Question about Westinghouse Electric L1916HW 19" Monitor
My montior turns on for a few seconds then the screen goes black. if i hit the pwr button it just repeats the process
  • robert_ajc May 11, 2010
    Is the monitorplugged into the PC power supply or the mains electricity supply?
    Scholar:
  • 34 Answers
If you put bright light at an angle close to lcd can you see a windows shadow, text icons etc, ie still logic power passing,then .... (from a.n. other) after two weeks searching I finally find doctor living stone http://www.aplusperfect.com/articles/lcd_capacitor_repair more fun with paulbtorrent
the takening the case bit off is like opening your wallet a second time after buying a new LCD, but you must! smallest two screw driver's flat headed, practice using two pennies stuck together()with your fingers after, one little () move and inch and {} again, with the case , it does not break, just need to lever open
[once open you realize they somehow put that old briefcase clip inside!] also note the bright light test to do first to see if can see a windows screen , and that capacitors are one for a number of things that a make a inverter work! there a transistors as well, given that however, to replace all the capacitors on my inverter, was 11 capacitors, cost me $11 (uk ebay) and already had the iron and solder. So only cost me me $11 to try and see but no luck , still fun and I still can see the screen for 2 sec' at a time plus I have a spare set of caps now in the event that the new
one do go burst! you have to laugh really, what next , a new on/off
button, as you work though the whole inverter !
mmmMMMMmmmMMMMmmmMMMMTim Berners-leeMMMMMmmmmMMMMMmmmmcome back all is not
wellMMMMMMMMMMnnnnnnweek later land sight mmmmmMMMMMMMMMmmmmgggggggg(from
another a.n other)Generally, if the screen went out quickly, it was the inverter. If it went out over a slow period of time (flickering etc..) I would bet it is the lamp.replaceing the lamp should be pretty challenging. as that requires complete breakdown of your LCD, extraction of your dead lamp, and soldering in your new lamp... but I would like to say that I it did this after realizing it's 2 x kitchen strips inside [========] with wires that can connect back to the inverter with out any desoldering(ie kit assembly/dis) with the outter case remove (glass plate safe away) I could reconnect and see that 3/4 were working (i!i hardcard ) cause the inverter to switch off after a secound ! order bult and replace and going to cheap and see if I can get away with fitting a 15" in my 19' as it a 1/3 of the price ! the market as drop out there, hope the inverter does not miss the length, or the screen out put.
Posted on Feb 08, 2010
  • 11,361 Answers
First place to check will be the power supply section, look for bad caps first, report back what you see so we can guide you further, see example of failed monitor due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 04, 2010
My kindle fire will not stay turned on! When i hit the on button it seems like its going to go but then the screen goes blank!
Did you try with power plug on ? If ok, the battery is gone. If not, try restarting (keep POWER button pressed several seconds and after few seconds press once). If you see the logo on screen and then black, look in a very dark room to adjust luminosity setting.
Sep 10, 2017 | Tablets & eReaders
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
Hp pavilion dv4 black screen
have some experience as a technician, able to replace the keyboard and palm rest of your laptop.
if it is not able to look for someone who will be able to do
Jan 27, 2014 | Computers & Internet
Montior goes black i turn off the monitor and turn it back on i can do about 2 things and screen goes black again repeat this as many times as i want. Gateway FHX2300 monitor
My monitor has been switching connections on me randomly. Hit the menu button. The one to the left of the power butter when facing the screen. Hit the left arrow twice then hit the menu button again. This will open up the screen where you can choose one of three inputs. I'm going to assume that it is on the incorrect input so use the arrow keys highlight what input you are using and the hit menu button again and your screen should return to normal. Mine only does this randomly when it goes into screen saver, hibernate or sleep. I don't know how to permanently get it to stop doing it though.
Aug 23, 2010 | Gateway FHX2300 LCD TV
Power Problem
Same problem as sweetpetny...blinking power button, won't on.
Jul 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
Screen goes off after a few seconds
The red tube is going out. I have the same problem with my Blue tube. If you get rid of your TV I will buy your blue tube.......
Jun 17, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Jun 05, 2008 | Sharp Aquos LC-32D40U Television
Black screen
Yes, it could be stuck in hybernation
Or.. Check to See if the Lid Switch is Stuck Down... Some laptops have alittle Movable plastic pin that depresses when the lid is closed to turn the screen off... this can sometimes get stuck down to the board button.. causing the symptoms youre experiencing
Jun 04, 2008 | Toshiba Satellite A105 Notebook
Screen turns black
problem with the inverter chek it
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Westinghouse Electric L1916HW 19" Monitor Logo
361 people viewed this question
Top Westinghouse Electric Computers & Internet Experts
greg benton
pankaj rautela
pankaj rautela
Vernon Taylor
Are you a Westinghouse Electric Computer and Internet Expert? Answer questions, earn points and help others
