Broken power button on a gateway t-series
Is there a fuse or circuit breaker for the power button on a gateway w350i? It won't turn on.
  • 12,061 Answers
Usually it is the Power Supply or The components of the PC. You will have to troubleshoot. To find the exact culprit.
You will have to troubleshoot and find out where the fault is. Here is what I do….. First, check the Power is ON, cable is OK and IN PC, Then open PC up, and remove all power connections from everything EXCEPT the Motherboard Connector.(s) (Remember where they go, draw a diagram etc) Power the computer up, and does it switch on? NO, Then, remove the RAM, does it Boot up? YES Faulty RAM, replace. If it still does NOT then your Power Supply Unit is probably Faulty.(But it may be the motherboard) either way we need to test more with a known good power supply. With know good PSU, plug this one into the Motherboard Connection(s). Does it work, YES. Problem Solved. OK back to Frst: Because it DID go the PSU WAS OK, The MB was OK & the RAM was OK, Now then we plug in each of the other Items, DVD Hard Drive, etc, etc. One-at-a-time, until we find the one that stops the PSU. (It has protection and will "Shutdown in event of a fault") The one that stops the PSU is your culprit, replace whatever it is.
Posted on Feb 03, 2010
How do I bypass the circuit breaker on power sweeper rainbow e series?
If it is broken and will not stay engaged it should be replaced.
Feb 16, 2018 | Rainbow Vacuums
80 series kenmore dryer wont heat - blows cold air during drying cycle. Dryer is all electric.
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 21, 2008 | Dryers
Light Switch Won't Work, How do i fix it?
Sounds like the switch its self is broken REPLACE IT make sure serciut breaker is off first
Jul 08, 2013 | Electrical Supplies
There was a power outrage and now my computer won't turn on?
Check the source of power to your computer. Your computer should be plugged into a protection strip. Make sure that the protection strip reset button is reset. If that is ok, check the circuit breakers in the fuse box.
Jan 29, 2013 | Computers & Internet
Have a carrier 92 furnace. electric motor will not kick on...just hums. red light on circuit board flashes...help?
see this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
However you can have a missing 1 phase , test with the VOM, for to measure voltage. Or motor need repair for winding trouble,bearing.If you do not have enough experience call some electrician.
God bless you
Oct 08, 2012 | Heating & Cooling
Hi,I have a travel trailer 37ft. Problem with my ac, the fan starts good but my compressor does not kick on. My next door neighbour says it's the compressor that is done. Could you help me?
Motor Trouble Cause Diagnostic Procedure Repair Procedure Electrical Power is Off Check that all service switches for the equipment are in the "on" position.
Check for voltage at the pump motor or pump controls. If no voltage is found, check for voltage at the electric panel.
If power is on to the building, check fuse or circuit breaker serving the electric motor that won't run.
Check for local reset button on the motor (popped out = off )
Check for other power reset or power off buttons such as an access door compartment safety switch that turns off power to the equipment (found on A/C blower compartment doors)
Turn on "off" switches.
Replace bad fuse. Reset circuit breaker; if necessary replace bad circuit breaker.
Let hot electric motor cool down, then push in its reset button.
Be sure all safety interlock switches such as on compartment doors are depressed and that the doors are securely shut. Replace a bad safety switch.
See
ELECTRICAL POWER SWITCH FOR HEAT
FAN AUTO ON Thermostat Switch
WATER PUMP ELECTRICAL SWITCHES
CIRCUIT BREAKER FAILURE
ELECTRIC PANEL INSPECTION
Blown fuse, tripped breaker Replace fuse or breaker - does the pump run and keep running normally? Be sure proper breaker or fuse size in ampacity is installed - ELECTRIC PANEL INSPECTION Low voltage to the motor Check with VOM at the pressure control switch or at the motor wiring Be sure the proper size of wire is used for the ampacity and length of circuit; Test for low voltage to the building. Loose, improper, or broken motor wire Check wiring against the motor installation manual diagram, check all connections for tightness, shorts, burns, damage Rewire or repair or replace wWhen a sealed compressor motor has "burned out" this means that the internal wiring of the motor has become irreparably damaged: the compressor motor windings may be burned and shorted together or shorted to the steel shell of the motor, or the windings may have burned and simply become "open" or disconnected. If the motor has burned out in either of these ways it needs to be replaced.
Oct 08, 2012 | Dometic Rooftop RV Air Conditioner
Gateway W350i won't charge new battery
1) the charger from power supply inside of the laptop is defective.some component is burn or open,or short.
2) Of course you must shure that the batteries new is o.k you must go where do you buy and test it in another computer for to see is charging.
God bless you
May 09, 2012 | Gateway Computers & Internet
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
Aug 22, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Won't turn on
CHECK THE FOLLOWING----
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
May 31, 2009 | Dryers
Tappan 30 Series Range ignition system
no fuse/ with execption of trying to reset circuit breaker. perhaps the power tripped the breaker om the electrical panel, if the power supply is goos to the unit i would look to the spark module( it contorls all electronic ignition function
May 08, 2008 | Tappan TGF320 Gas Kitchen Range
Computers & Internet Logo
736 people viewed this question
David Payne
David Payne
