Question about Seagate (ST660712URK) 6.0 GB USB 2.0 Hard Drive
Going between PCs and MACs.
Are you able to transfer between PCs and MACs with the drive without losing any data?
What drive are you speaking about.
PCs and Macs (assuming you are speaking about a PPC architecture machine-- older-- not the newer dual core Intel processor machines capable of running Windows) run on different code due to the different fundamental architecture of their respective central processing units (CPU's). PC software will not run on Macs and vice versa. Exceptions to this rule would be software written using a platform independent language such as Java (open office is an example of such software).
That said, you can transfer any data that you have on your PC to the drive on your Mac. Unless you have an Intel dual core chip, however, or the software is written in Java or the like, it will not run on your Mac. It will just sit there, nicely stored, waiting for you to transfer it to a machine that can understand it.
Posted on Jul 03, 2009
How do I reconnect the WD harddrive to the Bell PVR with out losing what I have already transfer
It is very simple, just re-connect the device and restart the process for remaining data and simultaneously check if you have lost any data or not. If you have lost your data then you have to show your machine to an expert for Recovering Data from Hard Drive.visit us http://www.maidenheaddatarecovery.co.uk
Oct 24, 2014 | Western Digital WD Passport 250GB Portable...
Tip
To increase data transfer rate b/w PCs
If the data transfer rate between two PCs over a LAN is slow, stop any firewall service if running in both PCs. This will increase the data transfer rate between the PCs.
This can increase the throughput if your are backing a set of servers using a master backup server. Or any scenario where is there is flow of data between two windows systems.
PS: This is not applicable to all the antivirus firewalls. Also i don't recommend to keep the firewall disabled, if no other alternatives are planned well.
on Apr 03, 2010 | Computers & Internet
Does it work with macs? i`ve used it on PCs and downloaded to macs, but I can't get it to copy iso from mac
If you have your drive formatted NTFS for the PC, the Mac will be able to read from the drive, but will not be able to write to the disc. To format it so that it will work cross-platform with both Macs and PCs, you will need to format it FAT32, and you will need to do it on a Mac, as PCs cannot format over 32GB in FAT32. Make sure you back up your data before formatting as it will destroy all data. Connect the drive to the Mac, turn it on, then open DiskUtility. You can find this in the Applications>Utilities folder. Then locate your drive on the left side of the window, and choose the drive by clicking on it. Then choose the Partition Tab. Under the volume scheme, change the drop-down menu from Current to 1 partition. Then click on the Options button and choose Master Boot Record (MBR) and click OK. Then under the Format menu, choose MS-DOS, or FAT. Then clcik Apply and OK, and the drive will format FAT32, and you will then be able to read and write cross-platform. I hope this helps.
Sep 15, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
I opened the box just now, inserted it into my mac desktop and tried transferring a folder into it, it says: "The item could not be moved because freeAgent GoFlex Drive cannot be...
What I would be tempted to do is to reformat the hard drive of course THIS WILL WIPE OUT ANY DATA that is currently on the drive. To do this go applications then utilities and select disk utility. Once opened select your seagate drive from the left hand box and then select the erase option. Under volume format you can select Mac OS Extended and put an name in the name box. You can select MS-DOS (FAT) if you want to use on both PCs and Macs. Then click erase.
As indicated above THIS WILL WIPE OUT ANY PREVIOUS DATA ON THE DISK.
Hope this helps.
Dec 06, 2010 | Seagate FreeAgent Go 320 GB USB 20 Hard...
My firelite smartdisk model cord does not fit into my new macbook air. can i buy a cord that has a usb port at one end? thx
The MacBook Air has one USB port. Most computer stores have many different plugs on the other end that will fit your SmartDisk. Most of the SmartDisk units use the mini USB plug. It is the same as many digital cameras use.
Tiger Direct, and MicroCenter also have many different adapters, and adapter kits to use on all kinds of USB devices.
I hope this helps. Please let me know if there are any more questions.
AAirwolf
PS: I use a 160GB SmartDisk on all of my Macs, and PCs. Get way to move data without conflicts.
Feb 13, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
How do i cannect my macg4 to my home network??
With the ethernet cable connected, try going to system preferences, choose network and select built-in ethernet in the left hand panel and then in the right hand panel at configure use the using DHCP option then click on Apply in the bottom right of the network panel. Hope this helps
Nov 22, 2009 | Apple iMac G4 Desktop
USB
UNIVERSAL SERIAL BUS(USB) - is the most common type of computer port used in today's computers. It can be used to connect keyboards, mice, game controllers, printers, scanners, digital cameras, and removable media drives, just to name a few. With the help of a few USB hubs, you can connect up to 127 peripherals to a single USB port and use them all at once (though that would require quite a bit of dexterity).
USB is also faster than older ports, such as serial and parallel ports. The USB 1.1 specification supports data transfer rates of up to 12Mb/sec and USB 2.0 has a maximum transfer rate of 480 Mbps. Though USB was introduced in 1997, the technology didn't really take off until the introduction of the Apple iMac (in late 1998) which used USB ports exclusively. It is somewhat ironic, considering USB was created and designed by Intel, Compaq, Digital, and IBM. Over the past few years, USB has become a widely-used cross-platform interface for both Macs and PCs.
Aug 16, 2008 | Computers & Internet
My 'maxtor' hard drive has been formatted to Mac OS extended- therefore it is not recognised by my other non-mac laptops and PCs. How can i format it so that i can transfer music and photos from macs to...
If it's a drive in an external case with a USB connector, and you're idea is to plug it into each computer, that won't work.
Otherwise, you share it on a network. Choose which machine it will be in permanently, then share it.
Of course, that means you have to have a network...
Jul 25, 2008 | Computers & Internet
How is transfering Data and information from my computer into 1GB USB2.0(Data Traveler) done?. How do I start and how do I connect the USB2.0 on my computer to begin the transfering?. I am asking this...
FOR ADDITIONAL INFORMATION ABOUT FLASH DRIVES
USB (Universal Serial Bus) flash drives are high-speed, high-capacity memory devices designed for long-term data storage and easy transport among PCs. The host PC treats the device just like a drive, so you can transfer files of all types to and from the device. Because the device emulates a drive, it supports any type of file, including audio files (such as MP3s) and graphics files (such as JPEGs [Joint Photographic Experts Group] and BMPs [bit map]). In addition, USB flash drives can easily support applications, CAD (computer-aided design) drawings, and a wealth of personal information you'd rather not leave on any particular PC. Even so, most USB flash drives are smaller than a pack of gum and can easily fit onto a key ring.
Years ago, users often referred to the practice of using floppies to transport files among PCs as sneakernet. Because USB flash drive manufacturers designed these devices for transport among PCs, their increasing popularity has given rise to a "new sneakernet."
Mar 09, 2008 | Computers & Internet
Lacie 250GB External Hardive to be used between a PC and a MAC
Be carefull when moving data from Macs to Windows etc. Your best bet would be to start again. It should work if you get your friend to put the data on the drive & copy it directly to your Mac. From there, you can safely copy data to the PC, but may have trouble accessing that same data after the PC has had it.
Jul 31, 2007 | LaCie Silverscreen 80GB USB 2.0 - Portable...
Seagate (ST660712URK) 6.0 GB USB 2.0 Hard Drive Logo
98 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
