Question about Paasche Talon Gravity Feed Airbrush Set
Paint feeds back into body , worked perfect for the first few times then started with paint flow into the body, as seen in the triger slot.
  • 100 Answers
It is dirty you need to clean with laquer thinner,you may need to soak overnite
Posted on Feb 14, 2010
Iwata eclipse G6 airbrush gun - no paint flow, bubbles forming in gravity feed bottle.
it is rather large (usually 0.6mm nozzle) airbrushing gun,
symptom indicate that needle is closing the nozzle and not retracting, gun need cleaning! or adjustment - seem like both...
remove paint from the feeder, remove feeder bottle from the gun body, clean it well with paint stripper and then solvent/water allow it to dry
remove front casing from the gun and check for any physical debris around the needle or in the chamber, carefully clean without damaging the needle. needle is stainless should be nearly mirror finish.wash with solvent and use toothbrush - DO NOT USE METAL BRUSH!
put it back together and check if it works correctly, if you have any flow from the front - fill about 1/3 of the tank with paint stripper and then spray it to the sink or whatever other safe place. do not forget to wear safety mask, goggles and gloves! paint stripper will eat through your skin! if you splash yourself, have few spoon of vinegar mixed with 2pints (1 liter) of water and this solution will deactivate paint stripper! SAFETY FIRST!
if gun still do not work - you need to strip needle assembly and clean it correctly, put your gun on the table on butcher paper, remove screw holding needle on the back (watch for the spring!) put whole assembly on the paper in the order in which you removed it,
clean needle and needle seat, lightly grease it with vaseline and in reverse order put it back together.
regulations:
very bottom screw - this close to the airhose, it regulates volume of the air to the gun, you very rarely need to adjust that one, you increase volume with haevy paint and decrease it with light paints
needle screw - it regulates volume of the paint itself, closing it clockwise will decrease amount of paint, anticlockwise will increase volume of paint
top screw - it regulates the spray pattern, totally closed - round pattern as there will be no flow to side vents, more open, more flat the spray pattern,
i would suggest fill the bottle with water and put some butchers paper on the wall and experiment what is what and what pattern is most suitable for your use.
hope this little info will help you solve your problem, it is good you give the model, it will be better if you provide as well what medium you use, was it acrylic, oil, water based? all of them behave little bit differently in airgun...
please do not hesitate to leave your opinion and points... thanx!
Oct 04, 2013 | Air Tools & Compressors
Air Brush blwa air out of tip but no paint. Whats up. Please help!!!
most common problem is paint, it is too thick, second problem is your feedline/needle block.
before you put your airbrush apart - remove paint from container, wash well with appropriate solvent, put some of this solvent to the container and try spraying, if no solvent comes out - adjust needle stopper, this is dual action! have needle adjustment! as you did not give the model and manufacturer, this can be only and only general advice!
if still nothing comes out - prepare butcher paper, disconnect airline from the airbrush, disassemble the gun putting the parts on the paper in order in which you disassemble it. wipe off the needle with soft cloth, use drop of solvent if needed. clean body and container assembly and check for liquid flow from container to the nozzle, it should be steady drop, if there is no flow, then use special brush and if you do not have one, soft copper wire of smaller diameter than the passage to clean mechanically the passage. check again for liquid flow. re-assemble the gun, use bit of vaseline or paraffin to grease the needle and moving parts before re-assembly.
use solvent first to check liquid flow. adjust needle, pattern and size of the max flow. remove solvent, put paint into the container and use normally.
in 0.2 nozzle, paint should be of virtually water density... if this is opaque paint - need to be strained as any impurities and bigger chunks will clog the outflow...
hope this advice will help you with your problem - and i do earn some points from you...
Aug 11, 2013 | Airbrushes 0.2mm Dual Action Gravity Feed...
My paint dries to fast, what should I do?
Acrylic paint depends on time, temperature, humidity, paint thickness, air-flow and absorbency to dry.
Reeves Complete Acrylic Painting Set
Oil colour
paint takes long time to dry than other media and it allows to think and it also provides the flexibility for changes.
Williamsburg Handmade Oil Color Paint Alizarin Crimson 37ml Tube
Feb 03, 2013 | Crafts & Hobbies
I have a gmc acadia and the rear bumper on it is filled with scratches, what is the best repai solution without changing the bumper
body shop estimate on paint and body filler and most important flex additive in the paint Best repair then there are the do it yourself kits of body repair and activator combination for the filling of the scratches but then your skills/ knowledge of body repair are needed for the repaint. Preperation below is key to the look above. all flaws seen in the primer and the sealer which can be seen show up many times worse with the shiny paint.
May 20, 2012 | Cars & Trucks
Lincon mig stops feeding wire
Been welding for a while, open side, check for proper tension on the feed wheel inside side panel, hit the trigger, if feed motor continues to spin tensioner needs tightened or mig wire may be getting hung up inside main cable lead. If motor is off on off on then its probbably the switch on the trigger getting a bad good connection, hope this helps o and check welding tip on gun end, may need replaced if worn or melted, unscrews.
Mar 05, 2012 | Welding Tools
I have a miller 255 nig .the welder will start to weld and stops gas flow is working the triger is working . You can relase the triger and start it again it willweld about 1 inch and stop emall ...
Sound like you have a machine programed on stitch mode, to override the program do the following:
1)Turn off the machine
2) With the machine turned off press the gun trigger.
3) Turn on your machine keep the trigger pressed, hold it for about 3-5 seconds. Depress the trigger and you should be good.
Jan 03, 2011 | Miller Welding Tools
Have a lincon 255Xt mig welder. You push the triger and it feed and try to weld and it arces then it stops right a way. Let go of the trigger and push the trigger and it feeds again. What is are problem?
Have you checked the tension on the wire roll feeder? Inside the unit where the spool is, the wire feeds off of the spool, through the feed roller, this roller has a tensioner spring on it that keeps the wire flowing steady, and also check the spring tension the keeps the spool from turning freely, keep this loose as can be, and just enoughthat it doesn't unwind on it's own.
There are so many things that it can be, but this is a start.
Good Luck.
Paul
May 07, 2010 | Lincoln X2688 2 YR EXTENDED WARRANTY FOR...
Staples SPL-P100 calculator feed
Okay. Tried the other ways listed here, did not work.. BUT fold the paper into a point.. then feed through.. it worked the first time!!
Feb 10, 2008 | Canon P23-DH Calculator
Loading paper
5/14/09-
Okay...It took me forever to figure it out but I finally got it. On the back of the calculator there is a slot (back meaning where the black cord is connected to the calculator). fold the paper to make a perfect straight line. feed the paper through there and press thee upward arrow. it should work.
hope I helped...=)
Aug 15, 2007 | Canon P23-DH Calculator
Loading paper
Hi, I had the same problem...but I fixed it. Here's how: At the very back of the calculater under the paper roller there is a very thin horizontal slot. Insert the tip of the paper roll into the slot, then press the paper advance button located on the top left hand sidw of the calculator until you see the paper. Guide the paper through the top slot and voila.
Mar 28, 2007 | Canon P23-DH Calculator
Paasche Talon Gravity Feed Airbrush Set Logo
203 people viewed this question
Top Paasche Air Tools & Compressors Experts
BJ Russell
Tom Chichester
Are you a Paasche Air Tool and Compressor Expert? Answer questions, earn points and help others
