Question about Dryers
Drum turns no heat kemore dryer - Dryers
    President:
  • 1,124 Answers
Most likely its the heating elemnet(s)..
Posted on Feb 03, 2010
Kemore 70 series electric dryer not heating up
Might be the heater or a heater limit or the timer itself. It also could be the wall outlet or circuit breaker. It most likely is the heater itself though. Repair videos and manual on kenmore dryers
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 05, 2012 | Kenmore Dryers
Kemore dryer serial number 96292110 dryer turns and operates but dosent produce any heat
Your dryer innards look like this
Their is usually a flap you can remove to get to the element.
It slides out after you remove a screw or 2 These videos show how to get into the dryer:
Older model:
Newer model:
More Here
Jan 15, 2011 | Kenmore Dryers
My kemore 80 series gas dryer does spin but it heats up whats the problem
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 05, 2011 | Dryers
Why won't my kemore elite dryer tumble?
if the motor runs and the drum isn't spinning you have a broken belt
Apr 21, 2010 | Kenmore 62602 Electric Dryer
Dryer does not heat
Check out this tip it will help you with your problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Heatman101
Mar 23, 2010 | Kenmore 72972 Gas Dryer
My kemore dryer model 11071812001 not drying clothes
Sounds like the problem is the solenoid coils on your gas valve. easy to replace and inexpensive + common. their are 2 coils on the valve that have 2 wires each going to them. Let me know if you have any other questions,
Phil
Jun 10, 2009 | Kenmore 73952 Gas Dryer
Kemore dryer (Mod#110.66512694) stops running
Reach inside and turn the drum. If it is hard to turn then something may be causing the motor to get hot and quit on overload. An overload is wired into each motor to prevent the copper from melting. If the drum is hard to turn you might want to inspect the rollers and idler. ACCESSING YOUR MACHINE
May 16, 2009 | Dryers
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
MY DRYER DOESN'T GET HOT
If it's completely cold, you probably have a burn out heating element. If it gets warm and takes forever to dry, then it's probably the fan wheel.
Hope that helps...
Geno
Mar 22, 2008 | Kenmore 62602 Electric Dryer
Kenmore gas dryer
That model does not have a pilot light.  It has an electronic ignitor.  If it is not igniting, either the igniter is not getting a signal to ignite, the igniter is burned out, or the gas solenoid is broken.  Probably the igniter is burned out.  It is item number 3018 at RepairClinic.com.
Oct 20, 2007 | Dryers
Dryers Logo
74 people viewed this question
Top Dryers Experts
