Question about Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750 - Tray 1 streaks on prints
I have a Xerox Phaser 7750 that is printing fine except through Tray 1/bypass. When printing heavy stock there are blue toner streaks (about 1/4" wide) across the center portion of the paper. I checked the blue drum and it looks OK. Paper through Tray 2 is OK. Tray 3 paper runs through in the same direction as Tray 1, and it's clear. I've tried different media settings and Tray 1 is the issue. Problem comes and goes, so I can get 10 clear prints, then dirty. I've cleaned rollers - not resolving. Any suggestions?
    Habit-Forming:
    New Friend:
  • 11 Answers
If you put Tray 2 in Tray 1's spot with the heavy stock in Tray 1 (now in tray 2's spot) and print from it, does the problem persist?
This may help...
http://www.support.xerox.com/support/phaser-7500/support/enus.html?objGUID=4538
Posted on May 17, 2017
  • 18 Answers
SOURCE: Xerox phaser 7760 streaking
to fined out what the problem could be you need to open a word doc and sent a blank page to the printer. from this it will show where the problem is in the printer
if u still get streaking it couls be a faulty toner and it may not be the cyan toner either. i would give the fuser unit in the printer a check. if there marks on tthis unit i can cause this problem as well
Posted on Nov 23, 2007
  • 2072 Answers
SOURCE: Xerox 7750
In what direction is the mark? Is the defect a dent in the paper,that repeats or is it a crease in the direction of the paper feed? If it is a dent that is repeating, the cause would be the transfix roller. If it is in the direction of paper feed, there may not be much you can do, most of those ceases you can see when held sideways like that come from the rollers edges. Just the normal crease that can be created by the end of the roller.
You can open the covers on the machine and make sure there is no excessive buildup of ink on any of the rollers. It is possible there is to much pressure on one of them, but with certain types of paper, there may not be much you can do. I will research it more and get back with you on that issue.
One thing you can try, (because your marks can be comming from a defective fuser), set the machine to print 4 or 5 pages, then shut it off or unplug the printer in mid run. Carefully look at the jammed pages to and see where in the process the crease is comming from. Take note and let me know please.
The gray haze seems to also indicate a possible fuser issue, but moreso, it sounds like the black housing is over toned. Most likely cause of that is a bad housing or bad developer. The developer in that machine will become worn and need replacing. It will restore the contrast and should resolve background issues.
Posted on Mar 11, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 6250DP sensor not cleaning
Is there a specific code coming up? That can make it easier to pinpoint the exact problem.
Posted on Apr 21, 2008
yalmer
  • 549 Answers
SOURCE: Xerox phaser 7750 error code
Click on this link at xerox.
Posted on Apr 22, 2008
  • 110 Answers
SOURCE: hi i got xerox phaser 7750 and i have error code
Cheap fix : reset the Developer Life Count in the Service
Tools menu. Hold down the back ARROW key with the "i" them with your other hand turn on the machine.
Expensive fix : What has happen is that the developers have come to the end of the life and once it gets to a certain page count it will print out no more until you have replace the developers. One thing xerox forgot to do is reset the engine control board too for this machine. So you might need a new engine cotrol board too.
Procedure
1. Replace the Developer
2. After the Developer has been replaced, reset the Developer Life Count in the Service
Tools menu.
NOTE: It is recommended that all the Developers and Beads be replaced at one time rather
than on sccessive visits.
Good luck.
Posted on Oct 29, 2009
How do I print labels using the bypass tray on Xerox phaser 3635?
All I can add to your question is from my experience.
Make sure you have the recommended labels installed.
The fuser can cause jams when not using the correct recommended stock.
Very old labels tend to ooze a small amount of glue along the edges and can get stuck to the inside.
Print as you would do on paper, perhaps try printing on some white 80 GSM stock and hold them up to the light to check alignment.
Good luck.
Jul 02, 2014 | Xerox Phaser 3635MFP/X Multifunction...
How can i avoid label sheets getting stuck in phaser 8560
1. Make sure you are feeding the labels from the bypass tray, not from the cassette.-
2. Make sure the labels are for Laser printers, not Inkjet printers.
3. Do not try and re-use a label sheet that only was half printed on.
4. When you put the labels in the bypass tray, set the paper type to labels...this slows down the print process so they won't get jammed.
Jun 02, 2014 | Xerox Phaser 8550DP Printer
How to clean phaser 7750
Included general maintenance video and how to clear smears from the paper.
Solution: Remove Print Smears / Printing Fuser Cleaning Pages
7750 Support Knowledge Base Remove Print Smears Fuser Cleaning...
With Troublshooting highlighted on the printer display perform the following steps:
  1. Press OK.
  2. Press the Down Arrow and scroll to Print Quality Problems.
  3. Press OK.
  4. Press the Down Arrow and scroll to Remove Print Smears.
  5. Press OK. The printer will print 5 cleaning pages.
Repeat this process five or six times, to remove stubborn toner buildup from the fuser.
Always make sure you are matching the type of paper loaded in the printer tray(s) to the correct Paper Type front panel setting. When you load a tray with paper, the front panel will ask you to indicate the type of paper you loaded. For correct print quality and printer operation, be sure to set this correctly.
MAINTENANCE:
Phaser 7750 Video Instruction Maintenance for the Printer Phaser
Apr 23, 2014 | Xerox Phaser 8550/SDP Color Laser Printer
Phaser 7750 Not Printing, No Error codes, Fuser Wont Warm Up, Wont Detect Open Trays or Doors
It sounds like one of the cover or tray sensors is not working correctly. Check the actuator on the fuser cover, sometimes these break off so the printer thinks the cover is still open. If that seems ok and you have a lower tray deck unplug it to eliminate them as the cause.
Apr 07, 2017 | Xerox Phaser 7750 Laser Printer
Xerox 6180 James at Tray 1 mpt every time!
Your lower trays are programmed incorrectly. Change the size and or the paper type back to letter and plain paper
Aug 23, 2012 | Xerox Phaser 6180N Laser Printer
Printing from wrong tray
I suffered from the same problem for a long time. We got Xerox Phaser 8550 and 8560 here. I choose on computer "tray 2" but the printer just print from tray 1 which is empty.
Today i figured it out! It's some configuration at the printer. So go to "Paper tray setp" -> "Tray 1 mode" and "Tray 2 mode" -> change to "static".
I figure it's like this. Before it was "dynamic", it probably means the printer decides it's better to use tray 1 even though you choose tray 2 - and this decision is stupid. Changing it to "static" fixes this.
Let me know whether this works for you too!
Feb 12, 2010 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8400N Printing Stripes
When you go into the eliminate light stripes there is also a mode called Jet Substitution. You can sometimes bypass the bad jets.
If that does not work then the print head will most likely need to be replaced.
You can replace the printer for less than the cost of a print head normally..
Jul 08, 2008 | Xerox Phaser 8400 Laser Printer
Phaser Maintenance Tray Message!
No unfortunatly. That is counted out on a chip with a hard count.
Wish there was.
Apr 02, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 7750DN Laser Printer Logo
138 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
