Question about Hobart Handler 140 Mig Welder
How would one attain a replacement for the main circuit board
My machine hums, even when swithced off. Also the feed sometimes just stops working. Also the gas relay seems to be stuck open, as gas flow is constant when tank valve is open.
    President:
  • 2,030 Answers
The main control circuit for the welder has gone bad....cost about $198.
Might be better off to buy a new welder.
Posted on Feb 03, 2010
Fuel pump hums. remove f pump fuse, noise gone. seems like it hums all the time
Might have a relay stuck closed. I would suggest changing the fuel pump relay and if that doesn't solve it, look for a short somewhere in the wiring. Somehow you are getting voltage when you are not supposed to be.
Mar 30, 2018 | Cars & Trucks
How can I get my water pumping machine that hums but does not pump water to work
There are several reasons, for example; the hum could be a relay or valve. It could be a frozen pump, meaning the parts that spin are stuck in place and need to be feed up, if possible. It could be a belt that slips when the pump shaft sits idle. The only way to get the problem fixed is to have a professional check out the problem and do repairs.
Feb 05, 2018 | Washing Machines
Given Pfaff 297-1 sewing machine for charity work everthing seems to be right but it does not feed - the feedogs seem to be too low. It's sewing steadily on the spot.
Could be the feed dogs are lowered to do darning. Here's a manual:
PFAFF 294 Instruction Book Page 11
See if the A/B switch makes any difference in the feed dogs.
Sometimes these old machines haven't been oiled like they should and it's possible the feed dogs are stuck in the lowered position. Also, if it was used a lot the feed dogs get worn and no longer work like they should.
Jul 16, 2017 | PfaFF Sewing Machines
I,m unable to start the grill. new gas bottle, every thing attached. It seems like there is no gas flow as I can't even start with a match. Can the gs regulator get stuck so there is no flow?
Hi ircatlin...
ONLY TO THE FOLLOWING IN AN OPEN AREA AWAY FROM FLAMES/FIRE/IGNITION SOURCES.
To answer your question if the gas regulator can get stuck...the answer is YES.
Check to make sure gas is getting thru the regulator...to do this disconnect the hose going to the burner controls...turn on the gas at the tank and listen and smell for gas coming out...if there is no gas coming out, you can sometimes tap lightly the gas regulator and it will free the sticking valve inside and let the gas flow...if the tapping does not work, the replace your regulator as it is faulty.
Please take time to rate me
Sep 03, 2011 | Weber Summit Platinum D4 Grill
I have a Starbucks Barista Espresso Sin 006 that I got used from someone. They hadn't used in it awhile and didn't have the manual. I'm told that before using I should Prime it. The instructions says...
Hi
Since the machine hadn't been used in a while you might have a stuck check valve in the pump. You say it hums. Does it rattle or just hum? If it hums something is stuck in the lines that is keeping the pump from moving water. If it rattles and makes a lot of noise its the pump check valve or it could be a plugged flow meter/ intake line.
Jan 16, 2011 | Starbucks Saeco Italia Digital Barista...
One side glows like a champ. The other side, dedicated for High setting, pooffs when I turn it to high, then kind of fickers and barely glows. I have a fuel filter and a six foot hose off of a 20#...
dirt , foriegn material,spider web in gas feed line to the right side ceramic element of mr heater big buddy. take plastic back of heater
off, many #1 philips or smaller screws. find large air induction holes
in gas feed line to right side ceramic element and blow out with compressed air and fine tiped /straw tipped air blow gun.
straw tipped air blow gun is a better tool for this.
reassemble & try lit mr heater again.
If it dont work after air blow gun the gas feed tube, you didnt get the gas feed tube cleaned out ,***** & span (something still in there ) and will need to disassemble the gas feed tube and inspect for foreign material blocking the gas flow.
If this dont work,need to take the gas feed line off the gas valve attached to Mr. heater red knob. red knob just pulls straight out, might need pliers to grab red knob.
check gas valve output for dirt etc that stop gas from getting through. check inside the gas line to the ceramic burner for dirt,
foriegn material- that stop gas from flowing through strong.
any stopage of gas flow , even a slight stopage or dirverting of the gas flow, spider web is common, will stop ceramic element from burning properly.
needs to be clean ,like a carburator.
Dec 27, 2010 | Mr. Heater Big Buddy Heater
The water simply keeps flowing in and will not stop! It seems the water sensor is faulty - but not sure how to fix it? Any suggestions very welcome! Thank you.
Check to see if it still allows water to flow from either the hot or cold side; change the temperature setting to do this. You don't need to have the water line valves wide open for this. If it only feeds from one or the other, the flow control valve located where the water lines connect may be stuck and needs to be replaced. This valve is behind the hose connectors. This is not a difficult task and requires only a few tools and some common sense.
Feb 12, 2010 | Washing Machines
No power to feed and gas after shipping machine.
I would first check that the unit is set for your input voltage.
Jun 24, 2009 | Welding Tools
My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
May 14, 2009 | Sewing Machines
WHIRLPOOL GAS DRYER MODEL LGR7646E
sounds like your motor is bad or the start relay on motor.. dont think you can replace just the start relay on that motor
Nov 06, 2007 | Whirlpool LGR3624JQ Gas Dryer
Hobart Handler 140 Mig Welder Logo
803 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Delage guy
Delage guy
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
