Question about Canon EOS-AE-1 35mm SLR Camera
Yesterday my camera was working fine but now when I try to forward the film the lever won't move all the way to the right to go forward, it's stuck and won't take pictures, what could be the problem? battery is OK all electric stuff seems to be fine the lock in not on there is no film inside the camera
  • 302 Answers
The camera may have tricked itself into thinking the film is at the end. I know that's not likely in an older manual focus SLR, but just fer grins, try pushing in the little pin on the bottom.
It could just be that the camera mechanism has jammed. When was the last time it was in to a repair guy for Clean, Lube, Adjust? Those AE-1 cameras are getting to that age where they need maintenance.
I had to get a couple of my manual focus SLRs in for CLA service too.
Posted on Feb 03, 2010
Minolta 700 film advance lever was working, then it wouldnt wind, now it is stuck.
Use or buy a brand new battery from store that sell lot of them.
Do not get from store that only has a few, meaning they have been sitting there for years.
atdlee@netzero.com
Feb 14, 2014 | Minolta X-700 35mm SLR Camera
Film advance lever wont move
Do you have a film in the camera? If so is it all exposed? Best thing to do is press the film rewind button and try the lever at the same time - this will eliminate stuck film issues as it removes film tension from the system. If this does not solve the issue then you need someone to have a closer look.
Jan 29, 2014 | Minolta X-370S 35mm SLR Camera
The film advance lever stuck
try pushing the lever forward a bit. try while camera is off, and then on. if not, you might have to sacrifice your film to unclog the inside of it. It's also possible a gear has broken inside.
Apr 24, 2012 | Canon EOS-AE-1 35mm SLR Camera
My cameras advance lever will not spring back and allow the film to move to the next frame. How do i fix it?
push the film release on the bottom of the camera and try to continue forward then. If you are trying to get 27 pictures on a 24 exp. roll you may have advanced your film so far that it is stuck on the piece of tape that attaches the film to the spool. Take only 24 pictures.
May 20, 2010 | Ricoh KR-5 SUPER II 35mm SLR Camera
The frame counter is set on S, the film advance lever doesn't work anymore either. Is there anything I can do or should i take it to get fixed?
frame counter,mechanism is bad,before u get it fixed,try urself open the back door of the film chamber u will find a lever just below the number counter,move it freely ,push and leave, the put a dummy roll and move forward the film,if u get number counter working ok
Mar 05, 2010 | Vivitar V4000 50MM 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Canon A-1, film advance lever and shutter release
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Jun 24, 2009 | Nikon FA 35mm SLR Camera
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
Film counter does not advance when film is wound forward!
The frame counter is engaged when the film door is closed by a small tab at the top of the door near the hinge. Try pressing that area of the door as you advance the wind lever. You don't need film in the camera to do this. The counter with work without it. The door may be a little bent and not pressing the counter lever in far enough to fully engage the mechanism.
Mar 16, 2008 | Pentax ME Super 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
620 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
