Question about Intel Motherboard
I have msi board G31TM-P35 and cannot install windows xp gives me a blue screen with error pci.sys
  • 67 Answers
Hi.
You need to have a Windows XP disk with ServicePack 2 on it.
Posted on Feb 04, 2010
Ms 7529 versin 1.6 audio driver version 1.6
please go to this link and supply all information to continue to download your driver.
Support For G31TM P35 MSI Canada Motherboard The world leader in...
May 07, 2014 | MSI 7529-050R Motherboard
Msi p35 neo2 supports boot from pci express with revodrive 24ogb ssd?
Hello here is the home page:
http://www.msi.com/product/mb/P35-Neo2.html#/?div=BIOS
Why not connect to the sata drive ports ??
I have not heard about booting from pci express.
Pci express is a screen card slot.
Jul 07, 2013 | Computers & Internet
I need MSI desktop ms7529 mother board audio driver
copy and paste the following URL in your browser
http://exehub.com/msi-g31tm-p25-msi-ms-7529-ver-1-6motherboard-drivers/
you will find all the drivers for Graphic (VGA), Sound (Audio) PCI Ethernet (LAN) and Chipset for this Motherboard for Windows xp, Vista and Windows 7 for 32 as well as 64bit versions. you will need to save the zip file and then extract the same using any tool like alzip (download link) http://www.altools.com/Downloads/ALZip.aspx and then install the drivers and restart the system for the changes to take effect.Good Luck
Feb 06, 2012 | MSI Computers & Internet
I'm installing XP till Windows 7 comes in the mail. I can't get to the load screen where it gives me the option to install after the CD is done loading the generic drivers. It either stops...
did you check to see if your board can be used for that system first some boards can not use those systems.check harddrive for format format drive then reinstall system ok jim
May 15, 2011 | MSI 880GME43 Motherboard
Windows XP setup problems
Hi
Remove any PCI devices in your computer and replug the memory card from the motherboard.
Start again the windows installation.
Hope it helps..
Thank you for reaching Fixya
Apr 01, 2010 | Intel Motherboard
Xp
Hi There,
I just experienced the same problem you did concerning the partmgr.sys blue screen error. I am installing Windows XP Pro SP2 on a pretty old Dell Latitude LS (upgrading it from Win 2000). The XP installation disk gives me the option to format in NTFS, FAT, and both formats in a "quick" mode. I usually do not recommend using the quick mode, however, after trying both NTFS and FAT and receiving the blue screen, I decided to try NTFS (quick). That has allowed me to actually get further into the installation, so you may want to try that.
May 27, 2009 | Microsoft Windows XP Professional
Blue screen when trying to install o/s from cd.
Not a lot of help here, other than to suggest it's caused by some hardware or driver conflict, but see this ms article. You could try then, this link to stop error codes, and these MS links here and here
I suggest you google "0X0000007E + pci.sys" and read the forums to see if someone out there has a solution...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 04, 2009 | Gateway GT5220 PC Desktop
Error code
Apparently the XP Pro CD you are using is pre-SP2, thus causing the error. With XP RTM and SP1, you need to supply the proper SATA drivers for the chipset on the motherboard since there is no built-in support for SATA drives. You can download the drivers from http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=2214&areaid=2&LanID=0
During the XP setup you will need to press F6 to install these driver before attempting to copy the XP files to the drive. Or you could make a custom XP CD using the directions at http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html that has these SATA drivers already slipstreamed into the installation procedure.
Or if you know someone who has the WinXP Pro SP2 CD, you could borrow that for the install.
Apr 07, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Blue screen error for windows xp prof
your operating system disk has a scratch or dirty, messed up data and has not installed the file
reinstasll
new hardware that fails will cause blue screen
Oct 16, 2008 | Biostar 945GZ-SE Micro Socket 775...
ECS 945GCT-M/1333 System Board
I can see you getting an error with pci.sys but not with pcy.sys.
Did a full system scan in a working WinXP Pro & found not such animal within the system or regestry. After looking through microsoft I did come across pci.sys and what may creat such an error. I would point to your onboard VGA. If intergrated into the board as I suspect. It is a pci device. During install windows found something wrong with it hence your error & blue screen. Suggest using your PCIE card & set bios to same disabling the VGA. Your install should no longer fail.
Good luck & please vote!
Jan 12, 2008 | ECS 945GZT-M (V1.0) Motherboard
Intel Motherboard Logo
366 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
