Question about Brother MFC 210C All-In-One InkJet Printer
How do get into maintenance mode without unplugging it?
How to get into maintenance mode without unplugging it?
  • 4,041 Answers
Hi
I have put a 2 PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Brother-MFC-210C-Users-Guide.pdf
Click Link= http://www.4all2sell.com/pdf/Brother-MFC-210C-FaxGuide.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 03, 2010
Printer unable to clean
This most likely means that the over flow tank is full. You can order a replacement tank but you have to disassemble the printer pretty far to get to it. You would also need to reset the counter so ..... if you want you can just reset the counter. Doing this without replacing the Ink Absorber will mean that once it is truly full it will leak into the printer itself. Do so at your own risk, but then again these are cheap printers....
Brother Maintenance Mode Commands:
- Quickly press Menu/Set * 2 8 6 4 to enter maintenance mode.
- Display should read maintenance.
- Press one or more of the maintenance mode commands below. After each command display should read re-init for a few moments then redisplay maintenance.
- Press 99 to exit the maintenance mode.
Maintenance mode commands:
01 Full RAM clear (see 91 below for retaining user programming)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
99 Exit maintenance mode"
I would use the 01 and reset everything. Otherwise you can go through the 91 parameter list till you find the counter.
Jim
May 11, 2011 | Brother MFC 420CN All-In-One InkJet...
Need to the baud rate how do you do it
Enter Maintenance Mode:
1. Unplug power from rear of Fax machine, hold the Menu button while plugging power back in. Continue to hold the Menu button until "Maintenance" appears in the LCD window.
2. There are no helps for the Maintenance mode. Follow parameter change procedures to the letter.
Changing Baud Rate from Automatic to 9600:
1. Enter 10 (one, zero). This will bring up WSW00 on the LCD window.
2. Change the 00 to 19. If the baud rate is set to automatic, the numbers that appear will be 11100010.
3. Change the 11100010 to 01100010. This sets the baud rate to 9600.
4. Press the "Set" button just below the LCD window.
5. Press "Stop".
6. Enter 99. This will exit Maintenance mode and make the fax ready to use again.
Feb 15, 2011 | Brother IntelliFax-4100e Fax
Hi, My office fax machine will not send or receive faxes, or make copies. I recently replaced the toner cartridge, and then the problems began. It keeps saying either printing online, or sending online,...
Sounds like a glitch in the memory has left a document there, unable to print. You'll need to clear it out by going into the Maintenance Mode. Maintenance Mode is not mentioned in your user's manual, because there are several functions available that can seriously disable the machine. All you have to do to be safe is follow these instructions to get into the mode, clear the memory, then get out without messing around with other functions.
Press these keys in rapid succession:
Menu
* (the star on the dialing keypad)
6
Do that whole sequence in 2 seconds or less, ignoring all the beeping the machine will assault you with. It's designed to not allow some to accidentally enter Maintenance Mode; if you wait for the beeping to stop, you'll fail, left in some part of the normal menus. When you succeed, the word MAINTENANCE will appear on the display, and all the lights will flash in unison. If that doesn't happen, just touch the STOP button and try again.
Once in maintenance Mode, touch 91 on the number pad. The display will say Initializing or something like that as it clears all the documents form the memory. Your programmed phone numbers and settings will not be affected. When it finishes it will go back to MAINTENANCE. Unplug the power for a few seconds, then plug it back in. The machine should be fine and ready to use.
If Function 91 doesn't work, you should try going back into MAINTENANCE and touch 01 instead. It will clear all memory back to the point it was when you first unboxed the machine. But I think 91 will take care of everything.
How do you clear message replace laser after replacement??
I assume that if you are skilled enough to dismantle this machine and replace the laser you know how to enter maintenance mode, if so press 8,8 while in m/mode to enter the parts reset area, follow bouncing ball.
To enter maintenance mode: press 'menu' '*' '2' '8' '6' '4' in reasonably rapid succession 'maintenance mode' will flash on screen, press '8' '8', scroll to part to replace blah blah, when finished press '9' '9' then repeat 'menu' '*' '2' '8' '6' '4' in reasonably rapid succession to exit m/mode and return to normal mode.
Note: if your machine is at the stage of replacing the laser (100k pages) then your fuser and paper feed kits will need doing also, if you are just resetting parts without replacing them i can assure you they will not do another 100k pages which means the machine will just fail massively without warning one day somewhere between 100k and 200k pages.
Hope this helps, Regards, Andrew.
Dec 08, 2010 | Brother MFC-8860DN All-In-One Laser...
How do i clear memory on the brother mfc 665cw
where is the sevice button on the brother mfc665cw
Oct 02, 2009 | Brother MFC 3220C All-In-One InkJet...
Replacing Brother MFC-8440 Fuser
To remove the fuser - remove the tray at the bottom and the back tray (4 screws, 2 either side) lift out the phone line box on the right (looking from the back - 2 screws) and swing it out of the way (careful as cable isn't too long) 2 screws either side of the fuser (long black object at the bottom) unplug the halogen lamp (white plug on left) and small 5 wire plug on right, and lift out fuser unit.
Aug 25, 2008 | Brother MFC-8440 All-In-One Laser Printer
Error code SC543
press .....clear modes 1-0-7 and hold clear/stop until the screen changes to service mode then unplug the machine and plug it back in and turn it back on Good luck
Aug 15, 2008 | Ricoh CL4000DN Laser Printer
M7310 displaying maintenance mode
Try unplugging the set from the jack, count to 10 and plug back in. This should request the programming from the ICS.
May 27, 2008 | NorStar M7310 Corded Phone
Maintenance code 7
Leave the maintenance mode by pressing 9 then 9. You need a new waistinktank first. You'll get one at a service partner near your home: search brother hompage for that.
Afterwards you'll have to assemble the printer and to change the waistinktank.
Afterthat you can reset within the maintenance mode (search error 46)
DO NOT RESET WITHOUT REPLACING THE WAISTINKTANK
Nov 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
166 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
