Question about Brother MFC-9420CN All-In-One Laser Printer
Please what is a transfer roller - Brother MFC-9420CN All-In-One Laser Printer
Lexmark x502 printer shows tray 1 missing
hi...........
pls do the following :-
Tray Missing: Insert Tray Tray 1 and/or Tray 2 is missing. Insert the specified tray(s) into the printer. TR Belt Life: Replace Transfer Belt The transfer belt is exhausted. Install a new transfer belt. TR Kit Life: Replace PQ Kit The transfer roller and transfer belt cleaning roller are exhausted. Install a new transfer roller and a new transfer belt cleaning roller. TX Comm Error An outgoing fax transmission error has occurred. Resend the fax. Warming up Wait for the message to clear....
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 29, 2011 | Lexmark C532n Color Laser Printer
Error code 917.00
Step Action 1 Turn off the printer and let the printer sit, powered off, for one minute. 2 Power the printer back on. 3 If the 917 error does not return on power-up, try printing a few pages. If the error does not return during printing, this may have been an isolated incident. Continue using the printer as before, but pay close attention to it for the next few days to see if the error returns. 4
If the error returns on power-up, as soon as you try to print, or re-appears at a later time, inspect the transfer roller. (Click the links in the steps below for images.)
  1. Turn the printer off.
  2. Open both the lower front cover and the upper front cover of the printer.
  3. Remove the toner cartridge and place it aside.
  4. Look at the transfer roller. Make sure nothing is stuck on the roller or wrapped around it. If you find any obstruction, try your best to remove it without damaging the transfer roller or knocking the roller loose.
  5. Make sure the transfer roller is not loose or damaged. If the roller is damaged, the roller will need to be replaced. Please contact Lexmark Technical Support or a local authorized service provider for further assistance.
  6. Spin the transfer roller. Make sure it spins freely.
  7. If the transfer roller appears to be fine, reinstall the toner cartridge and power the printer back on.
  8. Try printing again to see if the error message returns.
If the 917 error still will not clear, or if the error continues to occur intermittently, the printer will likely require service. Please contact Lexmark Technical Support or a local authorized service provider for further assistance. See Contacting Lexmark below for more information.
Jan 11, 2011 | Lexmark T642 Laser Printer
Functional problem SC402
sc 402 is the transfer roller error. please clean the transfer roller. transfer roller fits on the side cover. some machines have transfer belt.
Dec 01, 2010 | Ricoh Office Equipment & Supplies
I need to know how to replace...
The transfer belt cleanning blade is under the transfer belt.Remove 2 screw and change it.The bias transfer roller is mounted in two bushings,remove the bushings and 2 springs.The fuser unit : upper fuser roller,lower fuser roller and the cleaning rollers.
Aug 25, 2009 | Office Equipment & Supplies
Lexmark t644 error code 917.00
This error indicates that there is a charging problem with the transfer roller. You could start by cleaning the contacts for the transfer roller (power off printer first). The transfer roller is the black foam-like roller under the toner cartridge. Handle it with paper because the oils on your hand could damage it. To remove it, just pry under the far left side with a screwdriver. Lift and pull to the left to remove. If this does not fix it, then you have a more serious problem. It could be one of the arms or the HVPS.
May 07, 2009 | Lexmark T642 Laser Printer
Ricoh Aficio CL800 - Set Transfer Roller
possible transfer roller rotation sensor dirty or damaged transfer roller. check -- open rear door and see how the roller looks.
Apr 10, 2009 | Ricoh Aficio CL1000N Printer
My Rico Aficio 200
Please open the front door and turn the blue lever in the middle,
remove the Transfer and Separation unit and check if the bushings of the transfer roller are damaged.
If OK, please give some oil on the shaft/bushings of the transfer roller. This unit may be replaced as a whole unit.
If SC401 re-occurs, please check the Photoconductor unit (drum).
Aug 27, 2008 | Ricoh Aficio 180 Laser Printer
Gestetner 3225
SC401: Transfer roller leak error 1
SC402: Transfer roller leak error 2
-Definition- [B]
A transfer roller current leak signal is detected.
The current feedback signal for the transfer roller is not detected.
- Possible causes -
· High voltage supply board defective
· Poor connection of the PCU
· Transfer/separation unit set incorrectly
Jul 23, 2008 | Gestetner DSm618 All-In-One Printer
Brother 9420cn message on display transfer roller not installed, appeared during printing session, cannot rectify
Replacing the transfer roller
1 Turn off the machine’s power switch.
2 Open the back cover of the machine.
3 Release the transfer roller lock levers on
the right and left-hand sides, and then lift
the levers to release the transfer roller.
4 Take out the transfer roller by gently
pulling the right-hand side up and sliding
the transfer roller to the right.
5 Put in the new transfer roller by holding
the lock levers of the transfer roller and
adjusting the angle of the transfer roller
lever shafts (both sides) to match the
transfer unit grooves. Put the transfer
roller onto the shafts and place the roller
onto the springs as shown below:
6 Push the lock levers down to lock the
transfer roller into place.
7 Close the back cover.
8 Turn the machine’s power switch back
on.
Apr 30, 2008 | Office Equipment & Supplies
Phaser 6250 transfer roller
Hi clwest: I hope that this will help you.
Transfer Roller is at End of Life
■ Print the Supplies Usage page to verify the remaining life and Transfer
Roller install date.
■ Cycle printer power.
■ If the problem persists, follow the procedure below
Note
Look at the clear plastic window on the Transfer Roller. If toner is present in the
center of the window the Transfer Roller is at end of life and needs to be
replaced. If no toner is visible, try cleaning the CTD (ADC) Sensor.
The “Transfer Roller is at End of Life” is a warning. “Replace Transfer Roller” is
a hard stop.
Dec 15, 2006 | Xerox Phaser 6250N Printer
Brother MFC-9420CN All-In-One Laser Printer Logo
139 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
