Question about GE Profile PDW8400J Built-in Dishwasher
My GE GLD5500 dishwasher has the Normal and Heated Dry lights flashing and the pump continues to run , but no water. I have tried the reset and turned the breaker off and no change in status.
  • polkshannon Feb 04, 2010
    Great advice I will give it a try. Thank you so much.
    President:
  • 2,468 Answers
You need to open up the machines control panel and start checking grounds,then you may also need to check for corrosion on all inner door,and lower motor/pump unit connections.,any high-resistance or corroded connections in the lower unit,grounds are a large factor in proper operation of the unit,corroded connections lead to signal backfeed looking for another ground path, even if all looks good upon dis-assembly STILL wiggle the connections as they can look good and hide corrosion
Posted on Feb 04, 2010
My delay light has come on and I cant get the dishwasher to start. The delay light goes out after the time has expired but if you try to move it to the start position the light comes on again
The Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). The Control will flash the Clean LED 7 times repeatedly and will disable the Start/Resume key until cleared.
To clear and reset the control press in this order: Heated Dry ? Normal ? Heated Dry ? Normal and then let the unit run for 1-2 minutes and then press Cancel and let the dishwasher complete the cancel cycle. The dishwasher should operate normally again unless it does not detect a temperature rise in the main wash cycle.
It could be caused by a Heater circuit problem if it continues to stop and flash the Clean light.
It could have one of the following failures:
Open in heater.
Open connection or component in heater circuit.
Faulty heater drive circuit on control.
It can also be caused by the wash pump not pumping water past the heater efficiently.
Oct 11, 2016 | Kenmore Dishwashers
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 18, 2015 | Kenmore Dishwashers
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Clean light is flashing. Dishwasher will not start.
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 29, 2011 | Whirlpool Dishwashers
Clean light "green" flashes 7
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or high temp wash-heated dry-high temp wash-heated dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 29, 2011 | Dishwashers
Control clean light keeps blinking and dishwasher will not function
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run your dishwasher as normal.
If this same light appears again then you have a bad element or thermostat.
Dec 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Green light on kenmore dishwasher is flashing
I actually had to change the steps a little and this is what I did:
press heated dry
press normal wash
press heated dry again
press normal wash again
wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Started a cycle and began washing.....Thx
Dec 31, 2008 | Kenmore 24 in. 16039 Built-in Dishwasher
Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Jul 02, 2007 | Whirlpool 24 in. GU3200XTP Built-in...
I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Jan 27, 2007 | Maytag MDB9600A Jetclean II Built-in...
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
GE Profile PDW8400J Built-in Dishwasher Logo
97 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
