Question about Refrigerators
"clunking" noise when it turns itself off
My refrigerator is about 9 years old - top freezer. When it turns off, it often makes a loud "clunk" noise. What's wrong?
    President:
  • 1,891 Answers
The compressor mounts are bad . or the internal insulators in the compressor are bad . . is sounds like the internal mounts . at 9 yrs . . mm hope this helped . ,mm
Posted on Feb 04, 2010
Hotpoint fridge makes clunk-clunk-clunk noise when it shuts off
You need a new compressor. Probably time for a new frig.
Nov 18, 2011 | Hotpoint Refrigerators
We have an 11 year old fisher-paykel fridge .For past 6 months several times a day it makes a loud knocking noise
If this noise happens when the compressor turns on and shuts off it is called a compressor knock. All the internal workings of the compressor are supported by springs, over time the springs wear out and become weak. When the compressor stops or starts the tourq causes the internal parts to hit aginst the casing of the compressor. Sounds like a clunk clunk clunk noise. If you can deal with the noise do not go out and replace the compressor cause it will work just fine like that.
Sep 01, 2011 | Refrigerators
My 18 year old top freezer Inglis refridgerator has started to clunk. This noise began a couple of months ago. The clunk is fairly loud ( heard over the TV) and happens once every couple of hours. The...
The clunking is because the compressor has a broken mount and it clunks when it shuts off... this will eventually cause bigger problems, but probably you will need to replace the compressor to fix it...even so just check that a bolt did not come loose and that it may be a simple fix...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 06, 2010 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Compressor is making very loud clunk when shutting off.
I think the wire was kinda expensive. If I were you I would try to save the fridge. I think you should unplug it for a couple hours, take everything out for a while and remove any ice. Once the fridge reached room temp, the refrigerant should have made its way back to the compressor. Plug it back in and see if it makes the noise again.
It might just be the fan in the freezer. I would try the unplug/deice for a few hour method first because it is free before you try to replace a fan that might be bumping ice. Good luck!
Mar 10, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Every 20 mins or so the fride--a11 yr old
is it shutting off when it makes that clunking noise? if so, thats the compressor making the noise. the motor inside the shell casing, which is suspended on four springs, is banging agasint the shell casing because one of those springs has stretched or broken. You need to replace compressor. if its been happening for a while, i would start looking for a new model. if its more recent, and not very loud, you haver more time, but in either case, it could just cease up at any time. to hgave your compressor replaced, and unless your an HVAC tech you should most assuredly NOT do it yourself, its quite expensive, at or near the cost of buying a new one.
Feb 14, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My Kenmore refrigerator is making a loud noise when running and when it shuts off it makes a loud clunking noise. Also, it is running about every 10 minutes. The refrigerator is 7 years old.
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Nov 17, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Refrigerator makes fairly loud noises of a clunking kind but runs and stays cold.
Clunking noises usually comes from the rapid stop of the compressor. It will not hurt a thing. The rubber grommets which the compressor sit on for cushioning, have most likely hardened and are transferring the noise to the frame or casing. The compressor runs at 3600 rpm's and when you tell it to stop on a dime, it can't. The result is a couple of clunks or so. Also check the drip pan for improper positioning. I have seen them make noise also.
May 04, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
Loud clunking noise underneath fridge
its sounds like a spring is broken inside your compressor this you cannot repair you need a commpressor replacement or you can check if your fridge is levell sometimes by levelling the fridge it may reduce the sound thans from gilles
Dec 10, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refrigerators Logo
333 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
