Question about Whirlpool LSQ9610L Top Load Washer
I replaced the dog ears but when I put it back together and try to use it the agitator will not catch on the ears unless I pull up on teh head? There is a black thick ring washer that was broken guessing maybe that needs to be in?
  • 129 Answers
Yes
Posted on Feb 04, 2010
Agitator not working but spinner is fine how can i fix myself?
the dog ears are wore out look at a vid on it type in dog ear re[placement washer perhaps that will lead you to one if you open the washer the center top of the agitator pull off the cap there should be a bolt head down there unscrew it and pull out the top area the dog ears will be there three little plastic thing looking like teardrops with small fins to catch the agitator to move it they are worn out cheap to replace
May 14, 2016 | Washing Machines
Agitator won't move
Thes units have litlle plastic dogs that make the agitator agitate, and when they break it will stop.
Remove the agitator and inside there are 3 to 4 plastic dogs or ears and these are more than likely bad.
Pry the agitator cap off by inserting a screwdriver into the cap's notch
2) Pull the inner cap (if present) off - many Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
3) Remove the bolt in the center of the agitator (earlier models used a 7/16" hex-head steel bolt)
On older models, grasp the bottom portion of the agitator and pull the entire assembly out of the washer. (Some recent models allow just the top portion's removal to access these 'dogs')
5) Older models - place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
6) Newer model dogs can be replaced once just the ratchet ***'y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All '4-dog' versions use the 285770 (or #80040) kit, regardless of the cam ***'y style. (Really old agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
7) On older versions, be careful to align the two tabs when inserting the upper ***'y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***'y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
8) Lightly lubricate the agitator cap's rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap's o-ring too - makes it easier to snap into place)dcramer531_112.jpg
Apr 18, 2011 | Kenmore 24042 Top Load Washer
The agitator tries to rotate, but instead jerks, but doesn't rotate in normal motion. It also makes a ratcheting snapping sound.
Does the lower half of the agitator still operate normally? (Back and forth) Can you spin the top half (spiraled part) of the agitator in both directions with out the lower half moving? If so then you have a worn set of agitator "dogs" they are little plastic ears located in the upper half of the agitator and catch the notched inner section of the agitator to make the top action work like a corkscrew, slipping one way and driving the other as the lower half goes back and forth.
To get at these parts you will need to remove the agitator, Remove fabric softener dispenser or cap on top, and look down inside tho opening.
You will need to remove the plastic cover inside that has two ears sticking up, pull on one side or the other and it should pop out, there will be a rubber seal around it so it will be a little difficult to remove.
Now you will have access to the bolt that holds the entire agitator in the machine. The agitator dogs are located right on the outer edge of the center cup that the bolt goes through. To access them you will want to seperate the two halves of the agitator and flip the top half upside down while holding your hand inside it to catch the cup with the dogs in it. Part number 80040, for the dogs.
Good luck to You!!
Jun 26, 2010 | Roper RAS8445KQ Top Load Washer
Hello. We have a Whirlpool Ultimate Care Heavy
yes you r. lol
the agit. dogs need replaced look in your phone book 4 a dealer near you to get this part you need. remove softner despenser and inner cap then you will need to remove bolt 7/16th or 3/8th after removing bolt pull up on agit.it is 2 pc if it all comes out as one pc. ok you need to stand on lower 1/2 and pull up you now have the top pc in your hands. you will see some type of cup that holds in the dogs remove by flipping up side down install new parts and put back togther a small tip use the bolt
to put cup back in when you are ready to put back together put top pc of agit. over cup up side down you will need to line up with 2 or 4 ears on bottom pc. it should click now reinstalle sound hard but very easy just keep preassur on dog cup at all time with bolt and socket have fun
Feb 10, 2010 | Whirlpool Washing Machines
Top half of the agitator does not move during wash cycle. bottom half works OK. 90 series Kenmore. pop the cap off the agitator top, and find 4 cams that come out and touch the geared wheel but do not...
you can replace them ,they are called dog ears, can get from your nearest appliance shop or you can order from Repairclinic.com, not a hard job to replace ,repair kit is about 15.00 bucks
Jan 30, 2010 | Kenmore 23822 Top Load Washer
I have a Whirlpool LSN1000LW0 Washer. How do I separate the agitator to replace the dogs?
remove the fabric softner assemble.if ther is a plastic cover remove it remove 1/2 bolt and reach down under agitator up. put agitator on the floor.put a foot on both side's of the bottom of the agitator.place a hand on both side's of top part of agitator and pull up.turn top agitator upside down and the dog's should come out along with the holder.replace the dog's.to put holder and dog's back in top agitatoruse your 1/2 socket and exstention.place the 1/2 bolt in socket and place holder and dog's on bolt.turn top agitator upside down and feed holder and dog's up in top agitator.holding socket and exstention in top agitator,rotate top agitator down holding dog's and holder in with socket and exstention.place top agitator over bottom agitator and line up the two aliment ear's on bottom agitator and use exstention to push top agitator down on bottom agitator.place agitator back on transmition shaft and replace 1/2 bolt.replace plastic cover and fabric softner assembly.
Nov 15, 2009 | Washing Machines
Need to get the agitator off
that's funny [feed dogs]they are called, dog ears but you do now have to feed the dogs because their not working.lol.hey you will have to get those parts on-line or at an appliance store.lowes wont carry those that i know.anyway if you pop the cap of the agitator you will see a piece that has a small handle.pull up and remove that piece.then you will see the bolt to remove to pull the agaitator[its a 7/16]take a good look at how its together before you take apart.......ok now that the agitator is out place on floor,put feet on the bottom piece and pull up on the top piece til comes off.then dump out the piece in the top w/dog ears in it........install new ears in that piece and reinstall upside down,inthe top piece of the agitator.then apply pressure on the dog ear retainer and place over the bottom piece of the agitate aligning the two little tabs sticking up on the bottom piece of the agitator with the little cut outs in the dog ear retainer....now take your socket to place bolt back on,put some plastic wrapper or package from dogs in the socket and push the bolt into it.then place the bolt in the hole of the dog ear retainer .now lift agitator up and place onto transmission shaft and tighten bolt and place cover back on................boy that was a lot of words.that should do it for you God bless you Tiffany ,from tom
Jan 24, 2009 | GE WBSR3140DW Top Load Washer
Trying to get the cam drive off to replace dog ears
Remove the bolt and get the agitator out the washer.
Set the agitator on the floor,put your feet on the base and yank the top part off. Get a piece of pipe and place the cam with the new dogs on the pipe. Flip the top piece of the agitator over and shove the cam up into the top, then flip it right side up and position it so you can snap it back together . Make sure you don't flatten out the 2 tabs on the base. NOT GOOD. Once you snapped it back together carefully slide it back into postion on the washer spline and take cake not to make it come back apart. Put the blt back and don't overtighten. Comprende? LOL
Jan 07, 2009 | Washing Machines
Agitator disassembly
take the disp out, remove the inter cover, take out the 7/16 screw, pull agit up from bottom to take out of washer, set on floor, put feet on bottom of agit and hold top fins and pull up hard and quick, will come apart, after putting new dogs hold agit upside down to put back together or dogs will keep falling out and put back together / please remember to leave a rating / have a good day.
Nov 27, 2008 | Washing Machines
I have a Roper RAX7245BWO that the top of the agitator is loose and doesn't agitate. I know I need to replace the cam dogs. What I can't figure out is how to get the inner cover (part #20 on the agitator...
Whirlpool LSQ9610L Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
