Question about RCA F32650 32" TV
RCA 32" TV
I need to adjust the vertical size. I use to be a TV technician but I don't remember the service code to get into the service menu can you help?
    Scholar:
  • 104 Answers
Many RCA's use the following to gain access:
Hold the 'Menu' button while turning the set on.
The code may also be inside the back cover.
Posted on Mar 11, 2008
Zenith TV B27A24Z, Vert Size Adjust
To do this adjustment, you should enter the service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Service mode entry, adjust and exit procedure to many popular brand TVs are given.
Feb 27, 2014 | Zenith Televison & Video
Picture is to large for 27in
If model indicated here is correct either a problem in the Vertical circuit of the set or an adjustment.
Almost any shop can take the set into the service menu and adjust vertical size a bit to correct if not circuit problem.
Nov 02, 2012 | RCA F27636BC 27" TV
How to adjust vertical size my hitachi c29-r30sp
You could go into the user menu and look around to see if it has an adjustment. If not you will have to access the service menu for your tv. There may be a setting to adjust vertical size there. If that still isn't possible you may have to open the tv and look for a pot or a switch that can control the vertical adjustment. It may be by the vertical output circuitry. This could also mean that you have a defective component in the vertical circuit or inadequate voltage to that circuit.
Mar 11, 2010 | RCA F27440 27" TV
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
The picture is not sized correctly. The bottom of
Yes there is but you have to get into the service menu and its a risky business to go there without knowledge of these adjustment.In any case these adjust would be called vsize,vpos.Any local repairman should be able to fix that in 5mins. good luck
Nov 01, 2009 | RCA F32450 32" TV
Ctc 179 service program
No need for the answer I have the setup instructions for the rca tv. I am a tv and computer technician and always carry a sheet with these instructions as I work for company like Sears on tv, projection tv, audio and other electronics, thanks for the help.
Dec 30, 2008 | RCA G35831AT 35" TV
Acess service mode rca ctc197cw
hold menu button in. push power button once. push vol up once.
Dec 02, 2008 | RCA F32450 32" TV
Vertical Stretch
You need to adjust "vertical height" in the service program. You need to put the set in "service mode" to do this adjustment. If you google "enter service mode RCA F32665" you should find the procedure. It will be listed in abbreviated letters such as VERT SIZE or VERT HT. Follow the instructions for entering service mode and saving the data closely!! The data you change will be listed as a number between 1 and 63. The number will only need to reduced by a small amount and you can still see the picture behind the data and watch it shrink as you adjust the number down.Always burn the new number to memory (if required) before exiting service mode. Good luck
barneyluc
Dec 01, 2008 | RCA F32665 32" TV
Vertical adjustment
hold menu press power press volume up a p and d will appear use the volume up to change the value of v to 76 then you in but you require which setting to adjust i don't have them with me now but try this and see if you can get in first,.to exit press power button /
Nov 30, 2006 | RCA 32V550T 32" TV
Need access to service menu to adjust vertical size
No service menu for this set. Sounds like you have a bad yoke winding on this one....accordianman
Oct 25, 2006 | Emerson SpongeBob SquarePants TV
RCA F32650 32" TV Logo
151 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
