Question about GE Spectra JBP78 Electric Kitchen Range
Oven partially heats - GE Spectra JBP78 Electric Kitchen Range
  • GE Master
  • 43,501 Answers
If your electricOven partially heats - 2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 15, 2010
My AEG induction oven is suddenly blowing the fuse - both ovens do it. Is it still the element, do you think? Thanks
Check the power cord to the oven, follow it inside and see if might be heat damaged or otherwise shorted, this means partial disassembly of the oven cabinet.
Nov 29, 2016 | AEG Ovens
I have a jenn aire JGR8875RDB oven. The control panel is partially out. The numbers beep. The clock displays and all the oven controls do NOT work.
Go to the power panel of your home and locate the circuit breaker for the oven. Turn this breaker on and off several times then check the oven controls. If this restores normal operation, then I would replace the breaker. If the breaker trips instantly every time you try to reset it then suspect the heating element and the thermostat. When a heating element shorts, it can ruin the contacts inside the thermostat.
Aug 07, 2016 | Ovens
Mer5755 Oven losses temp. Start at 400 loses temp later
The problem is usually the ignitor not reaching the correct amp draw .When the ignitor does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The ignitor are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available.
Apr 02, 2010 | Maytag MER5755Q CleanDesign Electric...
The glass panel on the inside of my oven door has fallen out. Also, the oven takes ages to heat and it's almost impossible to roast potatoes........just does not get hot enough. This is a separate problem...
I know that you state the oven not heating up properly pre-dates the problem with the door. However I would recommend that your replace that sheet of glass as a partial oven door will impact the performance of your cooker. Here's our guide to fixing up an oven door:
If the oven is still taking forever to heat up most likely it's a problem with the thermostat or the element. You should check them both for continuity (with the cooker uplugged) and do a visual assessment for any loose wiring that could be contributing to the issue.
Jan 26, 2010 | Britannia SI10T6L Dual Fuel (Electric and...
Viking oven not heating past 150 degrees
My viking oven had same issue - I needed to replace the ceramic ignitors (if ignitors fail to heat up properly the gas valve remains partially closed). Apparently they are intended to be replaced every 3-5 years. Also inspect and clean the oven burners - mine had corroded somewhat and prevented the flame from 'moving' to the opposite side - ie only half the burner was lighting. If you are handy the ignitors are very easy to replace - one screw, two wires each.
Jan 02, 2010 | Viking VDSC365-6B Dual Fuel (Electric and...
Oven door not sealing properly and heat escaping
Check the hinges at the bottom corners to see if the spring is still connected and see if the hinge is wore out. The door lifts off the hinge when it's in the partially open position after loosening the screw holding the door in position on the hinge. Slide the oven out a little to access the hinge to replace or inspect.
Jan 01, 2010 | Neff U1421 Double circotherm Electric Oven
Oven and broiler: no heat
Flipped the breaker switch! Although we had looked at the breaker first thing, and it was not flipped off, plus everything else on the range was working: we found out it is actually a double breaker, with one half controlling just the oven, and it can be just partially flipped and you don't notice it. So as soon as you toggle it off and on again, you are back in full power.
Apr 08, 2009 | Kenmore Kitchen Ranges
SMEG SUK62 MFX
check stat is not open circuit and check selector switch not damaged
Oct 18, 2008 | Smeg SE250XUK Stainless Steel Electric...
Gas oven won't heat
You most likely have a defective oven bake ignitor.  Call an experienced tecnician.
Oct 09, 2007 | Ovens
GE Spectra JBP78 Electric Kitchen Range Logo
228 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
