Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Connecting Dell Dimension 5150 PC to HP Officejet Pro L7580
When I try to connect my pc to the printer via the usb port the printer goes haywire - lights go on and off and the display requests that I turn the printer off and then on again. The pc does not seem to recognize the printer either. I've tried this by connecting different usb cables to different ports but no change. The printer seems to work independently of the pc. HP have even replaced the printer saying it must be a hardware issue with the printer. I had the same problem with the second printer. They're only solution is to send me yet another printer; which I doubt will fix the problem.
    Genius:
  • 3,422 Answers
If your PC is not recognising it then the printer is not functioning properly.Whn you connect your printer to the USB do you get a something like "This device has malfunctioned" if yes then it is the fault of your printer.
Goodluck..
Posted on Feb 20, 2008
  • 770 Answers
Does your PC reckonize the printer when you connect the usb to it?? ave you tried before connection the printer to click on start and control panel then printer to see if it is there ?? If no try to add it and use the driver disk that came with it.You can also look in system folder at the contol panel screen after it opens click on Hardware Tab then click on deivce mgr to see if you have any confils under the printer.let me know
    New Friend:
  • 101 Answers
Uninstall all printer software and drivers then restart w/o the printer connected. install the software 1st when it checks 4 printer thats when u plug it in.Also check your ink cartidges. what is the model of printer?also update your drivers .in your boot up is usd devices part of your boot? that would be in your bios settings.did you have a printer before?need more info.
I have a Dell Dim 2400 and no connection with HP Deskjet 3070A.
Charles, has this combination worked previously, have you been able to print from your Dell Dimension 2400 to your HP Deskjet 3070A successfully?
If the answer to the above is Yes, then if you believe that the printer is still working correctly and you can test this with a different computer able to print to it, you should consider uninstalling and re-installing the HP software and device drivers for this printer.
If you have not printed to this printer successfully previously, have you tested the printer with a different computer and proven it is still working fine?
If the printer works fine to a different computer then providing you are using the same USB cable to connect to your Dell 2400, the problem needs to be narrowed down further.
Check that you can plus other USB devices into the port on the Dell used for the HP printer - if these work, then your USB port is good - if not, try another port if you have one.
If your USB hardware is good, then again you are left with the need to uninstall and re-install the HP software and device drivers - it may be worth trying to download the latest version of such software if available. HP tend to update their All-in-One software on a regular basis.
Dec 30, 2011 | Dell Dimension 2400 (24006YYVP31) PC...
My hp officejet pro L7580 is connected to DOT4 port, there's a hp officejet pro L7580fax connected to USB002. I want officejet pro L7580 connected to USB002, NOT the L7580fax. My desktop is not...
To walk you through I'd need to know the OS you are running, but the generic answer is that you need to go into the print driver, and in the Printer Properties, under the ports tab , select the USB002 port rather than the DOT4 port and Apply the changes.
Mar 18, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Installing hp 5150 printer gets hung up on last phase searching for hardware
generally, this works for me: Make sure the printer is disconnected, uninstall the driver, reboot
download the latest driver from HP.com
Run the install and when prompted, turn on printer, then connect the USB cable to the computer and let it detect.
If the printer still doesn't install normally try this
http://www.fixya.com/support/r3680773-completely_remove_printer_drivers
and this
Apr 10, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150 front control panel board - usb ports
Google it. Otherwise,no dice,replace the board if you can find one. Try ebay.
Jun 23, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Wireless Dell laptop can't 'find' HPDeskjet 5150 Printer
this printer is (as per HP specs) only connected via USB or Wlan Print server.
Check connection using USB cable and be sure Printer driver are correctly working.
Check on Router your Print server IP address (Lock it out of DHCP)
Put both PRT and PC on same home network (normally HOME or MSWORK)
Put Printer server IP address into your printer properties/port tab/ IP.
OR check if you see your printer server in your Windows network/home network
Jan 11, 2009 | Computers & Internet
Printhead replaced; still says yellow is empty
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
My HP Officejet Pro L7580 prints one page and then stops
TRY WITH WHETHER THE PRINTER CONNECTED PROPERLY AND UPDATE IS NOT PROPER
Nov 18, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
My Dell Dimension 2400 does not recognize plug & play for my HP OfficeJet Pro L7650 all-in-one. If I add the all-in-one manually, the computer says it's offline. I've uninstalled & reinstalled the...
My solution was very simple...I just threw my computer out the window! Seriously, the problem has not been resolved...it seems that several types of Dell computers (in my case, the Dimension) have a problem with HP all-in-ones with regard to the USB 2.0 having enough power to recognize the plug and play option when installing the HP product. Dell's only solution (that I could find) is to operate the HP product thru a USB hub...so I guess I'll try that first and, if it still doesn't work, I'll probably just upgrade to a newer non-Dell Dimension computer.
Jul 15, 2008 | Dell Dimension 8200 PC Desktop
HP L7580 just went blank ??
Does it make any noises or signs of life if you cycle the power?
Is this unit mains powered or does it run from the USB cable only?
If USB only try another USB port on your PC
If mains powered, check the outlet still has power, the cable is plugged into the back of printer. Some printers have a clip out PSU (usually a rectangular box that the mains cable goes into) push it in firmly as it may be loose (you may be able to clip it out and re seat it completely - ensure mains is OFF first). Check the on/off switch is in the correct position, try powering up when not connected to the PC.
Post back results so I may try and assist further.
Jul 12, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Getting error when trying to fax or scan
The L7580 is not meant to be set up as a scanning device on a network. This unit can only function properly as a USB connected device to have all the features work. Also, for the software to install with out problems, all other All in One software fro previous HP printers need to be removed. Once we did that and did clean install using USB only then did it work.
Mar 03, 2008 | HP OfficeJet Pro L7580 Color All-in-One...
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
47 people viewed this question
Alun Cox
