Question about Jenn-Air JCD2389G Side by Side Refrigerator
My ice, water, and light quit working on my Jenn Air KSCS25FJSS01 side by side. I replaced the solenoid in the back but that did not do it. What else can I replace to get this to work?
    President:
  • 1,891 Answers
If the light quit working then i would look at the program board at the dispenser . mm
Posted on Feb 04, 2010
Jenn-Air Side-by-side Refrigeration not making ice and leaks water underneath when ice maker arm is up
With the arm up in the ice tray, the water solenoid valve should be closed. When the arm drops, that tells the ice maker to open the water solenoid valve to fill the ice maker tray. It sound like the leak is at the inlet side of the water solenoid valve. On some models its not easy to get to, but follow the water line to it. Hope this is it for you. Good luck.
Dec 30, 2013 | Refrigerators
Ice maker doesn't work. changed filter. light on ice maker door still on.
You need probably to change the dispenser solenoids which swith water on dispenser
Apr 05, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn air french door water dispenser broken
You have two sides to your 67006531 Dual Water Inlet Valve, so it is very possible the side that controls the water flow for the dispenser is defective. Replace the 67006531 Dual Water Control Valve and I believe your fridge water will work fine.
I will be here should you have more questions, Thanks Sea Breeze
May 20, 2012 | Jenn-Air JFC2070KRS Bottom Freezer French...
I have a Jenn-Air refrigerator #JCD2389DES. The ice maker became stuck and kept delivering ice cubes even after dispenser was released. I finally opened the freezer door and got it stopped. Now it...
Yes it could be either, BUT I would go back and make sure that everything you did to stop it the first time is undone. Is everything setted correctly? Is the switches in the right place?
Neither the solenoid or the microswitch could cause the problem you had before, so I would suspect something is not right with the ice maker itself.
Jun 16, 2011 | Jenn-Air JCD2295HES Side by Side...
Model JCD2389GEW - ice/water dispenser does not work. Until recently, it did not do anything on any of the settings (water, cube and crushed ice) now it crushes ice on all three settings but the door does...
We have a Jenn Air side by side, model JCD2389GEW. The ice dispensers work, the water does not. This started after I replaced the filter. I've checked and nothing is locked out. When you press the actuator pad to dispense water, you can hear a noise similar to a small pump which I assume is a solenoid attempting to open. Any ideas?
Oct 02, 2009 | Jenn-Air Refrigerators
WATER IS NOT GOING TO ICE MAKER. HAVE POWER TO ICE MAKER BUT NO POWER TO SOLENOID WATER IS TURNED ON
If there's not power to the solenoid when the ice maker calls for water, the problem is with the ice maker module or control board.
Sep 22, 2009 | Jenn-Air JCD2389G Side by Side...
The ice maker in my Jenn Air refrigerator stopped working.
Check that there wasn't a clog in the line after replacing the filter. Make sure you get water going to the solenoid, if so, it may either be a clog in the solenoid or a fluke that it's no longer working.
Sep 10, 2009 | Jenn-Air JCD2389G Side by Side...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Water Leak Into Freezer
Replace the water inlet solenoid valve found in back which controls the water feed into the ice maker. It may not be re-seating properly.
Apr 11, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
106 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
