Question about Tascam DV-RA1000 DVD Recorder
What are the most likely causes for intermittent 'unable to format' message. I have tried two brands of DVD. The machine still burns and plays CD's and previously recorded DVD's, also I can create a new session on an already formatted DVD. Thanks-Nigel-Pegasus Studios-Cairns, Australia
  • Tascam Master
  • 11,800 Answers
Really bad disks. Try using the same brand and model that has worked before and see if that fixes it.
Posted on Feb 04, 2010
Trying to write to blank disk first time (Memorex CD-RW). Get message: Record failed: wrong format for re-write Spectroniq SDR-205 DVD Recorder
Some DVD recorders cannot write CD-RW - only DVD-RW (+ and -) as well as DVD-R (+ and -) (this depends on the brand/model). This unit probably does not support CD recording. Try using DVD-RW instead for this machine - see if it records that (do not finalise even if unit prompts you to with an on-screen message prior to ejecting disc).
There are DVD players and recorders which can play CD-RW (mp3, jpegs etc.) but I don't know of any which record this format (a PC CD/DVD-ROM drive can do this though).
Mar 09, 2011 | Televison & Video
Whenever i burn a dvd with Roxio "Easy" CD &
The service packs are trying to stop pirating software.
Not very good software. TRY Nero Express and Power DVD
http://www.nero.com/eng/downloads-nero10-trial.php
Feb 10, 2011 | Roxio Easy CD & DVD Burning
Brand new Haeir DVD player, only one play so far says "Bad Disk"
Either the disks were badly (too fast) burned or the files on them are of an unsupported format.
Dec 29, 2009 | GPX D1816 DVD Player
Discs will not play back on dvd
What DVD's are you using +R/RW -R/RW some formats may not work especially on non-branded media some DVD players wont even play CD-R but will play some CD-RW of the correct brand.
I suggest that you try your finalized DVD in your PC then create an image using ImageBurn then burn the image onto a branded media and try again. Most firmware on DVD burners are very forgiving and will support a wider range of manufacturers and formats.
Hope this helps, you might want to look on your DVD players website for updated firmware you will need a blank CD and create a update disc using your computer.
Oct 18, 2009 | Sony DCR-DVD91E DVD Camcorder
Won't format new DVD-RW disks
i did everyting today to fix this. bought new dvds, name brands different, tried finding codes, called the number. trust me. try this. clean it. thats All i did. cleaned it with a dvd cd cleaning disc, the one with two little brushes on it, nothing special, ran it until i heard the beep, popped my dvd in, they all worked. everyone, im still recording. i ran it about four times. now, if you tried to burn a dvd, and got the error, throw that dvd away. because i tried about ten dvds. after i fixed it, THOSE dvds were no longer usable. dont know why. hope this works.
Sep 18, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
Loading some DVD's
I have seen this same thing on a laptop. DVD drives use two lasers. One for CD and one for DVD. As you noted CDs are just fine and so is that laser. Although I believe the DVD laser is intermittent. And it will work with some DVDs and not others. Yes I have seen this before. What will probably happen a few months down the road is it will stop reading all DVDs.
It isn't economical to replace the failing laser. It is far cheaper to just replace the whole DVD drive. Lasers are like light bulbs. Some seem to last forever and some seems to burn out right away. Generic DVD replacements will generally work, although the face plate might not fit.
Another option is to get an external DVD that plugs into the USB port. And those Slimline models are really small (same size as laptop CD/DVD drives) and you can use them on other computers too.
Jan 29, 2009 | Computers & Internet
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
Burned DVDs play on PC but won't play on home player. I have 3 PC (2HPs and 1 Parts built),running XP home, pro, media. I bought 2 Samsung SH-S182 DVD±RW Dual Layer Burner, and have tried them on all 3...
Nero 6 and 7 does not provides us the facilitiy of burning the DVD in appropriate DVD Format. Instead it burns the DVD in the normal DATA Format, which is not supportable by our DVD Player. To play the DVD in our DVD Player we should burn the DVD in the appropriate DVD Burner which itself converts the extension of the movie and make it proper for a DVD Player to read it. It also adds some files to the DVD which is sometimes used by the dvd player in running the DVD.
Thank You
Vinay Ramani
INDIA
Oct 07, 2008 | Ahead Software Nero 6 Ultra Edition...
Burning problem
Try different brand. Your Drive is a sensitive type and it only accepts some DVD-R brands. Also try DVD-RW disc. I had the same problem but not specifically the exact problem. My drive is cd writer only. Same problem, I just used diff CD-R brand like Imation and Philips and the burning works like a charm.
Jul 26, 2008 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
None of my DVD players will show photos from CD-R photopro (maxell)
What type of pic file are you burning to the CD? What format are you using as a burn profile? Without knowing this, my only guess is your DVD player can't show the pics in the format used, so you need to work around that problem. Shouldn't be too hard, reply back with more info...
Feb 17, 2008 | Emerson EWD2203 DVD Player/VCR
Tascam DV-RA1000 DVD Recorder Logo
Top Tascam Televison & Video Experts
Lawrence Oravetz
John Potter
Are you a Tascam Televison and Video Expert? Answer questions, earn points and help others
