Question about Car Audio & Video
I tried reseting a Chrysler REC Navigation unit, screen is black
I tried reseting the system of a Chrysler REC navigation unit to allow installation of an older map dvd and now just have a black screen. The radio functions all work still, but I have no display! Help!
SOURCE: How do you remove DVD stuck in navigation system
If you remove the unit from the dash the top, take off the top cover, no screws you can acess the CD slot. Remove the 4 screws holding the CD player in place and the ribbon cable and you should be able to remove the CD from the slot.
Posted on Jan 09, 2008
  • 8 Answers
SOURCE: probleme with rb4 and dvd
The only reason the DVD will not function with the RB4 is if the DVD unit is not talking on the BUS. The RB4 will work with the factory DVD single disc/or DVD changer.Make sure that the BUS is connected to the DVD unit and the Van thru the 22 pin and 10 pin connectors on the back of the radio.
Posted on Jan 09, 2009
  • 5 Answers
SOURCE: gps navigation screen is paralyzed--all other screens are working
hi did you install the software straight to your route 66 maxi using route 66 sync software ? if you did try downloading it to your computer then transfer it on to the memory card using a card reader
Posted on May 01, 2009
  • 30 Answers
SOURCE: Hello. I am considering buying a
The deck is a double din and it will not fit into your dash without extensive modification.
Posted on Oct 10, 2009
kenw392
  • 2226 Answers
SOURCE: i bought a used 2007 escalade that had the battery
try contacting xm.
Posted on Mar 19, 2010
The rec nav radio screen has grey black and white lines and nothing else
If you ever found an answer to your problem I would really appreciate the help. Mine just started doing the same thing today. The screen has lines on it but the sound works fine. 2005 Jeep Grand Cherokee Limited. Thanks
Jul 19, 2010 | 2005 Jeep Grand Cherokee
My car radio Eclipse AVN5435 say (Check map disk )and i lost
my Eclipse AVN5435 is lock is any body know the solution
Apr 11, 2010 | Eclipse AVN5500 Car DVD Player
2007 Honda Civic Navigation Screen went black
Had same problem with 2008 Honda Civic.
Note: you will need anti-theft code so get it first!
Solution:
1. Turn ignition off.
2. Look for fuse box under steering wheel.
3. Remove fuse #35 which is for the Navi-audio unit.
4. Then re-insert the fuse. This will reset the system.
5. Turn ignition on and the Navi-audio on. Buttons WILL be working now.
6. The unit will request for the anti-theft code for Navi-audio system. Enter the 4 digit code....Yippee!
However, I lost all my radio preset stations. Thankfully my saved destinations in navigation system were intact.
Apr 02, 2009 | BoxWave Corporation 2007 Honda Civic...
Lost maps by updating
Unit comes with pre-loaded maps. Why update? Maps on DVD is the same copy as it's on the unit.
If you have troubles make sure you're not in Navigation mode when running the update. Update does not like files still in use.
Mar 23, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
2006 REC navigation radio (screen goes blank)
The same thing happens with my 2005 Jeep.
Feb 27, 2009 | 2006 Dodge Ram 1500
Sanyo nvm 4050 problem
I ended up in the same situation and called (800) 421-5013 for help. The gentelman who assisted me said that how the DVD holds the same data as factory Sanyo 4050 GPS and upgrading has locked your device. To resolve the discussed issue one have to delete everything (plug-in your device via USB cable --> My Computer --> Removable disk) and install fresh copy onto your navigation device via that DVD.
Tried it with NO @!@ JOY
Nov 16, 2008 | Sanyo NVM-4050 GPS Receiver
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
Oct 07, 2008 | 2007 GMC Acadia SLE
Eclipse AVN-5435
for avn 5435 on the left:press menu and cont ant the same time, while holding them down press menu on the right 5 times
a menu will appear and ask you for a code. you have to call 800-233-2216 and pay $25 for the code. you will have to explain where you bought your eclipse and or know the name of the original owner. if it doesnt match they will not give it to you
Dec 07, 2007 | Eclipse AVN5500 Car DVD Player
Car Audio & Video Logo
428 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
