Question about Zoom Music
Power will not go on after machine was dropped. Plastic was broken broken on the top of the device near the power connection but the circuit board appears to be undamaged.
    President:
  • 2,992 Answers
The board may appear undamaged, but the instrument's behavior says something is broken. I have no idea what kind of musical instrument this is, but circuit boards are all the same.
Especially on boards with narrow circuit traces and surface mount parts, damage can be very hard to see. A trace might have a hairline break which would be impossible to see without bright light, strong magnification, and some idea where to look.
It's also possible that the board is fine, but some part has been damaged. The lead from some part may have broken away from the circuit trace, for example. Or a small surface-mounted component may have popped off completely or had a lead broken off.
Unfortunately, this kind of trouble is very hard to fix without detailed product information (circuit diagrams and board layout). Unless the manufacturer makes a service manual available to the general public, this means sending the unit back to them or an authorized service center for repair.
Posted on Feb 03, 2010
Why lower keys dont come on , on a kimball model 700-775
I think you are speaking of an organ.
Your organ has electronics inside it, and I believe the circuit board for the lower keys has a broken connection.
You should find an electronic organ repair place.
I just looked online and found several places.
Since you may be near to none of these, relay on your computer to find someone who can repair this circuit board.
They will have to tell you how to take it out of your unit.
God bless your efforts.
Feb 24, 2017 | Music
I have a behringer pmp3000 which has stopped working on channel A. I know what the problem is and have sourced a replacement board. Is it still possible to use it as a mixer if the amp section is...
What is the source of the HCA2400 module? Be very careful if you disconnect the power supply 70 volt cables to discharge the caps before connecting new amp module otherwise you will do some welding with the arc that occurs. You could run the unit with the 70 volt cables pulled at the power supply... leave the other little cables in place. Also be sure to read my tip on Fixya regarding the Channel A hazard with speaker cables. I received an HCA2400 replacement that was wrapped in pink bubble so tight that 5 small electrolytic caps near the audio input cables were broken loose destroying the circuit board. Be sure and check your replacement in this area for damage due to improper shipment. I have repaired some of the HCA2400 that burned up channel A... it is a lot of work to grind out the damaged board and re-insulate and restore circuits with jumpers.
Aug 23, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
My OS-2 Distortion pedal will not work. There is current flowing to the battery terminal, there is also contact noise in the output, but none in the input. The red light does not come on when powered and...
Common problem is a broken solder connection where power jack is attached to the circuit board. SOmetimes the circuit board is cracked or solder broken. If board is cracked, jumpers need to be soldlered on to bridge the crack.
May 07, 2011 | Roland Boss OS-2 Overdrive / Distortion...
I recently got a Marshall mg100hdfx head for free because it wont turn on, so I am investigating possible parts that may need replacing. The only description I got as to why it wont turn on anymore is...
You may find almost anything in this. I think the power amp is on a separate board so the connections to that might have been broken. Possibility include cracks in the circuit board. First thing is to do after visual check is to check power supply voltages to verify power switch/fuse/transformer/rectifier/capacitor/regulator health. Switches are sometimes damaged... and also wires can fall of or break.
May 02, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
When I use the Master volume the amp will suddenly bypass the master volume. And when I play on the top boost the volume fluctuates by itself. Thanks for your help Devon
I suspect you may have either a circuit board crack or the volume pot is bad or soldering of it is bad. Vibration will make things come and go. Look for broken solder around the pot leads first. Then look for a cracked circuit trace on the board near the ground end of the volume pot. If you put cleaner in the pots NEVER use Deoxit or Blue Shower. Use CRC226 which is available at Home Depot in the electrical dept.
Apr 29, 2011 | VOX AC30HWHD Amp Head
Device powers on and goes through startup but no light. lamp is new. scanner moves but no light
Yep... I got one on the bench and also another I have just fixed. The one that is still sick has a lamp power supply that is inoperative. There are two supplies in this unit. One powers the electronics and the motors, the other the lamp. The lamp one is mounted bottom side under the lamp. I have partially traced out the circuit and I am trying to analyze it. It appears to have two transistors that drive the step down transformer that generates the 24 volts for the lamp. It appears they MAY use a Diac as a relaxation oscillator driving the bases of the large switching transistors. The circuit is fairly simple and has a small transformer for driving the bases as well as the larger output transformer. This supply operates directly off the line input so one needs to use an isolation transformer for personal safety when troubleshooting. I suspect the Diac might be gone in mine. The one I just fixed had been dropped and the plastic standoffs for BOTH power supplies were broken. The smaller supply on the one I repaired had the power transistors fracturing the circuit traces they were attached to so supply would not operate. Jumpering the breaks fixed the problem. Also on that one the audio sensitivity pot was smashed. Replaced that. I will be working on the one with the bad 24 volt lamp power supply again. In the meantime, see if on yours the ONLY problem MIGHT be the big power transistor leads have broken loose from the circuit board
The supply is mounted on three standoff plastic pins to the cover with the grill punching on the back side. Remove BOTH long side aluminum extrusions (8 screws +1 more) to free the long plate with the supply on it. Chauvet STUPIDLY have the heatsink aluminum dangling by the two power transistors so bumps flex the transistors... you will see it when you open it... You can contact me as fredy2 at the AOL.com.
