Question about Linksys WRT54G2 Wireless Router
I have a Linksys WRT54G2 router set up at my house. My computer detects it but for some reason I can't connect to the Internet. I can get on my router's page, but the wireless network just won't work. When I click "diagnose and repair," the same error message keeps coming up: "There may be a problem with DNS configuration..." In the router page under "Status" and "Router," the IP address, subnet mask, and default gateway are all zeros. There isn't even any text for DNS 1, 2, or 3. If it makes a difference, I'm running under Vista. Now, I have the same problem as before where I hook the router up (even my iPod detects the wireless network), but there is no internet connection. The desktop I have the router connected to has internet access, but I can't get to the router page. Under ipconfig in cmd, it says that the IP address is 24.63.15.90, and when I type it into the address bar it doesn't work. In Network and Sharing center, under manage devices, the WRT54G2 doesn't even show up.
  • 19,396 Answers
24.63.15.90 is not the router address, but a random IP assigned by computer DHCP itself, as the router had been unable to assign IPs in range.
Check the ethernet cable, if you have a spare one, replace it.
Disconnect power cord (turning off is not enough) from both router and PC. Restart router first and PC afterward.
Disconnect ethernet cable from router , then go to installed devices and remove the ethernet card on PC from the list. Reinstall the ethernet card.
If still no luck, then the router may be faulty. In that case the first step in troubleshooting will be using the pinhole button to reset the router.
After resetting, check if the router is giving out correct IP. If it is, all the broadband settings will need to be entered again. In that case the best thing to do is calling the Internet Provider to get the setting at phone.
Posted on Feb 03, 2010
  • Ginko
    Ginko Feb 03, 2010
    I wanted to add, that as a first thing you should check the lights on the router.
    If router WAN and Internet lights are on and steady , and the LAN led is off, then you need to replace or connect properly the LAN cable, or check the ethernet card on computer.
    If router has only one blinking light, or lights are not behaving normally, then the router may be in fault mode.
My WRT54G2 will not connect to the internet I am using another router also
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Aug 18, 2010 | Linksys WRT54G2 Wireless Router
Linksys WRT54G2 Wireless router unable to connect to Internet
Try again by Disabling the WEP (or WPA), MAC Address Filtering and Firewall Setting Individually. Should be a problem with one of those. Then when you receive the Signals, try to Adjust using Bottom Up method. That means one setting at a time, Hardening the Security. Have you checked your DNS settings? Have you checked the Channels you are using? Re check them and try again.
Feel free to contact back.
Please rate the answer if it helps you to solve the issue.
Thanks for contacting Fixya!
Jun 12, 2010 | Linksys WRT54G2 Wireless Router
Problems with WRT54G2 and DNS
If there is only zero on the ip add, sub mask etc then it would never work.Make sure your router is connected to a modem and that the latter can be hooked directly to a pc with cable and test if there is an internet connection. If there is a connection go back to your pc and connect to your wireless.Then go to start>cmd, a black screen would appear and type the following : ipconfig /iprenew .Then afterward type ipconfig and see if the zeros' you mentioned earlier changes to a value to the format of x.x.x.x .This should solve your problem.
Feb 02, 2010 | Linksys WRT54G2 Wireless Router
How to find security code for linksys WRT54G2 to
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here
for step by step Instructions on how to find the network key
Jan 28, 2010 | Linksys WRT54G2 Wireless Router
My WRT54G2 V1 is having connecting to my internet
Are you trying to install the router.
You can do it manually without the CD.
MAke sure that your computer is able to go online through the modem.
Then you need to connect the computer to the router ad the modem to the router.
Click Here for step by step by instructions
Jan 16, 2010 | Linksys Wireless-G Broadband Router
I bought WRT54G2 router , but could not detect the broadband connection ,,,
do you have the broadband modem plugged into the wan on the router and is the cable you are using good. and also check to see if your internet is working. you should be able to connect your computer to the modem and get internet. if your broad band requires you to log on the modem before you get out you will need to connect directly to your router and set it up per the instructions.
Dec 24, 2009 | Linksys Wireless-G WRT54G Router
Internet lose on my wrt54g2
please reset the router
configure the router type ip address on the browser
may be 192.168.1.1
Oct 29, 2009 | Linksys WRT54G2 Wireless Router
I have good internet signal from cable modem and laptop detects router at 46 Mbps but can't access internet wirelessly
  • Is your computer connected to the wireless router
  • If you are able to see the router, maybe you need a security code to access it.
  • disable and enable your wireless on your computer.
Do hope 1 of the above helps.
Aug 15, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Setup linksys wrt54g2 broadband router with prolink h9200 modem
You probably will need to make some configuration changes in the Linksys router, or in your computer, or both. Your are correct that you connect the Linksys WAN connection to the LAN connection of the modem. If your connection type is PPPOE, you will need to set that up in the Linksys with the username and password provided by your ISP, so the modem will allow you to login and connect to the internet. If that is how you were connecting to the modem with your computer, you will need to configure a new LAN connection in the computer in order to connect to the Linksys. You can then configure the Linksys through your web browser to connect to the modem.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 27, 2008 | Linksys Wireless-G WRT54G Router
Linksys WRT54G2 Wireless Router Logo
110 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
