Question about Whirlpool Dryers
I have a whirlpool imperial dryer, I am not certain of the age or model number. I replaced the electrical cord after a move with a 4 wire instead of the 3 wire that was on it. The dryer operates it turns counter clockwise and it heats up but it does not dry the clothes. I changed the hot wires around hoping I had them wrong but it operates the same, any idea what the problem might be?
  • Whirlpool Master
  • 2,699 Answers
If it's heating up and the drum is spinning then you have a blocked vent line or the duct that the lint filter slides into is plugged with lint,if your vent line is long blow it out with a leaf blower,like i said you need to clean and vac out the duct that the filter slides into and vac out the inside of dryer where the motor is,you should do this once a year so you don't have a fire and your clothes will dry correctly
Posted on Feb 03, 2010
Just moved, the dryer has a 4 prong plug and house has 3. Should it replace plug to dryer to 3 prong or house plug?
Buy a 3 wire cord and install it on the dryer. Hang onto the 4 wire one in case you move again.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 28, 2011 | Whirlpool LER4634J Electric Dryer
I am replacing a 3 prong cord with a 4 since we have moved into a newer newer home and the dryer has a white wire attached to the frame instead of a green wire. Is the the ground and can I just place the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 23, 2010 | Roper RES7646KQ Electric Dryer
Just moved and outlet for dryer is different.
Connect the red, black, and white wires of the new cord to where the red, black, and white wires of the original dryer wires are connected to but disconnect the ground wire (green/yellow wire attached to the cabinet) from where the white wire is connected to and connect it instead to the fourth green/yellow wire of the new cord.
Apr 12, 2010 | Whirlpool LER5636P Electric Dryer
Trying to replace a three prong electrical cord with a four prong one.
Dryer wiring (3 wires to 4) If ya move or get a new dryer and need a 4 wire setup instead of a 3 this might be of interest: Look at the terminal block. Most dryers have a red wire on one side, a black wire on the other side, and a white wire in the middle. I put my red to red white to white and black to black as pictured in the above link. The green ground wire gets bolted to the frame.
Dec 26, 2009 | Maytag MED5770TQ Electric Commercial Dryer
I am changing out the dryer cord on my Whirlpool electric dryer from a 3 prong to a 4. there is a green wire with a yellow strip coming from the dryer and grounded on the side of the dryer like a grounding...
Hello. Now that you are upgrading to the four prong you should unhook the green wire with yellow strip coming from the dryer and instead attach the extra green ground cord on the 4 prong to the screw on the side of the dryer. Regards, Joe.
If you prefer to see this in picture form, check this link: http://www.appliance411.com/links/jump.cgi?ID=466
Nov 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Looking for the age of Whirlpool electric dryer model number LET7848AQO Imperial Series CleanTouch 7 cycle 4 temp.
Link Below will give you the ability to calculate your manufacture date from the letters in the SERIAL number.
Whirlpool Date Codes
Sep 09, 2009 | Whirlpool Dryers
My whirlpool gas dryer is not starting. the thermal fuse reads fine. I have a 4 wire thermostat next to the fuse. I have continuity between 2 wires. What should I have between the other 2?
Unplug the dryer, and remove one of the wires on the white fuse next to the 4 wire thermostat. If there is continuity on the fuse, then check the door switch. You can do an audible check just by pressing the button in or moving the lever in, which ever you have. Make sure that the motor is not covered with lint as it could have shut off thermally which takes about a half hour or so to reset if it has no air flow. Depending on the model, ( you never stated or the age ) there is another fuse that could be out also that needs checked. The things on this circuit that makes it run are, the wall outlet, the cord, the timer, door switch, internal fuses, the motor and wires, which could be burnt or chewed or simply loose.
Mar 31, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
78 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