Apr 27, 2011 | Chauvet Dmx-600 Intimidator 1.0 Color...
Korg Wavestation EX LCD Screen Info disappears!
This is characteristic of a poor contact someplace within the unit NEAR the connections for the display. It may also be a bad plated-thru-hole in the circuit board. This problem could also be on the display circuit board itself. They often have a complete microprocessor right on the display itself.
The vibration from the keys causes the connection to break, and the re-cycling of the power sends enough of a pulse to break down the oxide at the poor connection.
These can sometimes be found with freeze spray circuit cooler and often by applying gentle pressure at suspect points on the boards and looking for changes.
It for certain is a get out and get under repair involving taking out a lot of case screws and VERY careful handling of the cables within the unit.
Feb 24, 2010 | Music
Have a crate limo tx50 d some times the effects stop working and or get a buzz from the unit
An educated guess is that you have a cracked circuit board or a bad solder joint. OFTEN the boards crack or traces get lifted or solder broken near pots such as volume control, etc.
Another place to look is the connections where jacks are soldered... those are chronic failure points.
One other problem is the bypass switches on the effect insert jacks. The contacts of the switch part of the jack get oxidized or bent.
Feb 16, 2010 | Music
My amp fell forward and the (knob side) hit the ground. Now there is no sound, but everything lights up.
You have probably broken some of the pots. You will need to take it in to be serviced or if you have experience take the amp apart and take the circuit board out. Examine the solder side where the control pots are. Hopefully you didn't break the pots themselves and the solder joints just need to be redone. Also look for broken traces near the pots. They look like little roads which they are for electrons.If they are broken you can bridge them with short pieces of tinned wire and if the circuit board is cracked it can be Crazy glued. Look for all the broken parts and don't miss any. If the pots are broken, Take the broken ones into an electronics supplier and ask for exact replacements. If its a tube amp look for tubes that are loose in their sockets and broken tubes. Absolutely do not work on the amp with it plugged in to the wall (no power running to it) If its anything worse than that, take it in to be repaired as you need schematics, test equipment and direct replacement parts to do a proper job. Hope this helps.
Aug 27, 2009 | Music
DTXPlorer
You can replace the battery yourself in about 20 minutes. It is not soldered. You will need a replacement battery, which is a CR2032 watch battery, a small Philips screwdriver, and needle or thin-nosed pliers.
1. Remove all cables from the dtxplorer unit, and remove it from the drum kit rack.
2. Remove all 6 screws from the bottom side (i.e. opposite the face)
3. Remove the 3 lowest screws from the rear (jack-filled) side, including the one which holds in the little plastic power cord hook, then lift off the bottom and set aside.
4. You will see the bottom circuit board, covering the top board. Carefully pull off the spade connectors from the power switch, using pliers or patient wiggling, they are on fairly tight but will come loose. Note which one is which for proper reattachment.
5. Near the center of the board is a little white plastic post end sticking up, through a hole, from the inside (top) board, with small tabs. This loosely attaches the two boards. Using small pliers, squeeze the tabs on the post end, and pull up on the board and it will separate from the inside (top) board. Carefully move the board toward the front of the unit to free the jacks from the holes in the case, and then you can easily fold the board toward the front, like opening a book. (Don't try and remove the large wire sets attaching the two boards)
6. You will see the button-like battery. Just push it toward the spring clips at one side and lift it out. Replace it with the new battery, + side out.
7. Just reverse the steps to reassemble, hook it up and you're ready to go. Easier to do than this makes it seem. Greg
Sep 03, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Music Logo
209 people viewed this question
Top Zoom Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Barry Webster
Level 1 Expert
Are you a Zoom Music Expert? Answer questions, earn points and help others
