Question about Toshiba 57H81 57" Rear Projection Television
Shut off F850 repeatedly keeps blowing out. Replaced vertical output and convergence output, and again keeps blowing out.
  • 301 Answers
Make sure that you check for any cracked solder. and check all bridge rectifiers
Posted on Feb 21, 2008
Your tv might have a defective power supply, and/or convergence circuit. The initial cause of the problem, if it is the convergence circuit, is usualy a loose conection on one or two jumpers close to the convergence output circuits (STK392-1110), in with case this chips might need to be replaced and a pico fuse of 5A on the power supply too. I hope this help you.
Sep 24, 2009 | Toshiba 56H80 56" Rear Projection...
I have a Toshiba 61H71 that keeps blowing F850. It was just sitting there the first time it did it. I didn't have a replacement fuse so I temporarly replaced it with a 3A glass barrel type fuse. This...
Resolder jumpers on signal PCB..May be near convergence IC circuit..on 50" model they are 050 & 010. You may have solder cracks..I repaired a 50" toshiba..Let me know if this fixes
Apr 15, 2009 | Toshiba 61H71 61" Rear Projection...
2004 Dodge 1500 blowing fuses
Replace the cigarette lighter. Look to find out what else is on the instument cluster circuit, as that may be the problem, or a bad cluster.
Mar 07, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
RCA R52WM24 52 in TV
the RCA service bulletin says to replace FL231, DL231 and CL230 all at the same time then reflow the solder on the flyback and the vertical output IC
Feb 07, 2009 | RCA R52WM24 52" HDTV Projection Television
Toshiba 57H81 Flashing Red Power Light, Blown Fused F850+F852
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
  • Upon turning on set I got flashing red power light and nothing else.
  • Removing plug for one minute and plugging in results in:
    • Audible click, steady red power light for 2 seconds then slow flashing red light
    • Pushing power button results in steady red for about 2 seconds then slow flashing red light, no other set activity
  • Removing power cord for several hours and plugging back in made no change
    • Audible click, steady red for about 2 seconds then slow flashing red light
  • Possible related note: Over past several months occasionally the entire screen would flicker momentarily and at other times be problem free for weeks.
  • Fuses F850 and F852 found blown
Repairs Made:
  • PD0074 DEF/CON Power Board
    • There are two main power supply capacitors in this set. They are C-809 and C-810. One their negative lead on the printed circuit board re-soldered leads and nearby contacts. I’m told that because the factory left out a printed circuit board eyelet, the connection will come loose over time. When I called Toshiba customer service they said there was a known solder joint problem causing blinking red light.
    • Replaced blown fuses F850 and F852.
      • I actually installed a fuse panel on the inside of the cabinet and routed the fuse connections here instead of ordering the special fuses and replacing them on the circuit board.
      • Had to use a 5 Amp SLO-BLOW for F850. Fast blow does not survive power up. Get the red blinking light.
      • Used a fast blow 2 Amp for F852.
  • PD0073 SIGNAL Board
    • Re-soldered Q751 + Q752 STK392-110 Convergence Amps
    • Re-soldered adjacent pads that looks suspicious
Total Cost to Repair about $10
  • Twelve hours of my time over three days to research issue, disassemble set, make repairs, add fuse panel.
  • Already owned Service Manual and Circuit diagrams from a different 2004 repair.
  • Less than ten dollars at Radio Shack for fuses and fuse panel. Already had wires, etc.
  • Some solder. Already owned de-soldering tools, etc.
  • Visited both local authorized Toshiba factory service repair facilities. One said repair would have to include replacing Q751 + Q752 STK392-110 Convergence Amps with ST392-180, and realigning set for a total of $500+ and it would be more if they had to order a power board. NO THANK YOU! Other shop said $65 for site visit and $30 to make an estimate that could be applied to repair.
Jan 04, 2009 | Toshiba 57H81 57" Rear Projection...
Projection TV keeps shutting off
Good Day, checho3435;
Try this to help to narrow it down:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Day, big IRISH. back.gif
Jul 30, 2008 | Mitsubishi WS-55807 TV
Burnt resistors
Depending on where you bought the ICs you could have fried the new ICs when powering it up with burnt resistors as the green is controled by both ICs one IC controling the horizontal green Convergence and the other IC controling the vertical green convergence. Have you checked all the convergence resistors out of circuit?
May 18, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Convergence amps can be upgraded from STK392-110 to
Hitachi brand STK394-160E Part # CZ 01341.....
+ Check B+ micro fuses F850,F851,etc.
+ solder bad connects on wire jumpers 008,010,017,048,600.
If you don't solder jumpers,you may blow fuse ( again )......T.
Let me know.............................
Nov 27, 2007 | Toshiba 42H83 42" Rear Projection...
No power, LED blinking, Low voltage regulator IC?
check for bad solder connections then check all fuses the ones that look like resistors too get back to me
May 22, 2007 | Toshiba 57HX81 57" Rear Projection...
Low voltage power supply fuses blown
If the convergence power supply fuses blew you can bet that the convergence ICs need to be changed. The blue connector will be pressed down on the rear of the connector to release or pulled up on the back end of the socket. Ps dont forget to rate this.
Oct 11, 2006 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
