X1155 printer power button blinks; printer won't print.  have uninstalled and reinstalled and still won't print; queue appears to be running; won't scan
    Genius:
  • 1,019 Answers
If the power button blinks. It usually suggest that:- there may be faults with the printer itself. uninstall the driver-software. and setup the printer again. check for paperjams and also ink-levels.
ensure that all leads are connected correctly. and you have the most up to date drivers available for that model.
hope this helps.
Mike@Compurepair.
Posted on Feb 20, 2008
Not communicating
try to clear printing queue in both printer and cpu. Also try a different cable.
Feb 14, 2015 | Lexmark X1155 X1155 All In One Inkjet...
Print queue shows jobs stacked well after jobs printed
Best is to uninstall printer from computer and reinstall it again. Worked for me.
Jun 07, 2017 | HP Officejet 7000 Wide Format Printer...
I have a Lexmark S504 wireless multifunction printer. I can print a test page but a can't print anything from any application. The Windows print page window comes up and if you click OK it appears to...
It could be a printer driver issue. Please follow the steps below to fix the problem.
First, clear the print queue from any stuck print jobs. You can do the steps mention - going to Services and stop the print spooler, delete the files in the spooler folder and then restart the service.
Second, delete the existing Lexmark Interpret S405 printer driver. On your computer, go to Start menu > Programs > Lexmark > Uninstall. After the uninstall process, reboot your pc when prompted.
Third, visit the Lexmark website to download and reinstall the Lexmark Interpret S405 printer driver. Select the version of your Windows operating system. Download and execute the file. Follow the instructions on your computer screen.
After the reinstall process is successful, try to print again to verify that the problem is fixed.
Sep 07, 2011 | Lexmark Interpret S405 Wireless All-in-One...
My lexmark Z2320 printer will not print. It places jobs in queue but still will not print. The green power light constantly flashes quickly once turned on. I have tried unplugging the printer from the main...
The flashing light on the printer indicates there is a problem. Make sure there is no paper jam or cartridges are properly installed. Disconnect the printer from your computer. Remove the sheets of paper from the printer. Open the printer cover and remove the cartridges. Close the cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert the cartridges (make sure the cartridges still have ink in them). Close the printer cover and check the power light. If not blinking, proceed with loading of paper. Reconnect the printer to your computer.
Make sure the print queue has no pending print jobs before sending another print job.
Jun 18, 2011 | Lexmark Z2320 InkJet Printer
Keeps printing copies of what i copied last week and won't copy what i want this week
((make sure you have the printer turned off)) otherwise you it might print another page if you have multiple prints in the queue you will have to open a file that you are about to print click ok a page will open with a display print queue tab you can see all prints right click on the ones you don't need select cancel
it will be in the print queue where you can stop it printing right click to delete what you are printing you might have to uninstall the printer then reinstall to adjust your print settings
or just go into your printers settings to alter/change the settings
hope this helps
Jun 12, 2011 | Computers & Internet
My hp jeskjet 1560 is not working because the green light is blinking when i am on my printer it is continue blinking.pls.... some one help me
Your printer is keeps on blinking maybe because theirs a lot of pending documents pending in queue. Please follow these instructions on how to clear it.
Please check the following before you go and proceed to the troubleshooting:
  • Make sure that the computer is on.
  • Make sure that the USB cable is connected to both device (your printer & computer)
  • Close any open applications on your computer. (Microsoft word, power point excel & etc.,)
Solution #1 Clear the print jobs
  1. Download the "HP print diagnostic utility" click here to download.
  2. After downloading the tool, (print diagnostic utility) save it to your computer.
  3. Run the tool, then select the printer that your using, then start scanning the problems on the printer.
  4. It will tells you if theirs a problem with the connectivity, ports, print jobs stuck in queue and etc.,
  5. If the problem appears, theirs should be a "Fix" button available or "uninstall the driver".
  6. If theirs a fix button, clink on it to fix the issue, now if its telling you to uninstall the driver.
  7. Restart the computer, then if you have to computer boot up and running again. Install the driver for the printer. To get the latest driver that suites to your computer click here.
  8. It will ask you to select your operating system, (win xp, vista or 7) then click on next. Now it will ask you what software do you wish to download, click on "Drivers" then look for "HP Deskjet full feature software and drivers" click on it.
  9. Download the software and save it.
  10. Run the software and install it.
If you have the printer working, you don't need to troubleshoot further. If you are still having problem, continue to the next solution. Solution #2 Power cycle both devices (printer and computer)
  1. Turn off the printer by pressing the power button
  2. Unplug or disconnect the power chord at the back of the printer.
  3. Completely shut down your computer.
  4. Wait for 1min.
  5. Plug the power cable back in to the printer, then turn it on.
  6. Try to print something on your computer. It should be working fine now.
If your still having same issue, you now need to service the printer. contact HP's printer support department to have your printer trade in @ 1-800-474-6836.
Good Luck :)
Feb 04, 2011 | HP D1560 Deskjet Printer InkJet
I cannot uninstall my Lexmark printer model X 4580 because I have to delete print job. How do I do this on my new Macbook/Pro?
You can uninstall printer driver from library folder.
Go to system preferences and delete driver from Library /Printer .
Delete that folder then your printer driver is will uninstalled then reinstall the driver if you want to use it again.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 20, 2010 | Computers & Internet
Queue problems and spooling.
By uninstalling and reinstalling the printer software.
Jan 21, 2010 | HP Photosmart D5069 InkJet Printer
Lexmark C1150 printer doesn't print
First I try to uninstall the printer, it didn't work, so I reinstall the the printer anyway, it worked for one print only.
As second attempt I disconnected the printer completely, turned the PC off, and after few minutes on again. Uninstalled printer.
Reconnected the cables again, install the printer - it works well!
Dec 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
Aligning Print Head Alignment
Try printing a diagnostic page without the PC, if it prints normal then the problem is on the PC, probably drivers or possibly the printer queue configuration. If it prints the same faded fashion then I would suspect defective or clogged inkjet nozzles. Warning, be very precise with the buttons you push, you are entering the printers diagnostic mode and you can cause problems if you push buttons out of sequence or if you push them too many times. - Start with the printer off. - Hold down the resume button and then hold down the power button - Release the resume button - Press the resume button twice, then release the power button. - Let green light blink while the printer enters the diagnostic mode. - When the printer is done press the function button once to enter the print diagnostic page mode, then the power button once to start the job. - When the page finishes press the power button once to exit the diagnostic mode. Let us know if you have any other questions and please don?t forget to rate the posting.
Jan 14, 2007 | Canon i850 InkJet Photo Printer
87 people viewed this question
jasbo
jasbo
