I am trying to paly a new dvd
Change Of Habit DVD 820 835 5 * 11
Once I press play it comes up and advises
Invalid Region Code.
Could you please advise what this means as I am not getting it on any other DVD
Ihave tried your fix but am unable to sort the problem ,,can u advise in more detail step by step please ...
Sounds like you are trying to play a DVD of a different region to that of the player.
Worldwide region codes, sumarised:
1 - US / Canada
2 - Europe
3 - Asia
4 - Australia
5 - Africa
6 - China
You can change the region code of the DVDR520H to any region or use region 0, which makes the unit multi-region to play DVDs from any region.
This should give you access to a hidden menu form where you can change the region code.
Hi ive just bought a new dvdr5520H , but i need the unlock code for multiregion as i have a lot of region 1 movies ,,,can any one help please ...
thnx ...warren
You advised that you have the same problem. I was able to fix the problem by using the process as advised by avid imps.
Press system on your Philips control, which will bring up the system menu.
Arrow down until you show "SYSTEM MENU EXIT" at the top of the screen.
Enter 2960, which will show Region Code Then change the region code to Region Free.
This will as I have completed this process again while typing this Solution for you.
Thanks
JW6599
