Question about Kitchen Ranges
Excessive running noise
Is there an obvious cause for the Stanley Superstar to be very loud (roaring) in use - and is there a practical solution
  • John Rodgers
    John Rodgers May 11, 2010
    its this gas range lp or ng
  • 149 Answers
Yes there is. i take it that it is an oil fired pressure jet.
the fuel pump pressure needs to be set at 9 bar. run it for 10 mins and fit gas analizer to flue. ajust air to return 11% co2 and lock off you will find that the roaring has gone.. it needs a service by an oftec chap
Posted on Mar 27, 2010
My 97 chevy k 1500 makes a loud roaring noise and feels like front brakes are being applied only in 4hi or4lo any idea s
Jack up the front wheels and check for loose play in the hub bearings. Excessive play in the bearings allow the rotors to ride at an angle against the brake rotor creating drag. The roaring is the bearing itself that has failed.
Feb 26, 2015 | Cars & Trucks
Whats making my 1999 mercury sable make a loud roaring sound while driving? and sometimes it stalls when stopping or slowing down.
Used tires sometimes are used for a reason. Also make sure your brakes are releasing completely (especially the emergency brake)...sometimes over-tightening wheels on to the disc brakes can cause excessive noise.
Feb 02, 2015 | 1999 Mercury Sable
What could cause loud roaring sound from right front?
front wheel bearings make loud roaring or whining noises when failing
Aug 11, 2014 | 2005 Honda Civic
Front right wheel making loud roaring noise
Hi Linda
loud roaring noise means the wheel bearing failed and have to be change.
Good Luck
Mar 26, 2014 | 2000 Chevrolet Impala
Dryer is making a loud roaring noise when on but still works fine
Hmp..Maybe there's a part of the dryer need to be fixed.. Make sure to contact the service provider of that product,,k
Jul 15, 2012 | Kenmore 800 7982 Dryer
When driving my 2000 Olds Bravada, it has a loud roar noise that sounds like when a semi truck is taking off before the gears are shifted. Transmission shifts easily into gears, just this loud roar noise...
If there's a loud roaring noise all the time, then your muffler probably has a hole in it, time to get a new full or partial exhaust pipe.
If the noise goes when it changes gear, then you've probably got a gear box or thrust bearing problem.
Apr 22, 2011 | 2000 Oldsmobile Bravada
What would cause a loud roaring in the back seat of my 2001 Monte Carlo as I am driving?
That roaring noise should be a wheel bearing. Jack up the rear wheels and spin the tires by hand. You can hear a grinding noise if the noise inside the car is as load as you state.. The only other noise that will be like that is the differental gears inside the drive axle
Mar 28, 2010 | Chevrolet Impala Cars & Trucks
Loud "tire or wheel" roar on the highway
I certainly would take it back to the shop that performed the brake job and have them investigate. If it was not making the noise prior to the repair there is a good chance the noise is involved with the brakes. A possible loose brake pad, a sticking caliper(caliper pins may need to be lubed) or any number of things could be wrong.
Jul 04, 2009 | 2003 Ford Explorer
Roaring noise during spin cycle
The roaring noise is from the drum bearing and it will only get worse with time until it fails completely. You will need to replace the rear tub assembly which is about $300 for the part. The rear tub assembly part number is 285984. It will take about 2 hours in labor.
Make sure you are using HE (high efficiency) detergent and only about 2 tablespoons per load.
Mar 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kitchen Ranges Logo
136 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
