The LAN was off after it sleeps. The machine won't wake up. have to turn power off/on. No internet, no local area network. Thanks!
krihard
  • 407 Answers
SOURCE: network
hii you conect net server pc . all pc conect in switch ..then your name all pc diffence .. and net conect server pc then go net conection dailbox properties ..networking ....enabil network conection then so server pc auto ip address....apply ok  done
Posted on Jan 28, 2008
SOURCE: Network Adaptor not waking on LAN
Hi
I have tried all of those mentioned above and the problem still persists.
Posted on Mar 26, 2008
  • 108 Answers
SOURCE: cant download torrents off local area network
I suggest using a different bit torrent application.
Utorrent is a very good one. For best results with torrents. Set ur ip to the DMZ in the router
I can explain further, once I understand whats actually going on.
G'luck
Posted on Oct 23, 2008
SOURCE: Gateway 505GR not showing LAN line for internet
I have the same problem from the same situation ( a storm ) but in device manager i dont see network adapters in the list
Posted on Nov 17, 2008
  • 4 Answers
SOURCE: limited or no conenctivity using the local area network
run cmd, type in the command prompt window " netsch winsock reset "
automaitcally teh dhcp will be reseted... then type again on command prompt window " registerdns " then rebooted pc and test internet connection..
Posted on Jan 15, 2010
Testimonial: "it was resoved myinquiry.. thanks to this tropuble shooting steps"
What does the LAN do on the modem
There are two halves to a router. The internet (WAN) side a local network (LAN) side.
The term WAN means Wide Area Network and generally refers to the internet.
The term LAN means Local Area Network. That would be for the computers that are in your office or home.
The LAN connects your computer to your printers or to other computers.
I hope that answers your question!
Jul 02, 2014 | NetGear WNDR3300 - RangeMax Dual Band...
Wake on lan not working
I'm not sure what is your problem the WOL or no connection icon after sleep
Jan 09, 2014 | ASUSTeK COMPUTER Asus M5a99fx Pro R2.0 -...
HP Pavillion a6230n Desktop PC sleeping mode is not working properly. After it entered into Sleep mode, it will keep waking up as long as the Internet cable is plugged in. Any other computer can sleep...
Click on Start, Control Panel, Network Connections, Right click on local area connection that is connected and click properties
Under networking tab, click configure. New window opens, then click on last tab power management, take check mark out of "Allow this device to wake the computer" then click "OK"
Nov 30, 2010 | HP PAVILION A6230N DESKTOP PC
Apple mac will not stay in sleep mode
Make sure you do not have wake up on lan enabled in the network settings a good way to even do this is unplug or disconnect the thing from the internet. Wake up on land will wake the computero ut of sleep mode each time a packet is delivered to it.
Thanks I hope this helps.
Dec 13, 2009 | Apple iMac G5 MA064LL/A Desktop
Can't put computer to sleep, again
go to your desktop right click then properties go to screensaver then click the power then you will see the power options properties click the hibernate then enable it clik ok then ok again
Aug 10, 2009 | Compaq Presario SR5712F PC Desktop
When i put my computer to sleep, it will just wake itself up again shortley after, model is compaq presario SR5712F
Is it on any form of network ?
If so then there is a good chance you have "wake on lan" enabled or some other wake up application running.
Aug 09, 2009 | Compaq Presario SR5712F PC Desktop
DSL connection
This could even be the Dsl modem loosing internet sync, They will tell you its you're end and thats fine check the modem, it also could be the ethernet cards going into standby Thus turning off the wake on lan feature in bios or other software would provent the card from going to sleep.
Jun 26, 2009 | Dell Ethernet Card Network Adapter
Computer not sleeping in sleep mode.
One possibility is if you have an optical/laser mouse that is on a relective surface and the mouse light is reflecting and triggering the computer to think that there is activity.
More than likely, your network card is keeping your computer from staying in sleep mode as any internet data activity is taking the computer out of sleep mode making the computer think there is activity.
There is an option in the Network Adapter properties that says to "Allow this device to wake up your computer"
Go to Control Panel and click Classic View on the left hand side
Double Click the Network and Sharing Centre Icon.
On the left hand side of the window that opens, click Manage Network Connections.
Right Click on the connected Network Connection. It is probably the Local Area Connection. Right click on it and choose Properties
A new box will open up. Click the Configure button under the Connect Using: box
Click the last tab at the top that says Power Management.
Under the Power Management tab click the square box that is beside: Allow this Device to Wake the Computer to take the checkmark out of the box. Then Click OK at the botton and close all the windows.
Let the computer go into Sleep mode and see if the computer still comes out of sleep mode on its own.
Let me know if this worked for you,
Ry
Apr 03, 2009 | HP Computers & Internet
Dell Inspiron 1525 with Vista
I'm out for the evening, but I'll be back tomorrow morning. Leave the info and I'll get you a solution.
Jun 20, 2008 | Computers & Internet
P5rd1-vm vista internet problem
Go into BIOS and find the wake on LAN option and turn it off.
otherwise check via configuration and select properties of your network card and check if wake up is checked. Ifso, uncheck it and restart.
Jun 02, 2008 | ASUS P5RD1-VM Motherboard
k24674
