Question about Boating
I'm trying to wire a 12v bilge manual pump to a
I'm trying to wire a 12v manual bilge pump to a battery using a push button switch. The pump has a black wire and brown (+) wire. The switch has two terminals. Do I run the wires from the pump to the switch, and run separate wires from the battery to the switch, so each switch terminal has 2 wires in it? I'm not using a fuse or float switch. I'm also not running any other accessories on the boat, except electric start.
Thanks for your help,
Dumb
  • 425 Answers
You run your hot wire to the switch (brown) and black wire to the pump (+ve connection). Then from the pump run another wire to the negative terminal of your battery. I used to use a toggle switch on mine, but I do not use a starter motor, still all the lights, radio and echo sounder are connected to it (via a junction box). The only item I fuse is my echo sounder.
Posted on Feb 04, 2010
How Many Watts To Run 15 amps bilge pump
Usually the bilge pump would be a 12V pump. So roughly 175W.
Aug 24, 2014 | Fish
How to wire a 12 volt automatic bilge pump. In a boat.
Hopefully the float switch for the Bilge pump is under the engine not the pump motor. Having an electric motor under an engine is a fire or explosion hazard Find the float switch for the motor and follow the tubing back to the pump. A replacement pump should have instructions. Only the pump intake should be in an explosive environment.
Aug 24, 2014 | Boating
My bilge pump will not work when i push the switch on the dash. It works when it is hooked direct to battery. Why is this
The switch could be defective or there could be a defect in the wiring between the switch and the pump.
Jul 06, 2014 | Cars & Trucks
8501-Dp Battery Switch
can a rule 750 gal. bilge pump be wired directly to the perko 8501 DP Battery selector? Is the common lug negative? Would the #1or #2 lug be on with the switch off?
Aug 30, 2013 | Perko 8501-Dp Battery Switch
I have a 16 ft C Dory that has a Rule-Mate bilge pump. It has never been used. It is connected to a panel by the steering wheel along with other devices (running light, cabin light, etc.) and all have a...
Sounds like the pump is cooked, probably need a new one. Also check the switch on the dash, sounds like it might have failed leading to over running the pump dry, overheating the motor causing a short in the motor somewhere. Boat electrics need regular maintenance, looking behind the panel with some switch cleaner in your hand is a good idea.
Aug 28, 2011 | Rule Mate Fully Automated Bilge Pumps...
Pump is flowing at 1/3 capacity. I replaced the fuse after it blew not it runs buy very slow....I replaced it with the required fuse
the fuse is only a circuit protecter, it will not cause your problem. have you tried replacing filter? check voltage at pump for correct volts. my system has 2 wires, 1 is low speed, 1 is high speed.
Jul 18, 2011 | Attwood Tsunami Cartridge Pumps Tsunami...
Bass tracker fuse descriptions
I was trained at a tracker dealership and that is one of their faults. The best way to find the fuse for the bilge pump is to look on the back of the bilge switch and trace a wire to the fuse panel. Most of the time they are color coordinated so you can match fairly easy without trying to manually probe for the wire.
Jun 10, 2009 | Boating
Wiring on bilge pump
There's an installation manual available online. Black is negative ground; either brown or brown/white will turn on the pump. The intent is for a three way switch, connecting brown/white directly to positive 12 VDC while brown would go through an automatic switch (e.g., a float switch).
Mar 27, 2009 | NRS Kayak Bilge Pump with Float
Boating Logo
210 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
