Question about Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo
Will not turn on with remot and turn on button is
Will not turn on with remote and turn on button is broke - older model HELP. PITCH IT?
Is there a way you can power it on, by pressing hard on the button? The get a new Universal remote and program the TV.
Otherwise, it might be time to get a new TV.
Posted on Feb 04, 2010
Samsung LE32C450E1W TV remote control stopped working, changed batteries no luck, turned off at power source for 30 min which fixed prob temp but has happened again and now turn off doesn't help....
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside its battery compartment. If these do not help you, you remote control need cleaning. If you wish to know more about how to clean and repair a remote control check this site. Pull up older posts. One among it has details.
Mar 24, 2013 | Samsung TV Remote Control
I bought my car used with an aftermarket prestige alarm w/ remote start. Battery and alternator went bad. They have been replaced. The car will not turn on and alarm remote is not working.
Locate a black push button switch under the dash or near the drivers side kick panel (older model), or the alarm has a push button LED light(newer model) or the Valet switch is in the antenna(newest model). Turn the ignition on, press and release the switch one time. This should disarm the alarm.
For programming: turn ignition on, press and release the valet switch three times: you will hear one chirp from the alarm, press the lock button on the remote. Press and release the valet one time, you will hear two chirps from the alarm, press the unlock button on the remote. Repeat as necessary. Turn igniton off to exit programming. Test remote for proper functioning.
Jul 16, 2011 | Prestige Appliances Vehicle Parts &...
I have an older model sansui tv with out original remote. Somehow captions were turned on and I can't figure out how to turn them off. Help asap!
Ur tv have a button that said Menu on the bottom tv beside buttons only said POWER,CHANNELS + -,VOLUME + - ?Used the tv menu button go through the options functions look for Close Caption find CC 1,2,3 or TEXT 1,2,3 turn it all off,will stop captionning,if tv have no Menu option button.The captionning can be turn off by an original remote only.Try website like Remotes.com to buy the tv original remote.
Apr 27, 2011 | Televison & Video
I have a bose lifestyle 28 system purchased back in 2003. The remote broke when it was dropped on the floor (no longer functions). Is it possible to repair the remote or buy a replacement for this older...
Exactly how "broke" is the remote? (pictures help here, but if you don't know how to post one, or how to keep it under 150KB in size, then be as descriptive as possible in a REPLY to this post.
Feb 27, 2011 | Bose Lifestyle 28 System
My GPX DV1020 remote will not turn on the dvd player. Can you help?
be sure your remote is ok. check the remote as follow:
-use a pocket radio that is set/tuned on AM-frequentie band.
-hold the remote near the receiver of the radio while pressing every botton one by one
-you should hear a high pitch sound if the remote is ok
-when all botton do the high pitch that means the dvd IR-receiver is bad. usually it can't be, those are tough....
if you dont got the pitch the remote is bad. test especially the power botton of the remote.
If it is the remote please write back. I will show you how to do some simple actions to get the remote back going..
succes
Aug 29, 2010 | Televison & Video
I got an older rca 36" t.v and the remote broke. how can i switch from vcr to dvd without the remote
Most TVs have a manual button on the TV itself which allows you to switch inputs, you just have to find the sequence. You can replace your remote by buying a universal remote (Wal-Mart $10) and coding into the remote, your TV brand and model using a supplied chart that comes with the remote.
Aug 12, 2010 | Televison & Video
Hi guys i own a xregseat toledo 1.9tdi se mk2
either the lock mechanism is broke or the vacumn pipe is broke that lead into the door to operate the lock but this is only on older models .That have a pump in the boot
Dec 04, 2009 | Volkswagen New Passat Cars & Trucks
Need a remote for philips 43pp92 0217 rear projection tv.
Here's a link to order the original Philips remote control for this model (43PP920217) from a major parts distributor:
Philips 43PP9202 17 Replacement Part Remote Control
Feb 17, 2009 | Philips 43PP9202 43" Rear Projection...
Door opener remotes not opening garage door.
You have to sync the remotes to the new code. For older remotes, you can open the remote and match the pin settings.
For newer remotes there's a button that you push in the back of the opener that sets in program mode (for Chamberlain). When you push the remote button, it will acknowledge the remote is programmed.
If this doesn't help, comment back on your particular model and we'll help you with the solution.
Jan 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo Logo
125 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
