Question about Yamaha HTR-5860 Receiver
My yamaha 5860
"only my center channel works on my yamaha 5860" when i plug a speaker in a diffrent port it plays softly or doesn't play
SOURCE: i have a yamaha rxv663
wireless speakers will usually hook to speaker outputs as well as headphone jacks. hook the wireless speakers up to speakers "b".
Posted on Dec 17, 2008
  • 55 Answers
SOURCE: Is it possible to play my ipod nano through my Receiver?
If it doesn't have a jack made for plugging Mp3 players into it like the new car stereo's do than you just have to go buy an FM transmitter that is made for Mp3 players. It will play through one of your low FM frequency's on your receiver. You can generally pick one up for around $20
Posted on Jan 02, 2009
  • 146 Answers
SOURCE: WE PURCHASED A YAHAMAHA HTR-6130 TODAY
You may need to set up the receiver for your speaker configuration. There should be a setup menu on the receiver, and that will allow you to tell the amp what speakers you are using, and what inputs you are connecting what devices to. You may also need to set your DVD player, cable box and TV for the audio stream you want to use. PCM or Bitstream to be more precise. Also make sure that the sound output is set to Dolby Pro Logic or Dolby Digital and the input signal is in stereo or surround.
Best Wishes.
Posted on Jan 03, 2009
  • 127 Answers
SOURCE: i am trying to hook up a powered sub woofer to a
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input.
You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT).
Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work.
Don't connect anything to the speaker output on the sub, you don't need that.
Posted on Mar 02, 2010
SOURCE: Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
HOW CAN I SOLVE THIS PROBLEM
Posted on Dec 28, 2011
I have a HTR-3065 receiver and no sound in center speaker
Try changing surround modes - the center channel is not used in all modes. If that doesn;t work, check your speaker settingsw and make sure the center channel is not turned off
Feb 22, 2015 | Yamaha HTR-3065 5.1 Channel AV...
I can't get my reciever to play my subwoofer
The sub channel will be switched off. You need to find the speaker settings, locate the sub channel settings and switch it on.
Jun 16, 2017 | Yamaha RX-V663 Receiver
Sound is great unless I'm playing a DVD. When I'm playing a DVD, the music and sound effects are fine, but I have difficulty hearing and understanding the dialog. Any suggestions?
Check your setup for the center channel level, or to see if the center channel speaker is working at all.
Also check the setup in your DVD player to make sure its speaker setup matches what you have.
Feb 14, 2011 | Yamaha RX-V750 Receiver
I have a sony STR-DE897 and my rear speakers dont get sound when plugged into the surround back ports..Is there a certain setting in order for the rear surround spreakers to work? or does that mean the...
There are a few things required for the rear surround channels to operate;
1. The surround back channels must be enabled in the surround setup menu.
2. The media being played through the receiver must have audio encoded for the rear surround
channels. There are only a few exceptions to this but I'll exclude the explanation for simplicity.
3. The audio level of the speaker channels must be set high enough to be audible.
Enter the surround setup menu with your remote. Use the center button on the remote to toggle through the selections, press down on it to enter the selection.
You will navigate to a selection in the surround setup menu that says "surround back" or S/B with a selectable yes or no indication. Press on the center button to enable them.
Media like DVD or Blu-ray that has 6.1 or 7.1 channel audio has separate, or often referred to as "discrete" or "matrixed" audio intended for playback through surround rear speakers, depending on the music or movie. If your media is encoded for 5.1, then there will be no audio sent to these speakers. However, with the different modes of on-board digital processing of this receiver you can still have audio through these speakers.
Last but not least is the actual playing level of these rear surround channels. They may simply be adjusted to quietly. Enter the setup menu with remote, choose "level" and navigate to the rear surround channels. You can adjust the level up or down in 1/2 dB level increments by toggling left or right with the center button. Each surround channel can and should be adjusted independently and equally.
Dec 14, 2010 | Sony STR-DE897 Receiver
Hello i was wanting to know if i could hook up my AX-596 amplifier to my Yamaha HTR-5860 reciver
I assume you want to slave it to the receiver and drive some more speakers with it.
Connect some RCA cables from whichever channel pre-outs you want on the HTR-5860 to any input on the AX-596.
Set the AX volume to something sufficiently high, run through the HTR's speaker level setup and match the AX volume to match the channels on the receiver. Then leave the AX's volume alone.
If you just want the AX to have access to program sources of the HTR, run the RCA cables to it from one of the VCR1 or 2 Out (but DO NOT select whichever one you use via the front panel). These are not affected by the HTR's volume controls.
May 07, 2010 | Yamaha AX-596 Amplifier
Centre speaker not working on yamaha surround sound unit.
Check your "Setup" in the main menu of the receiver. Press "Menu" or "GUI" whichever you have on the remote and go to "Manual Setup" then toggle to "Audio" then "Speakers" then toggle to "Center Channel" and make sure it's on "Large" or "Small" instead of "None". If you still don't have audio, post a comment with the model # of your receiver, I'll pull the book and help you further. Hope this helps.
Dec 21, 2009 | Yamaha 5.1-Ch. Surround Sound Home Theater...
No sound from center channel
If you have checked the speaker and wiring. Check the setup, the center channel could be off or it's not in a surround mode.
When playing a DVD through the receiver are the voices heard clearly in the front speakers? if so the center channel is turned off.
Oct 21, 2009 | Yamaha DSP-A1 Receiver
Jan 02, 2009 | Yamaha HTR-5850 Receiver
No Sound From My Center Speaker
on the yamaha amps you can do a speaker test to see if all the channels are working. once that is complete and working you should check the disc to see if it is true digital or dolby pro-logic. normally on the disc menu you can select this.
May 26, 2008 | Yamaha RX-V595A Receiver
Open Questions:
See all Yamaha HTR-5860 Receiver Questions
Yamaha HTR-5860 Receiver Logo
96 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
