Question about ViewSonic PJ402D DLP Projector
I have a viewsonic pj402d projector. put in the new lamp. it turns on then tunrs off in a two to five min. once it cools off it will turn back on but does the same thing.
  • ViewSonic Master
  • 12,061 Answers
Your Heat Sensor is probably faulty, try a replacement.
Posted on Feb 03, 2010
  • mc08608 Nov 25, 2010
    I have the same problem - how do I get to the sensor and where can I get a replacement.
Lamp light flashes amber without the lamp ever turning on, then projector shuts down in a minute or two
Based on what you're describing, it sounds like a failure in the lamp ballast itself. The projector will probably need to be sent for service.
If you have a spare lamp, that would be the first thing to try. However, if it isn't that, it is likely the ballast.
Mar 15, 2016 | ViewSonic PJ402D DLP Projector
Viewsonic pjd5111 projector has temp and lamp light on. not turning on
Hello
Check whether its cooling fan works or not. If there is any fault to the cooling fan, these symptoms you describes here can occur.
Feb 07, 2012 | ViewSonic PJD5111 Projector
MY VIEWSONIC PJ402D DLP PROJECTOR WILL ONLY DISPLAY IN BLACK AND WHITE.
If you are connecting the projector to the signal source via S-VIDEO cable this not uncommon. It usually happens when one of the connectors or the cable is broken. Try a new or different cable. If problem persists examine the connectors on both end of the cable and the one in the projector as well as the one in the signal source(pc, laptop etc) to see if there is a hardware fault. If all is good then the problem is internal with the S-VIDEO connector. In that case your other option is to use VGA.
Have a good day, hope this helps.
Nov 03, 2011 | ViewSonic PJ402D DLP Projector
ViewSonic PJ402D Projector does says searching for source, what does this mean? Laptop does not even notice that projector is connected to it as well.
you need to hold function down and press something like F1 F2 F3 F4 maybe twice to clone the screen display and make sure your projector is on vga and there is a secure connection between your laptop and your projector.
Jan 21, 2010 | ViewSonic PJ402D DLP Projector
AMber light blinks as soon as I turn it on then shuts off
As soon as you turn it on hold down the menu button until the lamp turns on.
Oct 13, 2009 | ViewSonic PJ402D DLP Projector
Projector shut off
Your lamp may well have died..
Oct 07, 2009 | ViewSonic PJ402D DLP Projector
My sharp xr-20x projector wont turn
are there any leds on? if not, the power supply is shot. if there are leds on, the color and number of flashes will tell you the problem.
Aug 12, 2009 | ViewSonic PJ402D DLP Projector
DIY lamp
I had the same problem awhile back and looking around for an answer i found this.
http://recklessphilosophers.com/2008/05/02/home-theatre-for-63--dlp-pj-retrofit-for-7-bulb-instead-of-300.aspx
May 22, 2008 | ViewSonic PJ402D DLP Projector
ViewSonic PJ402D DLP Projector Logo
485 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
