Question about E-Machines T6216 (827103077834) PC Desktop
Onboard video works fine but when I install a pci express card the video is garbled. The card checks out good on a different machine.
  • 600 Answers
You need to unstill the intergrated vga port via the BIOS or disable the device via the device manager, install the new driver first the install the pci card
Posted on Feb 03, 2010
Use of PCI-e x16 slot for non-video card
...........................................!O_O!...........................................................
WHY would you want to do that?
There is a PCI-Express x1 slot on the motherboard.
Black in color, and in-between the black PCI-Express x16 slot, and a white PCI slot.
Use the PCI-E x1 RAID adapter card in the PCI-E x1 slot, and a PCI-Express graphics card in the PCI-E x16 slot. Sheesh!
A PCI-Express slot is not an evolved PCI slot.
Completely different technologies.
PCI uses a shared Parallel bus architecture, while PCI-Express is based on Serial point-to-point.
So your idea of how to 'fix' your problem, is to use a PCI-E x1 card in a PCI-Express x16 slot, and a PCI graphics card in a PCI slot?
Completely backwards.
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
PCI-Express x16 slot uses the same lanes from the Northbridge, as the OnBoard video?
UTTER NONSENSE!
The Northbridge chip handles the Faster capabilities of a computer.
Handles the Processor, Ram Memory, and HIGH-SPEED Graphics.
HIGH-SPEED graphics is the Accelerated Graphics Port (AGP) technology, and the PCI-Express technology.
The Southbridge chip handles the Slower capabilities of a computer.
The PCI bus is one of those slower capabilities handled by the Southbridge chip.
The PCI bus is also a shared bus. This slows data down.
The AGP bus, and PCI-Express bus are Not shared. They also have a direct link to the Northbridge chip.
The PCI Bus has to go through the Southbridge chip, which has to go through the Internal Bus, THEN to the Northbridge chip.
OnBoard video, or Integrated Graphics, uses the PCI bus.
When you inserted the PCI-E x1 RAID card in the PCI-Express x16 slot, and a PCI graphics card in the PCI slot, BIOS just assigned another IRQ for the PCI-Express x16 slot.
(Interrupt Request)
No fancy technology going on there.
Backwards technology going on with a PCI-Express x1 card in a PCI-Express x16 slot, though.
I do not concur, and do not think that is a good solution, Kevin.
Regards,
joecoolvette
Aug 24, 2012 | Gateway Foxconn C51GU01 Motherboard
I have a asus p5g41-mlx3 mobo and i'm trying to install a palit 8400+ 1gb video card, but after installing and starting up my pc i get a blank screen. if i take out the card my computer works fine....
Check if it a jumper to disable the onboard video. If not, try disabling the onboard video in BIOS or selecting the option in BIOS to use a plugin card rather than onboard.
Where do you have your video cable plugged in? With the new graphics card installed, do you have video out of either connector?
Jim
Preston Computer Services
www.prestoncomputerservice.com
Jun 03, 2011 | Palit Microsystems GeForce 8400GS,, PCI...
MS-7207 K8NGM2-H MOTHERBOARD Model:K8NGM2 -H E machines T6528 no video will display tried PCI -express video card and still no display. Monitor tested on other pc and works fine
If you are using a PCI-e video card, you will need to install a driver. If you have onboard video on your motherboard and that isn't working, I would say that your motherboard is fried and you need a new one or a new machine.
Jul 18, 2010 | E-Machines Computers & Internet
PCI Express slot not working
go into the bios and change the video settings from onboard video to pcie video
Mar 27, 2009 | Gateway GT5082 PC Desktop
HP a1712n How to troubleshoot MOB problem?
you can consider 4 factor on no video,it maybe video card or memory card,processor last mother board this if PSU was good,you also check memory card to other computer,somerime need only to clean terminal slot of memory by pencil eraser,eraser slot then put it back,also video card same process in cleaning try also to other computer.Instale good memory card and good video card even with out hard drive,cd room the mother board.if does not run,defective motherboard,
Mar 16, 2009 | HP Pavilion a705w PC Desktop
Onboard video has went out
no video to either
no have not been in the bios
Sep 24, 2008 | E-Machines etower 667ir PC Desktop
Can I install a PCI video card on my D915GAG?
Are you sure it's a PCI slot you are putting it into, and not a PCIe slot? If so, check your BIOS is set to allow PCI graphics.
May 26, 2008 | Intel D915GAG Socket 775 Motherboard -...
Video card for the gateway 507gr
Yes, your computer specifically supports:
PCI Express 16x and
PCI Express 1x
The 16x is the long one and the 1x is the reallly short one. Most likely the card that you get will fit the big slot. Be careful not to upgrade too high though, because if you do you may have to upgrade your power supply as well. Ask someone at gateway or a local shop for a recommended card for your system.
Apr 23, 2008 | Gateway 507GR PC Desktop
PCI-express won't come up.
BIOS Setup Utility; go to Advance Chipset Features
PEG Port is your PCI-EXPRESS…Enable/Disable
Nov 10, 2007 | EliteGroup 915G-M Motherboard
E-Machines T6216 (827103077834) PC Desktop Logo
123 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
