Question about LG WD-14124RD Front Load Washer / Dryer
LG Fuzzy Logic model no WF -T587 Stops halfway and comes up with an Error code U3 ? Many thanks
  • 1294 Answers
SOURCE: LG Fuzzy Logic won't drain out the water
Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
Posted on Dec 21, 2007
SOURCE: LG Fuzzy Logic WF-T7030TP Turbodrum Sensor
Error Peurta
Posted on Mar 24, 2008
  • 210 Answers
SOURCE: PE error code on LG WF-T653A
PE is a pressure switch problem. Could be a bad switch or it could be that the hose is plugged. The switch looks like a diapharm switch and is located on the main board. It has a black hose that connects under the bottom of the tub. See if that end is clogged. Otherwise you may need a new switch.
Sgt 48
Posted on Jun 02, 2008
  • 4 Answers
SOURCE: I'm using LG Fuzzy logic 6.5kg WF-S6607TC.
Check the lid cover. At the edge, there is a plastic housing some sort of a magnet. This is the magnetic sensor for lid cover open protection.
If the magnet is not there, place a magnet at the position on the washer where the housing will come in contact with the washer when lid is close.
Posted on Sep 09, 2009
  • 472 Answers
SOURCE: Hi, we have a LG
working on lg for a while we have talked to tech suport and they don't want to admit they have a issue with these units.. first of all they say if on a pedastal they will give you problems but yet they sale the darn things... what we have found though is there is a device called a haul densor and it is very easy to replace you have to remove the backof unit panel and gain access to the back of tub... make sure it is connected well as it is on a rotor looking device called a stator assembly... if it is connected well and you have made sure it is level you have a bad haul sensor...thsi is what determines the speed of drum and slows down unit if getting out of balanced.. it is not that expensicve and pretty easy to fix.... hope this helps you out...
servicer 18 years
Posted on Jan 06, 2011
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
Dec 01, 2013 | Washing Machines
LG fuzzy logic 7.5kg WF-T753A, 1E code coming up.
water is not enough check for obstruction and water pressure
Sep 28, 2013 | LG WD-14124RD Front Load Washer / Dryer
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
Lg Fuzzy Logic 5.5kg Turbo Drum with I-sensor, Model WF-T552TH Washing machine goes through initial fill up, when changing to spin/wash works for 2 seconds, then stops spinning back and forth and shows dE...
There is a small magnet at the front of the lid that triggers the door error, mine was corroded and the lg people wanted $80 for a service fee.. Ha I went to my local hobby shop and got a small earth magnet and some super glue $1.50 later and she's fixed.. tadAaa.
May 11, 2011 | Washing Machines
I have a LG Fuzzy Logic washer model WF-T1050TP, AND IT STOPS RUNNING SAYING THE LID IS NOT CLOSED SAYING ERROR d3, BUT THE LID IS CLOSED???
the door switch sounds like it has gone bad, check with a multi meter, they can check it for u at any appliance parts store if u dont have a multi meter
Jul 04, 2009 | LG Washing Machines
Washing machine won't drain
i think you can fix it , does it stops when it reaches RINSE cycle ?? if yes , your gonna open the front panel or back panel so you can see inside machine . follow the DRAIN HOSE thats attached to SMALL DRAIN PUMP MOTOR , YOU NEED TO TAKE OUT and check for anything thats blocking the impellers and causing it to stop ( pins , buttons , etc ) let me know by your smile . . . . . .
Apr 22, 2008 | Washing Machines
LG WD-14124RD Front Load Washer / Dryer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
