Question about Asus Eee Pc 701Sd Notebook
I need a replacement internal fan and a keyboard clasp
  • 76 Answers
Ok so what do you want to know
Posted on Feb 03, 2010
Tour trek pushcart replacement parts
Fixya does not sell replacement clasps.
Jul 26, 2017 | Cars & Trucks
Need to get replacement electric fan motors for bathroom exhaust fans. 1-Model # F33HXCFJ-1187 and 1-Model # F33HXBME-903. Both made by Emerson 1/100 hp, 120 v
Hello
Using a stool positioned directly beneath the inoperative fan, grasp 2 opposite sides of the plastic fan cover and pull cover down 2 to 3 inches until wire holding clasps on each side are exposed.
Squeeze the 2 wires on each clasp together until the fan cover is released and set aside fan cover.
Locate fan electrical plug and unplug the connection from the electrical outlet.
Locate the screw securing the fan unit to the ceiling. This is often found directly adjacent the electrical outlet. Some fan models will have 2 securing screws. These will be located on opposite sides of the fan base.
Use flat-head screwdriver to remove securing screw, pull fan out of the fan well and set old fan aside.
Align replacement fan in position to allow electrical plug to be inserted in electrical socket and plug into electrical outlet.
Insert fan into ceiling well and secure by inserting and tightening securing screw(s).
Test fan by turning on wall switch. If fan fails to operate, check to be certain that the plug is fully inserted into the electrical outlet. If fan still does not operate, check circuit breaker and reset if necessary.
Replace fan cover by holding cover in place with 2 wire clasps just below the slots in the fan base. Squeeze the 2 wire ends of each clasp together and insert these into the the slots on opposite sides of the fan base. Once properly inserted, the ends of the wire claps will spring into place.
Push the fan cover up allowing the wire clasps to be fully inserted into the slots on the fan base, at which point the clasps will spring open securing the cover in place.
THANK YOU FOR VISITING FIXYA
Jan 31, 2011 | Home
I need to locate the cmos battery so i can replace with new one
Open up your laptop. To do this, you will have to unscrew five or six screws that hold the laptop together. Turn the laptop off and unplug it. Then turn it over and find the screw holes in the bottom of the laptop. Unscrew them and then remove the bottom portion of the laptop
The hardest part of replacing a CMOS battery may be finding the CMOS itself. Usually it is located right in the center of the motherboard (main circuit board of the computer). Look carefully around the motherboard until you find the CMOS. It is round and silver. Typical CMOS batteries are smaller than a quarter and about a 1/4 inch thick. It might say 3V CRV032 on the battery as well.
To remove most CMOS batteries, you need to undo a small silver clasp that fits across the width of the battery. Just pull this clasp up and slide the battery out. Take note of how the battery was set into the clasp. The new battery needs to go in exactly the same way. Once you have the battery out, you can insert the new one. Just lift up the clasp and slide in the battery.
Jan 16, 2011 | Dell Inspiron 1545 Notebook
The spring in the clasp has broken so the watch band will not stay closed. How can I fix this problem?
replace clasp is the best option..if clasp has 2 buttons on it these can be a easy fix but they always break again so i would replace clasp section or even all the bracelet for the watch .you will need model and serial numbers of the watch then try manufacture or ebay or a repairer
Mar 25, 2010 | Watches
I need to know how to replace the fan assembly on TM 2480
I can't seem to find any posts online from other owners of the TM 2480 who have tried taking apart their laptop. Disassembling a laptop is a bit of an intuitive business and you have to take it slowly and carefully if you're not that familiar with taking apart laptops.
I did find a similar model that was taken apart to replace the keyboard, in this link you can see where the fan assembly lies, so at least this might help you get started.
http://tomkaminski.com/acer-travelmate-6592g-keyboard-replacement-guide
Again, wouldn't be surprised if doing any of this voids warranty and such. Take your time if this is your first laptop tear down. Remember, cold weather+fluffy sweaters=static!! so ground yourself b4 touching the internals.
Hope that helps :)
Dec 06, 2009 | Acer Computers & Internet
Ceilng Fan light fixture-metal clasps have broken off
For Hampton Bay ceiling fan replacement parts!!!
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Nov 25, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Sat belt replacement
I need to replace the rear passenger-side seat belt buckle clasp but the clasp (under back seat) is connected to the seatbelt for middle backseat passenger.Can I replace just the passenger side without disturbing the middle belt?, cheers,Jen.
Oct 21, 2008 | 2000 Ford Focus
Replacing Door Hinge
You should be able to access the back of the hinge via the top of the machine removed.
Oct 07, 2007 | Hotpoint Ultima WD72 Front Load...
Asus Eee Pc 701Sd Notebook Logo
79 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
