Question about HP Photosmart C5180 All-In-One InkJet Printer
Scaner print looks like bar code - HP Photosmart C5180 All-In-One InkJet Printer
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 73 Answers
Replace your usb cable
Posted on Feb 04, 2010
After scanning a bar code I need it to enter and go to next row in excel
This can be possible, therefore it is not an Excel setting. You would need
to use the software that comes with your bar-code reader to configure this.
Try looking in your bar-code reader documentation for "Append Enter" or
"Append Carriage Return"
May 21, 2011 | Symbol LS 4000i Handheld
Tip
How to change settings on a barcode
<p>Barcodes can be printed symbols encoded information printed in black and white contain. You can use bar codes entering data into bar code - the generation of the image software and print barcode using a normal printer or a barcode printer. Printed bar codes are read by a barcode scanner that reflected light rays used to decipher the code. Bar codes may contain different information. You can change or a bar code can be adapted by entering the information reviewed in the bar code - generation software. <br /> <p><br /> <p>1. Access your favorite browser and go to barcode generator, barcode, bar code or soft (see Resources) can use a free barcode - generation software. <br /> <p><br /> <p>2. Most sites that offer bar code - generation software to present their application interface on their own pages. Enter the information reviewed or custom code in the space you want, and "Generate Barcode" button to click to create barcode images. <br /> <p><br /> <p>3. See the image of the barcode displayed on your computer, click on the image to pop-up menu to display. Click "Save Picture As" from the pop-up window, select the location where you want to save the image and click "Save" next window to save the image in the selected folder. <br /> <p><br /> <p>4. Connect the cable to patch your bar code scanner in its corresponding port on the back of your computer. Keep the scanner about six inches from the printed barcode, which focuses on the barcode and press the button to scan the bar code. Look at the revised data upload to your computer and check its accuracy. <br />
on Jun 26, 2011 | Computers & Internet
Tip
How do I create custom Barcodes?
<p>Barcodes can be printed symbols with encoded data will be charged to the computer via a scanner. A bar code allows a company to maintain control of their actions to secure and instant access to information about each product. A bar code is created using software barcode generation software. Customizing a bar code is a simple process to enter your data into the software program, and print.<br /> <p> <br /> <p>1. Open your Web browser and visit Barcode Generator, barcode or Soft. See the program's interface is usually presented on the homepage of the website page. Look at the list of different types of bar codes available, and click the type of barcode you want to use. <br /> <p><br /> <p>2. Locate the area where you are allowed to present the information is converted into a bar in, and within the data type. Click "Generate Barcode" to create barcode images. View the image resulting bar code, right click on the image and click "Save image as" in the drop-down menu to save the resulting image on your computer. <br /> <p><br /> <p>3. Close the program bar code generation, and open the bar code image stored on your computer. Right click on the saved image and click "Print" from the output drop-down menu to print the bar code. Scan the bar code information printed to be loaded on your computer and check the data sent to make sure it is correct. <br />
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit &lt;Enter&gt;? Thanks, -john
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
Apr 06, 2011 | Symbol Spark LS 1004
HP LASETJET 3050 ALL IN ONE IS COPY THE PAGE IS LINES HOW TO RECTIFY
Try to print something out ( like report or similar ) and if the print is fine that means that you have some dirt on scaner, clean scaner verry well with moisturized cloth and dry it after.
If the lines are also on print that means that you have to replace drum ( toner crg. ). To be sure that is the drum problem, remove it from the macine and on green long roller ( drum ) look for lines. If there are lines, change it.
Use genuine crg. - allways
Jul 17, 2010 | HP LaserJet 3050 All-In-One Printer
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
When making copies or scaning there is a line that apears on the top, that goes all across the page. how can i fix this? when printing from the computer i.e. microsoft word or printing anything from the...
please your have a scaner use. then open the top pad and put the object in scaner and take atake object the job. you start a scaner then
select to general mode and coloue and dpi select and start a scan and put the object in your word page . and scan object is page in please and give a print and pgae celect to us. and is ok
Sep 24, 2009 | Epson Stylus CX7800 All-In-One InkJet...
Symbol LS 9100 does not transmit data
Have a look at the HOST setting in your defaults. I set one of these to default and had the same result. I'm guessing it's because the HOST is blank on Default settings.
Feb 07, 2009 | Symbol LS9100 Hands Free
My dell a920 printer/scaner will not scan
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Jan 29, 2009 | Dell A940 All-In-One InkJet Printer
Prints what looks to be bar code
I have the same problem. I have replaced both toner and photoconductor, did not solve the problem. I have been using XP for some time before my printer started acting up.
Feb 21, 2008 | NEC SuperScript 870 Laser Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
