Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Funky smell coming from bottom of frig when running
Funky smell coming from bottom when refrigerator is running, has no water pan only on the water disposal side and it is clean. Have looked underneath see nothing that can cause the odor. Please help, don't like
the smell.
  • Whirlpool Master
  • 3,740 Answers
Is it a musty smell or that of something / (rodent) decomposing? If you only smell it when it is running then look for BLACK gunk that will probably appear almost like a paste. Even things like cat or dog hair will collect in damp areas. There should be a white plastic drip pan under your unit. Look for the freezer white plastic drain hose on the rear bottom of your unit on the freezer side and follow that hose to the drip pan. It catches water every time the unit defrosts which is 3 - 4 times a day depending on which defrost timer your unit has.
Usually there is a build up in the drip pan that gets mucky and then stinks like mold. It will of course need cleaned.
Also look at the fan area for the coils. Sometimes there are unwanterd home critters that attempt to get through the running fan blades and end dead up inside the cooling coil metal radiator area.
Posted on Feb 03, 2010
There is a bad smell that I get a wiff of when I walk by. The smell is on the right hand side of the frig. Sometimes it can be smelled for a short distance. The smell is not coming from inside the frig,...
Some of them do have a drip pan under them ,at the bottom of the frig there is a cover that will come off may be screwed on may snap off when you pull on it.Take a flashlight and shine under it after you get plate off you should see it .You can put a cap full of bleach in it should take care of your problem.
Sep 20, 2017 | Whirlpool GX5FHTXT Bottom Freezer French...
On humid days water puddles in the bottom of the frig.
Sounds like the door is not closing properly so humid air is coming into the fridge OR door not closing properly and the humid air is condensing around the door so it is leaking the condensation OR
The water from the defrost cycle is not evaporating so it overflows from the evaporator pan above the compressor. You better call a service technician before getting some floor damage (Do not call A&E)
May 02, 2010 | Refrigerators
Dead fish smell from my Kenmore Elite Bottom Mount Refrigerator
dead fish smell ( under the frig there is a cond pan that collects water from the defrost . whirlpool has some tabs that you can put in pan/ it helps .. I would put a cup of bleach in pan every 3 months . and if you can find the drain inside the freezer add it thorugh the drain . algae builds up in drain and plugs it . mm
Dec 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My older KA Ref Model KTRP20K & M is giving off a strong odor similar to iodine. Very strong in AM but can still smell it in PM. I've checked for spoilage and nothing there. Any thoughts? Is it time...
since it is working ok . i am wondering if you dont have mold growing in the drip pan ... condensation from inside the refrigerator goes down a small tube in the back bottom of the frig ... that tube goes to a pan under the refrigerator and normally the water just evaporates .. if there is a lot of condensate from the frig then the pan may stay wet long enough for mold to get established ... a large amount of condensate from the frig usually indicates a leaky seal around the door .. or a door that doesnt close completely .. you might want to clean everything under the frig including any fans, coils and that pan (unplug first) ... now this all assumes that the smell is coming from the outside not inside the refrigerator .. if the smell is inside then you may have to defrost and clean the evaporator (the coils inside the freezer (somtimes also in the refrigerator) ... there are some kinds of mold that actually grow in that cold environment .. some hot soapy water with a little bleach usually does the job .. or if you have one, a steam cleaner, those do great .. it allows you to get down in the little places and clean everything ... make sure the frig is at room temp first so plastic doesnt crack ..
the refrigerant r22 or r134a have very little smell so even if you had a leak it wouldnt smell strong .. a few refrigerators use ammonia and that would have a distinctive smell easily recognized if there was a leak .
Nov 22, 2009 | Cell Phones
Do we need to replace a water filter on this GE model TFX25JRBA ?
I have a problem with my refrigerator , has a funky smell and when you taste the water is funky smell too, so waht is the problem the model is tfx25jrbbww serial vt231111.
Jul 05, 2009 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
Fishy smell in frig
Change the filter. Depending on your water supply and where you are located, you will get a buildup of junk that smells like fish.
It should be changed about every 6 months.
Feb 17, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Drip pan
the drip pan is built into the bottom and dont come out ,,, check the drain pipe to make sure its still sticking in the pan ,,,, also check the bottom inside of your freezer, drain may be stopped up and causing water to come out front edge of door / larry
Nov 29, 2008 | Hotpoint (HSM25IFTSA) Side by Side...
Very bad odor in Maytag refrigerator
There is a very bad smell from the bottom of the refrigerator . There is a pan under the refrigerator with a very bad smelly Liquid , How can I clean that pan I couldn`t pull it out ? Thank you
Feb 20, 2008 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
267 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
