Question about Pintoy Digger Construction Vehicle
Kubota kx36-2 and hydraulic problem please help or I my fire it,
Hi have a problem, I have got a kubota kx36-2 and some one tried to fire it, so I have replaced all the hoses and the wiring and sand blasted it back it rear metal, and painted it, but when I fill it with oil and bleed the air out I have no movement on the leavers, the tracks work and 3rd service but none of the low pressure stuff works ie arms buckets, can anyone help, thanks
This is Kubota L4150DT tractor. the Brakes are wet brakes. that need replaced. could I please get a free PDF repair manual. that shows how to replace the wet brakes.thanks
Hi Simon I googled (user manual for kubota l4150dt) and got this links below, The manual you're looking for ranges in price from $9.95 to $95.00 I didn't see any free downloads, I also noticed the manual you're looking for has 4 model number in it L3350, L3750, L4150, L4150-n... Hope you find what you're looking for..CHEERS..
https://www.google.com.au/search?q=Kubota+L4150DT+tractor&oq=Kubota+L4150DT+tractor&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8#q=user+manual+for+Kubota+L4150DT+tractor&start=0
Mar 25, 2016 | Kubota Garden
Need wiring diagram for Kubota t1770
check grounds first & then have starter & battery tested
Oct 27, 2014 | Cars & Trucks
Do you have an operating manual for a Cyclone Blaster PT 100
try placing a rag over the tip and hitting the trigger, this will back flush the hose and get the sand flowing again. it's just something you need to do on these
Aug 19, 2014 | Pool & Spa
Do you have free manuals of Kubota mowers?
Try requesting manuals directly from Kubota.
Jul 16, 2014 | Kubota Garden
IF code
if wired 120 volt reverse wires
Nov 14, 2011 | Hayward H400FDN Low NOx Natural Gas Pool...
I have a PORTER CABLE CP2600P 135 Psi 6 Gal Pancake Compressor and I have no idea how to use it. I borrowed it from a friend who is out of town and don't have instructions. I'm trying to power wash my...
An air compressor such as the one that you borrowed is very useful for airing-up tires, connecting a nailer for wood working projects and spray painting with a cup gun. All that you need do is plug it in to a 110v outlet and it will fill with air to capacity. To access the air you will need to plug an air hose into a quick coupler and adjust the air pressure with the knob showing two direction arrow. Unless your friend has included an air assisted water blasting wand that would also connect to a water supply, I do not think that it would be useful for cleaning. I have used a compressor such as this with an air nozzle or air blasting the air conditioner condenser fins and the drain to the evaporator inside the house. It will also be really great for cleaning the mower or any outdoor tool that accumulates oily dust (air filters). With a small sand blasting attachment you could remove old paint from the patio furniture or any wood or metal surface needing a good blasting to make it look like new. Sand blasting would not be practical for house/ deck/ fence because it would take too long and use too much sand; then there would be the sand cleanup. Have fun with the compressor and clean-up projects.
Sep 30, 2010 | Porter Cable Air Tools & Compressors
How to clean spark plugs on 2007 honda cbr
Replace the plugs, don't try to clean them. The proper way to clean plugs used to be to sand blast them. The problem was that bits of sand can remain deep inside the throat of the plug. When the sand breaks free it causes damage to the piston, rings, cylinder and valves. The only safe way to clean them is to blast them with dry ice particles. Cleaning plugs is not a big industry. The equipment required is hard to find and is expensive. You have a lot of money invested in your bike. Spring for a new set of plugs. Please rate my answer. Thanks.
Aug 11, 2010 | 2007 Honda CBR 1000 RR Fireblade
No vertical movement of hydrolic arms when pushing pedal
You will have to bleed the rams to get all the air out just crack the hose's open at the connector and have a person help you open the hoses on both sides and try raising the bucket when you get clear fluid coming out close the nuts on the lines then do the same thing for down position. Check hydraulic fluid level to make sure it does not get so low that you put air in the system. Be sure when you are bleeding to pay attention to fluid flow coming out of the rams is it even? If not you may have a hose that has collapsed. To know if it is look at how much fluid flows out of the hose the one with the lest amount of oil is suspect. Next if it still does not raise pull the pressure valve out of the control Block where the arm is for raising it crack the outer locking nut then remove the valve and see if you have a piece of dirt in the valve seat. If you need more help post it here and Give me the Year and model Number for more precise help for this unit.
Aug 23, 2009 | Garden
Lg wm0642hw drain hose in front is pluged with sand. When I tried to drain the hose so I could clean the filter I noticed the hose is plugged with sand. How can I clean the hose out.
That's a real pain. Even if you remove the hose, it is hard to clean out. You can get at the pump end of the hose by tilting the machine back and reaching under it. Replace the hose will save a lot of time, or I'd suggest next time you want to clean out your filter do this:
Pull the machine out about 18 inches or so away from the wall and tilt it back until the back rests against the wall. (front feet now up in the air) Now, all the water will be back at the back of the machine and you can remove the filter to clean it out without spilling water.
Aug 16, 2009 | LG WM0642H Front Load
Pintoy Digger Construction Vehicle Logo
141 people viewed this question
Top Pintoy Toys Experts
ray gallant
Are you a Pintoy Toy Expert? Answer questions, earn points and help others
