Question about Kenmore Washing Machines
My washer stopped spinning - Kenmore Washing Machines
  • 5,911 Answers
If your Kenmore does not spin, the two most common problems that cause this problem is either a lid switch malfunction or a broken motor coupling. The following link explains how to diagnose the problem to determine WHICH one may be the source of your problem:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
There are follow-on links included with the instructions I provided that also explain how to access and replace these parts (if required).
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) so that I may be able to determine how your washer is configured and provide you with better assistance. I hope this helps you.
NOTE: A no spin problem can also be caused by a bad gearcase (transmission), clutch, drive motor, or timer, but these parts are more expensive and do not routinely wear out as quickly as the parts I have mentioned. Its better to attempt to rule out the least expensive options first.
Posted on Feb 04, 2010
    President:
  • 1,768 Answers
1. you may have a malfunctioning "timer" which needs replacement.
this will take some electronic skills to replace.
2. I suggest that you call a repair person to replace it.
3. You also can call Sears repair and they should repair it for fee.
Posted on Feb 03, 2010
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
Washer spins to a stop.
the brake engages the clutch and no it does not stop right away.
Mar 23, 2014 | Frigidaire FEX831CS Top Load Stacked...
Washer is not completing the spin/drain cycle. Stops spinning and draining.
does it drain out all the water? after it stops or is there still water sitting in the tub?
Mar 22, 2011 | Kenmore Elite 45986 Front Load Washer
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Washer stops during spin cycle
i just relaced my door switch to my washer and it fixed my problem.my washer was doing the same thing as yours
Mar 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
After spin cycle washer stops abrubtly causing it to shift.
You have dragging brake shoes. This will cause the motor to draw excessive current. Nedd to take apart and pull down spin tube to access the brake shoes
May 31, 2007 | Whirlpool LSQ9600L Top Load Washer
Washing Machines Logo
70 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
