Question about Toshiba 35A44 35" TV
Speakers in a toshiba 35 tube blown
Will a surround sound override this issue
    Welcome Back:
    Visited the website for 2 consecutive days.
I spent hte whole day moving my girlfriend and the only thing I got out of it was a TV with no sound coming out of it. I turned the speakers "on" in the menu screen, then i used the speaker output of the tv to a stereo or a couple of cheap speakers. Or connect 1 speaker and set the tv to mono. Hopefully your tv has some form of audio out besides the built in speakers. Good Luck
CN
Posted on Mar 31, 2008
JVC has background sound but no voice
i would recon that is an issue with the sound settings,or maybe 1 speaker is blown?
you can change the sound to personalize the way you wish the sound to be,can you reset this to default?
listen if sound i coming out both speakers,also do you have surround sound? check all your settings
Mar 16, 2013 | JVC LT-42X579 42 in. LCD TV
I have a pioneer vsx 818 v amp, when I set it up we get noise / beeps etc from the surround sound speakers but then when playing a film in 5.1 we get no sound from the surround speaks ..driving me nuts !...
To get sound out of your surround speakers, first off go through the receiver setup and make sure that is correct. Also, usually the best soundfields to use for sourround sound is PLII Movie or dolby digital. Next , make sure the source you are viewing is capable of outputting 5.1 sourround sound. Lastly, it is a good thing to remember that sourround speakers are only intended to reproduce sound effects. You certainly can override it so that all speakers play full range audio, but that is not the intention.
Good Luck
Jan 07, 2011 | Pioneer VSX-818V-K Receiver
My subs sound choppy
Sounds like your sub is "clipping". Clipping is when your speaker is trying to pull more power than the power supply. (head unit, amp) If it sounds good at a low volume and choppy at high volume, supply it with more power. Bigger amp. If it sounds choppy all the time, push gently on the middle of the speaker. It should go back and forth smoothly. If it feels rough, you have blown the coil. Replacing the speaker is the fix for that.
Apr 14, 2010 | Sony Xplode P5 Turbo Subwoofers Car...
One Connector not working on Durabrand SA-SP9 Surround Sound
you have to test electrical out put, maybe loose wire inside or blown component
Jul 06, 2009 | Durabrand 5.1 Surround Sound Computer...
Flatline!
the vertical drive ic that drives the yoke for vertical sweep has blown.
sometimes it is solder problems like sharp and toshiba had.
the part is 10$ the pc board will label it ,the yoke is the coil setup on the picture tube.if you follow the wiring half goes to the horizontal drive,and the others to the vertical section.the chip drives the coil directly.there are VERY high voltages in there ,even turned off. the pix tube cap on top is 30000v. like a stun gun.the horizontal drive 2000 volts and the main power supply 165 volts dc high current.you need a special setup to discharge the picture tube.
May 15, 2009 | Mitsubishi CK-35308 35" TV
I need help with my surround sound!!
The calibration mic thing is to balance the sound evenly on surround sound systems, it replacles the older systems "TEST TONE" speaker setup, in other words it will balance each speaker say in a 5.1 setup to adjust the level output so the listening position is not overwhemled by say the rear surround speaker overriding the front left & right speaker or the most critical the center speaker. The calibration mic uses computer tech to make it easier for the user, no sound pressure calibration is needed as with the test tone setup mentioned earlier. The wireless speaker situation could be possibly waiting for the calibration confirmation, Read any user manual information if available.
Jan 25, 2009 | Sony DAV-DZ100 System
Onkyo TX-SR805 - surround sound problem
The speaker impedance is not the problem.
Apr 09, 2017 | Onkyo TX-SR803 Receiver
No sound coming out of z-5500
To troubleshoot a speaker system where sound is not issuing from all speakers, please do the following:
  1. Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the source selector switch or the M3D button on the controller unit (if available). You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  3. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  4. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Try these articles as well:
Manual
Setting up the Z5500 with PC, Mac, Xbox, Playstation, DVD Player, etc.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 24, 2008 | Logitech Z-5500 Computer Speakers
Surround sound
adding more speakers in parallel reduces the impedance, causing the amp to work harder. if you reduce the impedance to much and turn the volume up its a bit like making a short across the output, and has probably damaged the output stage. if you are really lucky it may be fused and simple replacement will fix the issue. if not it could be a costly repair. always observe the minimum impedance rating on your amp and match the speakers to it, never less than it
Sep 02, 2007 | Samsung HT-Z310T Theater System
Possible Blown Speakers?
Any speaker, if abused, can be blown. And if overdriven with dirty power at extreme levels it is not uncommon to burn out the voice coil. You might also want to check out the speaker surrounds. If they go, the speaker works but sounds lousy.
Localize the problem by hooking up two known good working speakers and see what happens. If they also do not work properly or sound like cr-p then the radio is at issue.
Jul 24, 2017 | JBL - MR4W Am/Fm with CD Player White
Toshiba 35A44 35" TV Logo
135 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
