Question about HP LaserJet 3030 All-In-One Printer
Hplj 3030.. fax set up
How to set up auto receive fax tone???
  • Anonymous Feb 28, 2008
    prints 2 blank pages before the actual print
  • chooi ling May 11, 2010
    I am unable to receive despite there is a incoming fax ringtone. Fax log show comm erro 252. Kindly advise how to rectify the problem. Tq
    Habit-Forming:
  • 131 Answers
Paste the link below in your browser
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=378056&taskId=110
Posted on Jul 16, 2008
How do i set my fax machine to recieve and send faxes
Dear
Connect the telephone line to the LINE socket of the fax machine and a telephone receiver unit to the EXT socket of the fax machine.
To send a fax, put the document on the platen glass (face downward) or face upward in case of ADF.
press on hook dial, (here the dial tone on machines speaker)
dial the fax no. ( wait for call connection and here the fax Rx. tone)
press START.
To receive a fax two procedure can made, manual- lift a hand set of telephone receiver on incoming ring, here the TX tone(periodical beep tone) press * 9 * of the telephone receiver. In auto mode go to fax setup select ans. to ring or auto fax etc. to activate atuo reveive of fax.
Hope this may helpful.
Thanks.
Aug 11, 2014 | Samsung SCX 4521F All-In-One Laser Printer
The fax dosn't work,what should I do? I don't have ring tone, and can't receve.
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
May 14, 2012 | Brother MFC 240C All-In-One InkJet Printer
HPLJ 3030 "Scanner Error -
Hi, unplugged its data cables for two hours. It exists inside the printer right or left hand depends on model. After two hours replug and you will see that your problem will have been fixed.
Best of Luck
Aug 28, 2011 | HP LaserJet 3030 All-In-One Printer
Can't receive faxes
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 22, 2010 | Brother Office Equipment & Supplies
HP laserjet 3055 Have dial tone. With phone can call out and receive calls. When sending fax keep getting Result: No answer
Mar 13, 2010 | HP LaserJet 3055 All-In-One Printer
I have an HP Lazerjet Model 3030. Recently I have
Here is a link to Hp for your Laserjet 3030. Look under Troubleshooting Fax Codes and Trace Reports. Click on 'Fax send and receive codes'. Scroll down the page to locate each code that you mentioned. I suggest calling your fax number from a cell phone to see if the fax line is clean (doesn't have any noise or static other than the "handshake digital tones") If it does have other NOISE....have the phone company check your fax's phone line for troubles. Let me know.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=378056&prodTypeId=18972&prodSeriesId=378056&objectID=c00062808#A5
Nov 18, 2009 | HP LaserJet 3030 All-In-One Printer
I Have a HP LaserJet 3030 Printer works Copier works Fax and scanner do not work
Have you loaded the drivers and set up your fax ie name number etc tone pulse. fi you have done this. then you will need to delete driver and reload.
Oct 10, 2009 | HP LaserJet 3030 All-In-One Printer
Can not recieve fax. currently just hooked to phone line
Receive a fax
Depending on the Auto Answer setting, your HP All-in-One can receive faxes
automatically or manually. If you have set the Auto Answer option to Off, you will
need to receive faxes manually. If the Auto Answer option is set to On (the default
setting), your HP All-in-One will automatically answer incoming calls and receive faxes
after the number of rings specified by the Rings to Answer setting. (The default
Rings to Answer setting is five rings.)
Receive a fax manually
If you set up your HP All-in-One to receive faxes manually (the Auto Answer option is
set to Off) or you answer the phone and hear fax tones,
1. Make sure the HP All-in-One is turned on and you have paper loaded in the input
tray.
2. Remove any originals from the document feeder tray.
3. If you are currently on the phone with the sender, instruct the sender to press
Start on their fax machine.
4. When you hear fax tones from a sending fax machine, do the following:
a. Press Fax on the control panel of your HP All-in-One.
b. When prompted, press 2 to select Receive fax.
c. After the HP All-in-One begins to receive the fax, you can hang up the phone.
Jan 14, 2009 | HP Officejet 5610 All-In-One InkJet...
HP LaserJet 3030 All-In-One Printer Logo
497 people viewed this question
Ben Johnson
