Question about Microwave Ovens
Microwave quit, now has high pitched 'alarm'' going off
Last night after using microwave, where the clock/'timer display is an''E'' came up. I couldn't get the microwave to do anything. About 30 minutes later the display went blank and there is a loud,high pitched,continuos ''alarm'' that has been on for 24 hours now. I am more worried about turning the alarm off for now, compared to the actual repair of the microwave. This is mounted on top of a stove, in between two countertops and cabinets, so I can't get to the plug.
  • Microwave Ovens Master
  • 12,061 Answers
Can you turn the breaker OFF. or will this affect the other things on that socket?
Posted on Feb 03, 2010
Used the microwave last night. Later I noticed no light display for the clock. Come to find out microwave lost all power. Model number smh9207st
If there are no fuses or circuit breakers, the unit could be down and out. Check you power box for any tripped breakers.
Dec 09, 2014 | In Microwave Ovens
Emerson microwave MW8992SB Just nothing. No clock no light. worked last night.Has electricity to it.
The main fuse has blown inside the microwave, the most common reasons are, one or more of the door switches is defective, the high voltage capacitor has shorted, or possibly the high voltage diode, and sometimes it just the fuse. I recommend a tv tech or appliance repairman because there are dangerous high voltage present.
Jan 17, 2011 | Emerson Microwave Ovens
Hums, does not heat when started. Display, timer,
The problem could be the high voltage fuse or the magnatron assembly. replace both to be safe. good luck.
Nov 12, 2009 | Sharp R-1610 Microwave Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
How to set clock on sharp microwave
normally you look for the clock ot watch icon. Pressing it once will give you the option for 24 hours setting. Press it twice and it will give you the opportunity to set to 12 hours setting. Using the no. keypad, punch in the time and then repress the clock icon again.
Sep 21, 2009 | Sharp R-1480 Microwave Oven
Kenmore built in microwave displaying "D" and wont heat.
"d" may mean demo mode. The first thing to try is a "hard reset". Unplug it from the power outlet for 10 minutes, plug it back in, set the clock, then try again.
Jun 06, 2009 | Kenmore 62622 Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
JennAir Microwave worked one minute then won't the next.
If this microwave is more than a couple of years old, it's possible that the magnetron tube or a rectifier has burned out. You'll probably need to take it to an experience microwave service technician to get a diagnosis.
Jan 16, 2008 | Microwave Ovens
Microwave runs fine - heats nothing
The most common causes for a lack of heating are a bad door switch, a loose connection on the magnetron, a bad magnetron, bad connection on the control circuit board, a bad relay on the board, bad high voltage diode, or bad high voltage transformer. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk We are the ones who repair the displays and control boards, by the way.
Sep 10, 2007 | Sharp R-530ES Microwave Oven
Keypad Problem?
look on the back panel for any hole with a "RESET" label next to it. insert a small pin to reset your microwave
May 25, 2007 | Emerson MW8168B Microwave Oven
Microwave Ovens Logo
78 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
