Question about RCA DRC8000N DVD Recorder
Drc8030n the unit has gone to saying "hello" and will not so anything else. I have a dvd stuck in the unit and need to get it out not to mention that I have only had this unit for a year but it has become an integral part of the family. Indispencible with two children under 3 plugin just says hello.
  • 5 more comments
  • ginoe Feb 20, 2008
    drc8000n when plug in just (hello) on display
    still no help
    did all of that but nothing seems to work
    DRC8000N JUST SAYS HELLO
    IT'S ALREADY IN A SHOP
    did everything but nothing seems to work.can someone tell me whats the voltage that goes to the hd. thanks in advance
  • ginoe Mar 03, 2008
    has anytech, find the problem for the drc8000n thats stuck on (hello).
    Scholar:
  • 75 Answers
1. UNPLUG THE PLAYER
2. Remove the screws, usually 2-3 on each side, possibly 2 in the back also. Then lift off the top of the player
3. after this push the drive out so you can get your disk out.
4. reassemble the player
5. plug it back in and it should be fine.
P.S. - as for the HD voltage it should be 1.5v, exactly the same as a computer.
Hope this helps :)
Posted on Feb 20, 2008
    Genius:
  • 1,665 Answers
Hi have a nice day.
Read user guide instructions about how to release DVD tray and get DVD out.
Dont you use cheap DVD's, it will lock up after you record when it is in the finalization phase. In the box is a piece of paper marked important. It says, "use compatible discs that have been tested with the DRC8000N"
Listed DVD's:
RCA
RICOH
PHILIPS
VERBATIM
SONY
MAXELL
TDK
IMATION
Good Luck
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Feb 20, 2008
    Inspect also for loosen cable connections to HD.
    Kleanthis Mavropoulos Mar 03, 2008
    Did you download the user manual from here ?
    Enter your email to receive information from.
    Genius:
  • 1,226 Answers
Hey!
All of you guys are correct that the ultimate solution is the service center of the stuff, and if the service center solution is not possible am sure that they will offer a new one.
Maybe you can claim warranty of your stuff.
  • 1,113 Answers
Is this DVD recorder of yours in a shop?
    Master:
    Sergeant:
  • 462 Answers
My best solution to you is to take it to a nearest service centre and just spend 5min, they will take the DVD out and give it to you, its a matter of 5min thats all....!!!
Thankyou
  • 871 Answers
Hi there
try and bring your recorder to a servcie shop if there isnt any much choice left. hope this helps.
  • earl norman llanera
    earl norman llanera Feb 20, 2008
    try prying it open but be careful. follow the steps coolguy just explained and this might help you. but it still dont, service center is the answer.
    oh ok, so its in a shop already...
    Genius:
  • 3,422 Answers
Press the up or down Channel button. It will change the output mode to the RF which is probably the way you have it connected.
Goodluck..
  • 1 more comment
  • Priya darshan Feb 20, 2008
    Hi again,
    see if there is a little pin hole in the face plate or bezel of your
    dvd player... stick a paper clip in it and it will release your DVD
    tray and you can get your DVD out. Then Plug it back in and see if it
    will reboot.. it should.
    Also check if the wires and the adapter are properly connected to the player..
    This can also be cured by doing a Hard Re-Set while the disc & tape were in the machine.
    Just plain old pulling the plug, counting to 40 seconds and reattaching the power cord..
    If you have a manual you can also go through that...
    alright then go ahead and open it up cuz that's the only solution..
    I have given you all the best possible solutions if the y don't fix your problem I suggest you to get it replaced or repaired..
    Thanx for using fixya..
    Sergeant:
    Champion:
  • 281 Answers
Open the DRC carefully from it back, first take out the DVD stuck in there.
After that it should work.
I NEED POWER SUPPLY BOARD FOR DRC8030N
I am sure that the fault was relative of the bad capacitor and swapping the working board has proved. Hope that solves the issue as all what is needed is to check and replace all the suspected capacitor is the Primary /Secondary side as the SMPS is working BUT with a limited voltage. So the threshold is low and so can be a tank capacitor, change the mains capacitor and also the secondary +B side.
