Question about Roper Dryers
Dryer suddenly shut off mid cycle, had heat, just
Suddenly shut off mid cycle, had heat, just stopped tumbling and will not work since
Check the belt around the drum
Posted on Feb 03, 2010
GE spacemaker electric dryer PCKS443EBWW. Dryer shuts off mid cycle on timed dry setting. Wait till cool down and will start again. Venting is clear, I vacuumed inside and around motor. Any ideas?!
Mark, Could be limit /over heat/thermal fuse/switch, check or have checked by a good repair Tech., diagnosed and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What to Check when your Dryer Shuts Off Mid Cycle
Whirlpool Maytag Dryer Diagnostic Shuts off mid cycle not heating...
Kenmore Whirlpool Clothes Dryer Repair The Most Common Problem
GE electric dryer overheating shutting down
Jul 10, 2016 | GE Dryers
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
Dryer that wont stop tumbling
Well we know the door switch is functioning properly so that usually just leave a timer issue.
Dec 05, 2014 | Dryers
Ge front loader dcvh515efoww - dryer shuts off when put on heating cycle
Did you pull the dryer out or forward sounds like you may have pinched the exhaust which restricts air flow exiting the unit this will cause it to heat briefly shut down heat shut down and continue this cycle the fact that it worked before makes me think it something simple it will not tumble in any cycle if door switch not installed correctly.
Mar 21, 2014 | GE Dryers
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
Dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Jul 28, 2009 | Kenmore 73952 Gas Dryer
My dryer has been difficult to start lately especially if stopped mid cycle. The lights are all on but it won't start up. Today I only used it 2 times and it was very difficult to start after pressing many...
You may be experiencing "Heat Retention" by stopping your dryer mid-cycle, which you should NOT ever have to do! If you have a minor vent restriction or if you open the dryer mid-cycle when the heat is on, this will cause a disruption in the airflow and rising temperatures can keep the dryer from restarting until it has been cooled long enough.
Check your vent all the way to the outside for restrictions/obstructions every 6 months. Clean your lint filter after each load and DO NOT stop the dryer mid-cycle!
Note: Stopping the dryer mid-cycle can also cause severe burns and even melt polyester fibers.
Jul 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
188 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
