Question about Yamaha SW118-IV 18" Subwoofer Speaker
Removal of speaker from cabinet Yamaha SW118
Please let me know how to remove the speaker from a Yamaha SW118 base cabinet. After removing the grille and the screws that go through the front of the speaker I tried to move the speaker itself. The speaker seems to be 'glued' to the cabinet. Is there a special way to remove it?
  • 31 Answers
Often there is a gasket seal at the speaker/cabinet interface to keep any air leaks from happening. That seal can get pretty stubborn after time, or perhaps it was glued in with some type of glue. I'd be real careful with the "claw hammer" technique, you will likely honk up the cabinet, the speaker, or both. Use a razor knife carefully around the edge of the speaker and cabinet. If that will go into the crack, work your way around until you've freed up the speaker. Good luck and be careful!
Posted on Apr 08, 2010
  • 382 Answers
Please take my response with a grain of salt for I only serviced subs from B&W and Harman International and Linn.
If there is no bolt directly opposite of the sub (very rare known as a basket tensioner). Then all you do it remove the screws then tap the box lightly with a rubber mallet and the driver will pop out. The foam rubber seal they use can really glue itself in there.
If the mallet doesn't move it then tap the metal rim of the basket lightly to free it up.
If it is like a Linn speaker and they actually silicone them in place them you have to thread an over sized screw into the hole to grab the basket then protect the face of the sub box with a cloth. Now use a claw hammer to rip the screw out and hopefuly the driver pops out with it.....these were a real pain.
Chances are its just stuck and needs a little tap to free it up.
Hope this helps!
Kevin
Posted on Feb 03, 2010
Yamaha psr700 speaker cover removal
Assuming this is a PSR-S700 then you need to undo all the screws under the keyboard and open up so you can see inside under the speaker grill. You will see the grill has tabs that poke through the casing and these are then twisted to keep it in place. Straighten these, push tab through casing going from side to side and then the grill will eventually work free. You do not want to do this too much as the tabs will eventually break with wear.
Jun 18, 2016 | Yamaha PSR-S500 Digital Keyboard
I need to clean the grill in hotpoint refrigerator. When I hope the door to the freezer there two screws hold down grill.The refrigerater is model No. HTS16HBMBRCC HOTPOINT
General Electric (GE) Profile refrigerators have a grille on the bottom of the front of the refrigerator. The grille allows air to be pulled from the kitchen into the lower compartment of the appliance by the condenser fan, which cools the refrigerator's compressor. At times this grille must be removed, such as when you are cleaning the compressor, emptying and cleaning the drain pan or adjusting the refrigerator's leveling legs to level the appliance. The grille is designed for easy removal: It is secured in place using only two screws
  • 1 Open the refrigerator doors to at least 90 degrees.
  • 2 Remove the two Phillips screws securing the grille to the cabinet. They are at the top portion of the front of the grille.
  • 3 Pull the grille away from the front of the cabinet to remove it.
  • Phillips screwdriver
    will be needed
    Dec 21, 2014 | Hotpoint Refrigerators
    Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
    Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
    1. Disconnect battery ground cable (14301).
    1. Remove front door trim panel (23942). Refer to Section 01-05.
    1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
    1. Remove two screws from cover assembly.
    1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
    1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
    Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
    AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
    AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
    AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
    AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
    BAW Speaker Grille-Mach-LH 5 F8DB-18978-
    BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
    AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
    AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
    Trim Panel, Door Front
    Removal
    1. Remove cover behind inside door handle.
    1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
    1. Remove three screws retaining front door trim panel to front door.
    1. NOTE: Do not attempt to remove more than one pushpin at a time.
      Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
    1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
    Installation
    1. Follow removal procedure in reverse order.
    1. Replace all pushpins with new pushpins (N808994-S).
    Front Door Trim Panel
    Jan 14, 2011 | 1999 Ford Taurus
    My Yamaha SW118 keeps cutting out (volume reduces to v low level) even when driven by 500W amp. Doesn't seem to be the amp but not sure if the speaker has it's own internal protection. Can anyone advise?
