Question about Whirlpool Gold Black-on-Black 25.4 cu. ft. Side-By-Side Refrigerator w / Accu-Chill Temperature Control System GD5SHGXLB
Our Whirlpool side by side also makes a thumping sound. I have had repair people at the house 5 times with only one finding a possible solution and that solution was to reposition a dryer by the fill valve that was replaced just before the noise started. Could the dryer be bad and need to be replace? Both the freeze and refrigerator work fine.
    President:
  • 1,891 Answers
This is not a uncommon porblem but notall tec under stand the problem . the dryer is ok . the problem is the tube that inters the compressor is located in shuc a way that it can cause a nois like a 22 going off . some are louder than others . this is often covered by the makers warranty . if less than 5 yrs . whirlpool should take care of this . it may require a replace compressor .. mm .. hope this helped ..
Posted on Feb 04, 2010
When we turn heat or air on it makes a thumping sound in the back of the suv?
If you have rear heating in your SUV, the sound may be the gate valve(s) switching positions, if it does have a gate valve, there may be some thing jamming it up. if you have kids/ or a lot of tools or stuff that you carry in the back, it is possible that something got inside the housing for the unit (may also be jamming the fan for it as well).
is the "thump" continuous or does it just happen when you first turn it on? look under the rear seat (usually on the passenger side) for anything that may be up against the unit (also look to see if the units' housing is crushed)
Mar 02, 2012 | 2003 Ford Expedition
Whirlpool side by side fridge stopped working had a chemical odor in the house
It is possible that the gas has leaked out. does it run hot !. It might be repairable or it could be beyon ecconomical repair. How old is the fridge. It could be time to replace the whole thing.
Jul 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My GE tfx27f is working fine but when the
the thump ing sound is probably the rubber mounts under the compressor . they go hard and do not insulate the compressor . . pry the comp up on all four mounts and make sure they are loose and not stuck down if ther are hard and not bouncy .. replace them . if compressor has borken internal motor mounts / there is nothing you can do . but put up with noise ..
Jan 06, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Machine makes a thumping noise when spinning
If its thumping you have the maching overloaded and the clothes (very easy to do with heavy jeans or sweaters) are all on one side causing an out of balance situation. Try relocating some of the clothes to the other side of the unit and if that doesn't seem to help remove some of the clothes to eas the load on the machine otherwise it will never reach maximum spin speeds needed to rinse your clothes.
Aug 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FRIG. NOT GETTING COLD
Switch off the fridge immediately and allow the compressor to cool off. It is possible that the defrost element is not working, causing a build up of ice in the freezer side. But this should not cause the compressor to overload. The compressor thumping and then stopping can be caused by low voltage supply or a blockage in the refrigerant system
Mar 02, 2009 | Maytag MZD2766GES Side by Side...
Kenmore heavy duty
I can only assume by rollers you mean bearings were replaced. Unless your dad measured both the ID Fit of the bearing and the OD fit [ inside diameter and outside diameter of the shaft and housings] new bearings could be on the small side of their tolerance, [new bearings are made to be within a certain amount of "slop" if the new bearing was on the outside tolerance, and the shaft or housing was on the large side of the tolerance, the bearings are still allowing the drum to move, and thump.
OR if belt driven, the alignment of the belt is important, if one pulley is out, and the other in, one shaft will be pulling and the other pushing, again a thump.
Something in the bearing/pulley setup has not been discovered bad yet, it takes micrometers and some knowledge of bearing tolerances to resolve this kind of problem.
Think about it, what can thump in a dryer? The tumbler cage. It is most likely that the journal or housings are wore, second the motor may have a front or rear bearing/ housing the same thing, gone bad,
This machine is old enough I would expect to find a worn housing or shaft, either drum or motor,most likely drum, check the alignment of the belt also, but most likely the thump is not cost effective to repair, plus Dad's time which is invaluable.
Start searching the sale sheets, and reading consumer reports, time for a new energy easy dryer anyway.
Will
Sep 16, 2008 | Kenmore 63942 Dryer
Washer makes a thumping sound
you indicate problem happens on quick wash how about cycle designed for towels ? the control bd on cabrio is programed for loads based on each setting the speed and torgue for motor is controled by the bd and trying to use on settings other than those programed towels may indeed cause problems ..try different cycle and let me know thanks
Jun 24, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Constant "thumping" sound when dryer is going
you can fix it by ordering a whirlpool roller kit but its no big deal the drum sits on rubber rollers when it just sits the rolers get flat spots on them like tires and makes the thumping sounds its just noisey but no big deal but they do make a kit with softer rollers
May 24, 2008 | Kenmore 63942 Dryer
Subwoofer "thumping" w. no audio feed
You need to check your ground connection. If there is a bad ground there will be feedback to the amp and it will just sit there and loop back with the Thump, Thump, Thump sound. I had to wire my amp's ground all the way back to the negative battery terminal. It was a pain but I have never had a problem since :)
Feb 12, 2008 | JBL SCS125A System
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Refrigerators Logo
108 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