Dec 02, 2011 | RCA DRC8030N
Won't turn on, just says "Hello" and will load no further
This is due to one of the IDE devices inside (Hard Drive or DVD drive) not sending the requires "I am Ready" signal to the main board while the DVR does a power on self test. With the hundreds of units I have come across, 99% of the time it is due to a faulty DVD drive. These "Loader" brand DVD drives were on the cheap and when they give out, the unit does not go past the Hello. You can verify this by replacing the the DVD drive with any other DVD burner or DVD drive or even a CD drive that comes from a computer (IDE connector). The only fix for this is to replace the drive or simply connect an old CD drive inside and not use the DVD properties of the DVR, only the hard disk recording/playback.
Oct 01, 2009 | RCA DRC8030N
I want to find a replacement for DRC8030N
you can replace the DVD-RW yourself with any computer DVD/DVD-rw drive.  You will need to modify the way it sits in the unit as the screw holes will be different and some drilling will most likely be needed to make new screw holes.  Finding an original replacement DVD-RW for this unit will be hard because the first problem that this unit has is a constant HELLO message due to a faulty DVD-RW, so they are in high demand.
Jan 13, 2009 | RCA DRC8030N
RCA DRC8030N No output
Connect the unit as you normally would using the composite cables. Once you turn the unit on and the RCA logo flashes and then the video *poof*, dissappears, press the Video Out button on the remote control so that the PS OFF (progressive output for S-Video) is shown on the LCD, this should get the video back to normal.
Nov 09, 2008 | RCA DRC8030N
Drc8030n Motherboard
Thank you so much for sending me those parts, and an extra thanks for the extras. Which happens to be what I needed to fix my problem. You won't believe it... I got your well-packaged parts today. I soon replaced the Motherboard, no change, still the same HELLO... I was so deceived... Then, I decided to replace the Power Supply, just in case... IT WORKED!... (thanks for sending me a free power supply)... Looking at my power supply, I can see that on the printed circuit under those 3 diodes, near the transformer, is an area that seems to have overheated. I will test it and give you the results eventually, as well as the results and solution if I can fix the DVD burner. I'll use the extra fan you so generously gave me to cool the power supply, seems like it won't hurt. Though I have to place it right, or it'll make the problem worse... Seems like anything wrong with this DVR and all it'll do is display HELLO... I've heard of a bad DVD Burner, a bad Motherboard and now a bad Power Supply that causes the HELLO... Thank you so very much GSAN, you did it... I recommend you to everyone out there for your fairness, kindness and devotion. We should call you Mr. FixYa!...
Nov 01, 2008 | RCA DRC8030N
RCA DRC8030N Problem
This is due to the DVD-RW drive that is in the unit. This is the first to fail and RCA seems to have gone with the lowest bidder on this model. The DVD-RW drive will need to be replaced. If you used the DVR to watch and burn DVDs then you will need to replace it with any computer DVD-RW but you may need to re-drill some holes to have the replacement drive fit exactly aligned with the DVD door. If you only want to use this DVR for the internal hard drive recording and TV viewing, then any CD or DVD computer drive will do, just simply connect the replacement drive and leave it in the case (you wont have access to the DVD or CD drive under this option). If you do replace the drive, make sure you match up the jumper on the back so that it will be in the same position as in the original DVD drive ( the Master setting). I hope I did not scare you with all this information, but unfortunately, the dreaded HELLO issue with the DRC8030N has no easy fix.
Jul 09, 2008 | RCA DRC8030N
RCA DVR SAYS HELLO
Did you try pressing the power button?
May 16, 2008 | RCA DRC8030N
Manual
my drc8030n only say "hello"
May 03, 2008 | RCA DRC8030N
Drc8030n
For DVD that are stuck. Unplug the unit from the power source. Flip open the DVD dust door (FROM TOP TO BOTTOM) now you can see the DVD disk tray. Look under it to see a white gear arm, you can push on this to unlock the tray and pull it out manually. Now you have your DVD back.
Feb 15, 2008 | RCA DRC8030N
Drc8030n says hello
Are all the cords connected? Is there any disk in? Make sure theese are all done
Nov 29, 2007 | RCA DRC8030N
RCA DRC8000N DVD Recorder Logo
96 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