    Poly Switch
    All full-range loudspeakers are fitted with a self-resetting
    poly switch that protects the high-frequency driver from
    damage caused by excessive power.
    If a loudspeaker cabinet loses high-frequency output, immediately
    remove power from the unit and wait for two to three
    minutes. They should allow the poly switch to reset. Reapply
    power and check the performance of the high-frequency
    driver before continuing with the power reduced to a
    level that does not cause the poly switch to interrupt the signal.
    On the SW115V/SW118V/SW218V sub woofer, the Poly
    Switch protects the woofer and a similar routine should be
    followed if its output is lost.
    Aug 29, 2010 | Yamaha SW118-IV 18" Subwoofer Speaker
    Which wire on the inside is the positive the
    Why should it matter if you're talking about the two wires that go directly to the speaker?
    Reversing them would only result in reversal of the 'phase' (speaker pushing out or pulling in on a corresponding signal from the amp) which isn't absolute anyway. Once you integrate a sub with your other speakers and the ROOM, you have to usually mess around with reversing the phase of one or more speakers either through a convenient switch on the sub itself or through reversing the polarity of the wire coming from the amp, so when a huge bass note pushes out of one speaker it isn't being cancelled by another speaker pulling back at the same time.
    Go for it. Make a choice. They're both right.
    Nov 20, 2009 | Yamaha SW118-IV 18" Subwoofer Speaker
    Screen Removal - Mitsubishi WD-62527
    SPEAKER GRILLE Removal
    Pull the SPEAKER-GRILLE away from the cabinet to remove.
    SCREEN-ASSY Removal
    1) Remove 10 screws (a) from the upper cabinet rear cover (3 screws on each side and 4 screws across the
    top).
    2) Remove screws (b) along the bottom of the SCREEN-ASSY (8 screws on 52 inch models, and 12 screws
    on 62 inch models),
    3) Unplug the LL connector to the front CONTROL-PANEL.
    4) Lift the SCREEN-ASSY up slightly and then pull away from the cabinet.
    CABINET FRONT DISASSEMBLY
    Aug 01, 2009 | Mitsubishi WD-65735 Television
    Csi sp-6c removal
    Your speaker cover should either twist and gently pull off or may just need gentle prying with a small screwdriver. Before attempting is your speaker grill foam or metal. Some like my pioneers, you must gently remove the actual grill and not the entire facia itself to access the speaker removal. If you need to remove the grill, i recommend using a tiny screwdriver and gently work around the edges evenly. Steve
    Dec 15, 2008 | CSi Speco SP-6C Main / Stereo Speaker
    Passport 250 PD dropped face first and it loosened the inside speaker connection
    I have experience with the original Passport 250 as leader of the design team. To get inside of the speaker cabinet, you will need to remove a couple of small screws that hold in the grille at the top and bottom of the cabinet face. Once these screws are removed, you will need to carefully pry out the grille from its pressure fit in the plastic noting how it is placed so you can reassemble the grill later. Once the grille is removed you will notice several holes located around the outer perimeter of the speaker panel. Inside these holes, you will find the screws that secure the front of the cabinet (part with speaker attached) with the back of the cabinet housing. Once you have all of the screws removed, you can separate the front panel from the housing and fix the wires or dislocated parts such as crossovers, etc.
    Once repaired, use the reverse method to reassemble the cabinet. Don't tighten the cabinet screws excessively as they can strip the plastic.
    I hope this repair works for you.
    Oct 18, 2008 | Fender Passport P-51 Consumer Microphone
    Bad speaker/ access panel removal
    As far as I know the speakers have to be removed from the back. Its a poorly designed cabinet.
    Feb 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
    Screen removal
    1) Remove lower,front speaker grill
    2) Remove screws along bottom edge of screen frame
    3) Lift screen assembly off cabinet
    4) Lay assembly face down
    5) Remove just enough frame screws to get back in position--
        Don't force it----
    6) Reassemble.........T.
    Oct 28, 2007 | Toshiba TP55G90 55" Rear Projection...
    Yamaha SW118-IV 18" Subwoofer Speaker Logo
    471 people viewed this question
    Top Yamaha Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Electro Med Services...
    Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
