Question about Vizio L32 32 in. LCD HDTV
My vizio just stoped working all of sudden. When i turn on the vizo insignia lites up but screen is black. Could my backlite be bad or is it some kind of proccesor?
  • 148 Answers
No, I'm 95 percent sure it is a power problem ieThe caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!If this helped you (or not) please rate, thank you!my vizio just stoped working all of sudden. When i - 069fc34.jpg
Posted on Feb 04, 2010
Testimonial: "right on man! that dose help. I'am an Refridgeation tech and I've repaied many units that a simple cap was bad.I'm going in!let u know how it trnd out"
Vizio e470i-a0 black screen no video only sound
These have problems with the leds,but there is a power board that is made better for that tv,not as many failures. Part#0500-0612-0300.if backlites are bad, trash tv.
Dec 16, 2017 | Vizio Televison & Video
I have a 32 vizio e320-a0 with a black screen with sound
probably the tv have problem with its back light, you have to check and replace the led driver. Che the video to more about back light.
Samsung TV Repair Part Number Identification Backlight Inverters LED...
www.electro-medical.blogspot.com
Sep 21, 2015 | Vizio E-series E320-A0 - 32" Class 31.5"...
Vizo tv comes on with white screen then shuts off
screen should be black with a dim back light than go to video you may have a short in the panel
Jan 31, 2013 | Vizio VA220E LCD TV
My vizio screen went black. What do I do?
Start by clarifying which Vizo model do you have.
it's written on a label at the back of the TV.
Jun 05, 2011 | Vizio Televison & Video
I have a Vizio VW42LFHDTV10A -- The first time I
Please check for bad electrolytic capacitors on both main board & power supply, if there is any "pup-up" one, replace it (them).
Aug 15, 2017 | Vizio GV42L 42 in. LCD Television
My vizio vx32L turns on but only a black screen shows up
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Sep 30, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
The price for a screen
Vizio does not, on the whole, provide panels for repair.
You will need to purchase a new set (or, if you have an extended warranty or manufacturer's warranty, a new set will be provided to you at no cost).
Aug 01, 2009 | Vizio L32 32 in. LCD HDTV
Vizo GV42L HDTV Only a blue screen when I turn
look for "blue filter" in your setup and turn it off
Jun 26, 2009 | Vizio GV42L 42 in. LCD Television
Vizio L32 32 in. LCD HDTV Logo
537 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
