Question about KitchenAid K45SS Classic Stand Mixer
I have a classic k45sswh kitchen aid mixer. I removed back cover and replaced and now it does not start.Then removed brushes and must have put them incorrect but still it don't start. I notice a angle on one corner of the brushes - which corner does that brush go?? I assume there is an adjustment using the screw however still I am unable to get it to start. How do U adjust it to perfect?? Does that adjustment screw affect the starting or just speeds?? I know the brushes are part of the starting issue forsure. Help pls
  • 235 Answers
Hi TRADESGIRLS, you are correct, the brushes have to seat correctly on the armature’s commutator or you won’t get any ‘juice. Unfortunately, the ‘screws’ on the sides of the mixer are just the Brush Holder Caps (brush cover), which allow you access to the brush holder assembly and has nothing to do with ‘adjusting’ the brushes. From what done already, still I suspect that one or both of the brushes is (are) not seated properly.
The brushes need to be installed so that they both seat correctly on the armature's commutator. See the illustration below:
I'd suggest removing them again and making sure the concave contact face rests completely on the armature’s commutator. If you've turned it 90 degrees too much, it won’t seat properly and you get no power to the motor.
It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW, and select the first file K45SSWH0.pdf (341.41 KB) listed under Parts List (1) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 32, Brush holder assembly that includes Illus. Nos. #18, 21, 22, 23 & 31, and Illus. No. 19, Brush & Spring assembly respectively.
The Parts List illustration along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
Posted on Feb 05, 2010
I have a kitchen aid stand mixer. model #rkt2651x. it goes very fast when turned on then shuts off. it will go again but turns right off again. age?
That is indicative of worn motors brushes or a speed regulation circuit board problem. It is worth getting it fixed.
I just checked and my diagnosis is sound :>)
I have a kitchen aid stand mixer. model #rkt2651x. it goes - Fixya
www.fixya.com/support/t26909658-kitchen_aid_stand_mixer_model
52 mins ago - i have a kitchen aid stand mixer. model #rkt2651x. it goes very fast when turned on then shuts off. it will go - Food Mixers question. SOLVED: Mixer goes really fast then stops
29 Dec 2007
Questions, Troubleshooting Help & Support Page 3
28 Jul 2006
More results from www.fixya.com
KitchenAid Classic Mixer K45SSWH Troubleshooting - iFixit
https://www.ifixit.com/Wiki/KitchenAid_Classic_Mixer_K45SSWH_Troubleshooting Make sure the KitchenAid Mixer is firmly plugged into a working outlet and the cord is not twisted or split. ... If your mixer still will not turn on, it might be a problem with the motor brushes. If the brushes are worn down ... The most common sign of a failing hall sensor is if your mixer increases to top speed and then shuts down. Missing: rkt2651x
Stand Mixer Shuts Off During Use - KitchenAid Product Help
producthelp.kitchenaid.com > ... > Stand Mixer Assembly and Operation Jul 12, 2017 - Once the steam has dissipated, the unit should turn on again (about 3 minutes). Resolution: If the mixer could have overheated during use let the mixer cool for at least 30 minutes and try to re-start. If you were making mashed potatoes when the mixer shut off it's possible that with excessive steam the unit ... Missing: rkt2651x
images for kitchen aid rkt2651x stand mixer goes very ...
More images for kitchen aid rkt2651x stand mixer goes very fast when turned on then shuts offReport images
FAQs - KitchenAid
https://kitchenaid.com.au/faqs Explore our range of frequently asked questions to get the very most out of your KitchenAid product. Missing: rkt2651x
[PDF]Classic Stand Mixer Speed Control - KitchenAid
https://kitchenaid.com.au/sites/.../stand_mixer_service_manual_speed_control_6-12.p... KitchenAid®. Classic Stand Mixer. Speed Control. Theory of Operation. And. Troubleshooting Guide. (revision date 6/19/2012). D. Pahl ... Mixer Does Not Shut Off page 6. Mixer Does Not Turn On page 7 ... the motor is not running (OFF) the governor ball plate is at its farthest forward position and when the motor is running at ... Missing: rkt2651x
How to Replace the Speed Sensor and Control Board on a KitchenAid ...
? 6:28
https://www.youtube.com/watch?v=41qTqTWQkMI Jan 15, 2013 - Uploaded by eReplacementParts.com
This video tutorial will show you how to replace the speed sensor and control board on a KitchenAid Pro 6 ...Missing: rkt2651x ‎turned kitchenaid rkt2651x stand mixer goes very fast when turned on then shuts...
Mar 10, 2018 | Food Mixers
The gears will not work. It will not turn on
There are three springs which can be seen when the back cover is removed. Two are behind the black control plate (the pair of screws at the top of the plate are tensioned by these screws) and another spring that pulls on the bottom of the control plate (this one comes from deep inside the motor housing).
The following link will take you to a copy of the KitchenAid Service Manual which will help you identify the springs and, I hope, the problem.
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Jan 23, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
Where can I get the grease for my Kitchen aid stand mixer?
The grease is food grade grease and Kitchen Aid supply it as a spare part so depending on where you live either from themselves or an Authorised Service Agent. If you are in New Zealand then I can supply.
Jan 01, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
Can I use lucas oil white lithium in my stand mixer
They do not use oil at all, they use food grade grease. Any oil that is dripping out is the liquids separating out from the solids in the grease. You either need to open it up and stir the grease u again or remove the old grease completely and repack it with new stuff.
Nov 29, 2014 | KitchenAid Kitchen Aid K45SSWH Classic...
Manuals breville
I do not know why you would which to remove the motor. I do not recommend it. The motor is connected to a transmission in the front of the mixer and was most likely pressed in to place by a machine into a baring in the back of the transmission. As far as I can tell the only user serviceable parts are in the back. Primarily the bushings and the back service cover.
To remove the windings you will need a puller. You might be able to find one at your local auto parts store, or one of the stores that specializes in tools such as Harbor Fright, Northern Tool or something like that. Once you remove the back cover you should see the armature, simply attache the puller to the shaft and extract it. If you are lucky you will be able to reinsert it in the opposite order. However, there is a chance that parts of the transmission will fall out of place making it difficult to reassemble.
I am pretty sure you can disassemble it, but putting it back together will be much more challenging.
If you are having trouble with a switch or the bushings I would call Kitchen Aid first. Help Contact Us KitchenAid
Aug 25, 2014 | KitchenAid Kitchen Aid K45SSWH Classic...
Kitchen Air Mixer will not come on
The easiest thing to check is the brushes. Unscrew each black (sometimes white) round cover on either side of the motor housing and see that there is enough carbon brush remaining.
Since the brushes were most likely ok, then I would suspect the solid-state control phase board. These are pretty easy to replace. You can find the service manual for your model on line.
Jul 22, 2014 | KitchenAid Kitchen Aid K45SSWH Classic...
I unknowingly removed the brush pins from my kitchen aid mixer
This is pretty easy, just put new ones in. The brushes are meant to be replaced and are user servicable.
Nov 30, 2012 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K45SS Classic Stand Mixer Logo
481 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
