the power supply has been cut, but the capacitor is still energizing the unit. So it catches the noise in the line.
Mar 07, 2008 | JBL PB10 Subwoofer
Subwoofer "thumping" w. no audio feed
You need to check your ground connection. If there is a bad ground there will be feedback to the amp and it will just sit there and loop back with the Thump, Thump, Thump sound. I had to wire my amp's ground all the way back to the negative battery terminal. It was a pain but I have never had a problem since :)
Feb 12, 2008 | JBL SCS125A System
LOUD thumping noise when printing
Fuser/ upper heat roller/film or lower pressure roller has lost it's coating, nees new fuser assembly (hot bit at back) about $150 plus labour
Oct 12, 2007 | HP LaserJet 1300 Printer
Need Help
input and output slots???? is it playing although thump present,low current could be the problem check for good connections as well as adequate wire guage.
Jun 29, 2007 | Jensen A600HLX Car Audio Amplifier
Thumping Subwoofer
Ive seen this problem in alot of audio setups in vehicles but most peeps dont know this is not a good thing and will cause damage to your woofers or amp. 99% of the time it turns out to be as you said that bad boy muting circuit. alot of these curcuits do use separate transitors or diodes as mute switches but most of them are directly from the Microproccessor. Only way to trouble shoot this is with a schematic and a good car stereo tech. Good luck
May 25, 2006 | Yamaha RX-V2200 Receiver
Open Questions:
See all Infinity TSS-750 System Questions
Infinity TSS-750 System Logo
1,302 people viewed this question
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
