Question about Bunn GRX-B Original 10-Cup Home Coffee Brewer, Black
Takes forever to brew coffee
It takes a super long time for the water to run through my bunn coffee maker.... and when it finally does it doesn't run ALL of the water so if i would make a pot up to the 10 mark it woud only go to 6 or 8. and then the coffee tastes horrible...
    Brigadier General:
  • 4,090 Answers
Time to clean out the scale.. Like cholesterol in arteries it needs to be removed!
You can get some CLR from hardware store ( calcium and Lime removal substance) Place some in the unit and let it sit fore a while. The run the unit so that the disolver can also attend to the delivery tube. Once it is clear run plain water through it to rinse it. This substance is not harful to health.
Please rate my help++++Thanks for using FIXYA
Posted on Feb 03, 2010
    President:
  • 1,124 Answers
It could be clogged.. Take out all removable parts and clean well.. Then run a mixture of equal parts od water and vinigar to clean the areas that cant be reached. Repete a few times..
Have a great day
Bunn coffee maker leaks
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
Jun 17, 2014 | Bunn VPR Coffee Maker
We have a 2 month old bunn coffee maker. worked fine now coffee is taking 10 minutes to brew
Sounds like calcium build up, You need to descale the machine.
If you look at the grounds on the basket, After the brew cycle is over there is like a hole in the center of the grounds. This happens when there is calcium build up in the tank, tube and or spray head. And takes forever for the brew cycle to end.
Follow the instruction on your manual to descale the brewer.
Jan 15, 2011 | Bunn Coffee Makers & Espresso Machines
What is the best way to clean our Bunn coffee maker?
The best way to clean a machine like this out is to actually run a full empty brew of a half water half vinegar solution. This will completely clean out the lines inside the machine and freshen everything up quite a bit. After you run the full empty brew of the solution make sure you run at least 2, maybe 3 full brews of just water on the unit. This will ensure that all vinegar is flushed out of the system, and will help clean it as well. Of course the vinegar won't hurt you if it isn't flushed all the way out, just makes it taste quite funky. But 2 flushes with plain water is almost always enough to completely clean it.
Of course when I say an empty brew, don't put any grounds or coffee filter in the machine, just run the water and vinegar through the machine as if you are brewing a full put of coffee.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Oct 14, 2010 | Bunn (VPRBUNN) 12-Cup Coffee Maker
My Bunn is taking forever to brew and the coffee
It sounds like the thermostat might be allowing the water to boil and cause the grounds to be scorched and making your coffee bitter. It also could be caused by the machine needing to be cleaned and delimed. I would recommend you do this first-and if you don't have the use and care manual, you may call Customer Service to have one sent out or access one at www.bunn.com @ home, then products.
Apr 09, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
My tim hortons coffee maker is not brewing as quickly..s there a wayto clean it
Make a 1/2 pot 50/50 mixture of cold water and white vinegar then run it through the machine in normal brewing fashion. Place a clean filter in the brewing cup to catch the white deposits that are removed. Allow the mixture to cool, then repeat the process several times while using the same filter. Finally, run several pots of fresh water through to work out the taste of the vinegar. Repeat whenever the brewing time seems to be excessive.
Feb 02, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
May 06, 2009 | Bunn NHBX-B Contemporary 10-Cup Home...
My bunn coffee maker is just dripping when it is making coffee. Then the next time it makes it just fine.
Hello, I am wondering how long between times you are stating, as most Bunn commercial units, stay heating 24/7, and if water is not poured into the machine every couple of days, they will evaporate off water that is held in the tank. This drop in water level can cause short brewing, slow brewing, etc.. as the unit relies on a vacuum or suction to brew properly. You could also have a leaking tank gasket, or brew tube gasket, and it is seeping air into the tank, breaking the vacuum/siphon action, and then seals with water, or expansion at other times. Another cause would be scale build up, and pieces are floating in the tank blocking the flow of water, or your spray head may be clogging/clogged, which minor cleaning should take care of the sprayhead, and tube, or a major cleaning necessary for the tank.
Hope that helps, and thank you.
Mar 04, 2009 | Bunn VPR Coffee Maker
Water supply for Bunn coffee maker
open the cover on the brewer- depending on your model, it could be the front or the back cover. look for a brew timer dial. turn this up slowly, running a brew each time to see if you now have a full pot
Feb 05, 2009 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Slow brewing
I have had that problem with my bunn and I unscrewed the nozzle and it didnt help.My pot came with a wire so long u are totake that wire and stick it up in there and it cleans it out .If that does not work run cleaner threw it but i would not use vinegar.Thats the best i can do,it worked for me.
Jan 11, 2008 | Bunn GR10 Coffee Maker
My bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
Sep 15, 2007 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Coffee Makers & Espresso Machines Logo
164 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
zimcloud
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
